10-05-2020, 03:30 PM | #26 | |
Re: A 2-link question-
A front 'Z' done properly helps get the ride height @ a lower altitude w/o compromising ride quality. Do the Caster mods & taller upper BJ for a quicker Camber curve w/the OE suspension. Leaves $$ for better quality shocks as well.
10-06-2020, 12:14 PM | #27 |
That's pretty much the plan. What's the taller upper ball joint? I did the 3/4 mod (moved the joint and boxed the arm) on the 67 I just did, much improvement. No urge to swap the rear clip.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-06-2020, 02:46 PM | #28 | |
The Square set-up that they did the T/A rear clip was also a long to short conversion so they were cutting the frame in half anyway. Basically from the rear cab mount forward was 73-87 & from the front bed mount back was 67-72. I didn't see how they did the splicing so I'm not sure on specifics. I considered the T/A swap for my 74 before swapping it for my Dually. My plan was modding a 67-72 x-member. I had both OE & aftermarket so not sure what path it would have went (whichever was easiest/better fab wise).
10-19-2020, 12:33 PM | #29 |
I understand the geometry, my question was more toward Part Number. I wasn't aware of a taller part of these trucks and now I'm interested.
10-19-2020, 12:58 PM | #30 | |
https://www.summitracing.com/parts/qa1-1210-203b
10-22-2020, 03:52 PM | #31 |
Hmm. Interesting, thanks!
