Old 11-30-2022, 04:10 PM   #26
leegreen
Re: Front Bumper Option
mold in question. this is for the bottom of glove box that needed to clear a larger than factory delux heater. A lot of the masking tape pulled off when I made the bottom, but I was able to re-use the same mold without that notch at the back to make the top half and used packing tape for the top.
For the bumper I would not rely on tape. I could destroy the cardboard mold if needed and deformed it quite a bit getting bottom out. Bumper would not be so forgiving
I'm contemplating a headliner molded on roof. Someone on here did that but never posted the final results
leegreen is offline   Reply With Quote
Old 11-30-2022, 04:15 PM   #27
dsraven
I've used wax paper before, kitchen variety.
Old 11-30-2022, 06:46 PM   #28
hotrod1
56 - autocross
hotrod1's Avatar
Thank you everyone for the direction.
hotrod1 is offline   Reply With Quote
Old 12-01-2022, 01:12 PM   #29
_Ogre
_Ogre's Avatar
Originally Posted by hotrod1 View Post
What weight and type of cloth and resin? Where do I get it at?
i wouldn't use cloth, use 3/4oz mat.
cloth doesn't lay well without wrinkling up, wrinkles are air that need grinding out
look thru my build a bit, i documented quite a bit of fiberglass fabricobbling
buy a gallon of un waxed resin and 5 yards of 3/4oz mat
you probably won't need a gal, but buying 2 qts is probably the same cost
if you need help ask in my thread, i'm snowbirding in tx for the next 4 months
i won't have pictures like on the pc but i can talk you thru what isn't in my build
here is where i bought my materials uscomposites.com/polyesters
just get the 404 Tooling Polyester Resin-Isophthalic
shop air compressor timer
Old 12-01-2022, 01:21 PM   #30
hotrod1
56 - autocross
hotrod1's Avatar
Thanks for your help everyone. I sure appreciate how nice everyone is here.
Old 12-05-2022, 10:37 AM   #31
my56chevytruck
my56chevytruck's Avatar
Not close to stock.
can you post a picture of what your truck looks like upfront??
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-05-2022, 02:27 PM   #32
hotrod1
56 - autocross
hotrod1's Avatar
I cant yet- its in pieces.
Old 12-06-2022, 01:02 AM   #33
mick53
Back in my surfing days we used balsa wood runners for strength. We used soap or car wax for mold release in our skateboard molds.
mick53 is offline   Reply With Quote
