Old 11-28-2021, 12:57 PM   #26
jrusher
Re: 1965 c10 patina build
Your making great progress looks good!
jrusher is offline   Reply With Quote
Old 11-28-2021, 03:07 PM   #27
66C10LB
Great to see things moving along with your build!
66C10LB is offline   Reply With Quote
Old 11-29-2021, 09:49 PM   #28
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
If you are doing that well using flux core, you'll find it a breeze with gas shielded.
66 C20 Service Truck:
Old 11-30-2021, 08:13 AM   #29
65truckowner
65truckowner's Avatar
Yes I know but what I have is all I could afford at the time. It has been a great little welder. I would love to upgrade to a better one with gas so much better to weld with
65truckowner is offline   Reply With Quote
Old 12-01-2021, 12:11 AM   #30
LostMy65
LostMy65's Avatar
I just wanted to say you were doing a great job with the tool you have.
That's all I have for now also.
Old 12-01-2021, 09:06 AM   #31
65truckowner
Old 12-07-2021, 08:06 AM   #32
65truckowner
I have the cab on and part of the front clip. I am going to patch the drivers side fender it is really rough.IMG_4611 by Daniel Crymes, on FlickrIMG_4610 by Daniel Crymes, on Flickr
Old 12-07-2021, 11:38 AM   #33
66C10LB
Good work! That fender looks very rough. Is a replacement fender a possibility? I guess it could be challenging to match the patina though.
Old 12-07-2021, 08:50 PM   #34
65truckowner
I am planning on priming the rockers light gray and thought I would do the same to the patch panel on the fender. I hope it looks of like that
Old 12-18-2021, 08:04 PM   #35
65truckowner
Did some work on the door rust today then hung the doorIMG_4627 by Daniel Crymes, on FlickrIMG_4626 by Daniel Crymes, on FlickrIMG_4629 by Daniel Crymes, on FlickrIMG_4630 by Daniel Crymes, on FlickrIMG_4633 by Daniel Crymes, on Flickr
Old 12-18-2021, 08:04 PM   #36
65truckowner
I will do the body work then just prime the corners and the rear of the front fender.
Old 01-30-2022, 08:13 PM   #37
65truckowner
I got the bed floor cut out todayIMG_4874 by Daniel Crymes, on Flickr
Old 01-31-2022, 12:58 PM   #38
pdxhall
pdxhall's Avatar
The bed wood looks great. What type of wood are you using?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-31-2022, 08:38 PM   #39
65truckowner
It is pine I am staining it the dark color you can see on one of the short boards in the picture. What color should I paint the metal strips?
Old 01-31-2022, 09:47 PM   #40
cwcarpenter98
cwcarpenter98's Avatar
I didn't repaint my strips, but they still have some of the original, black paint left. I really like the look of the black strips with the color stain I have. Post 588
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-01-2022, 08:32 AM   #41
65truckowner
Yes the black strips you have look great!
Old 05-03-2022, 09:02 PM   #42
65truckowner
Slow go but got the interior painted and ready to put together. I order a bunch of parts just waiting on them.IMG_5437 by Daniel Crymes, on FlickrIMG_5438 by Daniel Crymes, on FlickrIMG_5434 by Daniel Crymes, on Flickr
Old 08-21-2022, 06:30 PM   #43
65truckowner
It lives!!IMG_8326 by Daniel Crymes, on Flickr
Old 08-21-2022, 06:31 PM   #44
65truckowner
Click on the picture for the video of it running
Old 08-21-2022, 06:58 PM   #45
66C10LB
It's great to hear it run! For the radio cut outs, did your truck come like that, or did you have to repair and cut out for the radio? I will have to do mine soon and have a template, but will have to make sure it is correct.
Old 08-23-2022, 07:02 AM   #46
65truckowner
I put a radio delete plate where the radio was.
Old 08-23-2022, 08:18 AM   #47
66C10LB
Good idea.
Old 09-25-2022, 07:26 PM   #48
65truckowner
Done with another project. Here are some pictures.IMG_5738 by Daniel Crymes, on FlickrIMG_5735 by Daniel Crymes, on FlickrIMG_5731 by Daniel Crymes, on FlickrIMG_5729 by Daniel Crymes, on FlickrIMG_5722 by Daniel Crymes, on FlickrIMG_5719 by Daniel Crymes, on Flickr
Old 09-25-2022, 07:29 PM   #49
65truckowner
IMG_5720 by Daniel Crymes, on FlickrIMG_5714 by Daniel Crymes, on FlickrIMG_5713 by Daniel Crymes, on FlickrIMG_5732 by Daniel Crymes, on Flickr
