Old 08-15-2020, 11:27 PM   #26
85/Silverado
85/Silverado's Avatar
Re: Body Roll
I don't see a way to lower these short shocks 10"
I think there not strong enough to handle the rear of the truck
I don't think I can mount a rear sway bar, not enough room.. even heavy duty springs on the rear would screw up the ride.
Yes I would say the guy was clueless.
85 Silverado LWB Fleetside 383 Stroker
86 Custom Deluxe SWB, Pro Street LSX
85/Silverado is offline   Reply With Quote
Old 08-16-2020, 12:42 AM   #27
SCOTI
SCOTI's Avatar
Re: Body Roll
Or.... He set it up just the way he wanted it. It functioned well enough to sell after the fact.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-16-2020, 07:09 AM   #28
85/Silverado
Re: Body Roll
I was told to buy a Panhard Bar and bolt it to the ford 9" and the frame and that would stop the rockin.
What do you think?
Old 08-16-2020, 08:41 AM   #29
gmc684x4
Re: Body Roll
Install front sway bar
Relocate rear shocks outward
Like suggested
Panhard bar is to keep diff centered on a truck arm or camaro style setup it has no sway bar properties
This four link rear suspension is built for drag racing not for corner carving
That is why it sways
gmc684x4 is offline   Reply With Quote
Old 08-16-2020, 01:30 PM   #30
SCOTI
SCOTI's Avatar
Re: Body Roll
What do you think?
Like suggested
I would agree w/gmc684x4.
Panhard bar is just a side to side locator. It's not going to impact 'body-roll' significantly. A front sway-bar + the rear springs/shocks out-board of the frame (or as close to the frame as possible) will make the biggest impact.
Personally I would remove what's there for a rear Ride Tech 4-bar/coil-over set-up (or similar manufacturer). But, I get minimizing expenses & working w/what's there if possible.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
