Old 08-03-2020, 07:33 PM   #26
RotaryRocketeer
RotaryRocketeer's Avatar
Re: Triumphant Return
Originally Posted by jjzepplin View Post
Did you upgrade the internals of the LQ4?
To a point, but nothing extreme. Has a healthy truck oriented cam, .010 over, a good valve job on fresh heads, and appropriate springs. Rotating assembly otherwise stock.
RotaryRocketeer is offline   Reply With Quote
Old 08-03-2020, 09:33 PM   #27
RotaryRocketeer
Took it across the scales today. Just a bit heavier than I figured. This is with me in it, 3/4 tank, and all the tools one would keep in a truck.
Old 08-05-2020, 02:25 PM   #28
jjzepplin
jjzepplin's Avatar
What heads do you have? 317?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-05-2020, 07:59 PM   #29
RotaryRocketeer
Yep. Although I have a set of 862s that I’m slowly porting as I get the time.
Old 08-09-2020, 12:12 AM   #30
RotaryRocketeer
Finally got around to installing the stainless brake hoses in the front end, and let me just say NEVER AGAIN. What a pain! They obviously hadn’t been off EVER and the PO was real lax about letting things leak and accumulate grunge.
I’ve never encountered front hoses that were such a hassle, but the task is done and the brakes are much tighter. The lines also didn’t have a 90 degree bend coming off the caliper. Made for a funky fit, but the manufacturer says these are correct and they do function well.
Old 08-09-2020, 07:17 AM   #31
Greenlee
Greenlee's Avatar
Nice truck! Looks like a work horse.
Greenlee is offline   Reply With Quote
Old 08-09-2020, 08:14 AM   #32
jjzepplin
jjzepplin's Avatar
Yeah them stock lines are a real mutha. I put steel braided on my 4x4 fronts 20 years ago and they are still working great. I recall the originals being a real fun day to get off but the new ones were easy to install and I probably should replace them now that you mention being lax.
Old 08-09-2020, 12:29 PM   #33
Ziegelsteinfaust
That's not too bad. You have a 14 bolt FF, and they weigh close to 600 pounds. A flat bed can be a 1000 pounds because they are designed to be abused. Plus what looks like a heavy duty tool box, and how many tool?
My 07 GMC rcsb weighed 4900 with a full tank if gas, and me.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-09-2020, 04:36 PM   #34
RotaryRocketeer
Thanks Greenlee! I try to make it better any time I can.
Old 08-09-2020, 04:39 PM   #35
RotaryRocketeer
You ain't kiddin'. That job was almost like some kind of punishment or rite of passage. After a pretty entertaining contortion act on the passenger side, the driver's went a hair smoother, but not much.
I'll lend you some moral support from afar when you do yours.
Old 08-09-2020, 04:44 PM   #36
RotaryRocketeer
It was just a couple hundred lbs. over what I had guessed. WOW! Later gen RCSB trucks are that heavy?!
No FF rear here though. This sucker has a 14 SF (weak sauce) and there's no toolbox on it. Just some things under and behind the seat. You're dead on with the bed though. Right around 1,000 lbs. She's just an ol' flat girl.
Edit: Nevermind. It is a FF rear end. I don’t know what I was thinking.
Old 08-14-2020, 02:55 PM   #37
RotaryRocketeer
Driver’s side rear hub bearing started clicking pretty hard a couple days ago. It would seem that the truck’s new heart is a bit too strong for its worn out old ankles.
I’m gonna order parts and do both sides in the same sitting. Y’all got any advice or tips and tricks to help it go smoothly? I’ve never done anything to a 14 bolt FF, so any advice is appreciated.
Old 08-15-2020, 10:03 AM   #38
jjzepplin
jjzepplin's Avatar
It was not your engine that damaged your 14 bolt. They are pretty indestructible. Most likely it was just age or a bad seal. They are very forgiving if you make sure you replace the bad parts with good name brand stuff.
