05-01-2022, 05:50 PM | #26 | |
Re: New owner of 1966 C10 Camper Special
05-18-2022, 09:05 PM | #27 |
Might make a new thread about this but figure I'll just add this here and see if I get any responses.
My truck is so smoky, especially when it starts. I haven't done anything to it yet but wonder what I should attack first to make it run a little cleaner. |
05-18-2022, 09:22 PM | #28 |
Smoking real bad on startup is usually bad valve seals. You could have some other oil control issues if it's smoking all the time
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-18-2022, 09:54 PM | #29 |
05-19-2022, 05:33 PM | #30 | |
A valve job usually refers to cleaning up the valve seats on the combustion chamber side of the engine and replacing or cleaning up the valves.
05-19-2022, 05:35 PM | #31 | |
05-19-2022, 05:35 PM | #32 |
Happy to help!
05-19-2022, 09:25 PM | #33 |
You can change valve seals without removing the heads. It involves putting an air fitting in the spark plug hole. Air pressure applied keeps the valve from falling down when you remove the valve spring. I've never done it but there's videos on youtube.
Edit: You can also accomplish the same thing by feeding some rope in the spark plug hole while raising the piston until the piston and rope come up tight on the valve, holding it up. Last edited by bigmoe; 05-19-2022 at 09:38 PM. |
05-20-2022, 04:41 AM | #34 |
To add to Bigmoe's comment I changed out valve springs both ways, air and, in my case, an old spark plug lead - you will need to remove the valve springs to replace the seals.
It is really rather simple - don't be afraid to give it a go - and if it doesn't go according to plan take the head off and use the opportunity to do the valve job. Looks like a really nice truck. Enjoy! P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
05-20-2022, 09:05 AM | #35 |
Thanks to both of you.
