06-05-2023, 11:19 AM | #26 | |
Re: brakes go to floor
Read post #8 in this thread. You need to check the depth of the pushrod hole in the master. Possibly it’s the source of all your symptoms. https://67-72chevytrucks.com/vboard/...d.php?t=844976 |
06-05-2023, 12:21 PM | #27 |
I would check the other rubber brake lines, they are probably deteriorated and squishy like the one that burst. You made sure there is no leaking from seals in all four corners right? That being said you should be able to get brakes even with old hoses. You just sucked up a lot of air when that hose burst . Not trying to be a jerk but when you had someone in the cab pumping brakes. That person held brake pedal down and then you cracked open bleeder correct? If so just keep bleeding brakes and pedal should come around
79 Chevy 2wd BIG10 350 TH400 |
06-05-2023, 09:13 PM | #28 | |
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350 and 700r4. ~ James |
06-05-2023, 09:15 PM | #29 |
Okay thanks, will do
06-05-2023, 09:17 PM | #30 |
So I bought a vacuum pump and pumping it up to 20 inches of pressure. I lose all of that in 10 seconds. Does that mean my booster has a leak? Is that how this test works?
I tested the tube by itself and it held the pressure with a stopper at the other end of the tube.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350 and 700r4. ~ James Last edited by K10-Kansas; 06-05-2023 at 09:39 PM. |
06-05-2023, 09:42 PM | #31 |
Moving the pump to vacuum it's holding 17.5 inHg steady, no issues. Maybe that's how this test goes? Vacuum and not pressure?
06-05-2023, 10:10 PM | #32 |
Post Whore
Yeah...you check with vacuum ..not pressure...
again, the booster isnt causing the issue your having.. my best guess is you have air in the system somewhere,
06-05-2023, 10:13 PM | #33 |
Great, thanks for that confirmation. It makes sense, based on all of the information I've gotten in this thread that the behavior would be the opposite of what I have if it were a booster. I appreciate all of the great advice from everybody I've learned a lot on this one.
06-05-2023, 10:57 PM | #34 |
Post Whore
If the booster was bad it would have a very hard to press pedal, like when the engine isnt running
06-05-2023, 11:45 PM | #35 | |
When I went to the parts store and asked for a 77 k10 mc, they handed me the exact same mc that I already had.
06-07-2023, 04:06 PM | #36 |
x2.
I may be old, but I still enjoy the feeling of the earth rotating beneath my wheels... |
06-07-2023, 11:23 PM | #37 |
Just to clarify, you opened the bleeder and then had someone pump the brakes? If you do this, every time the person working the brake pedal leaves off, the bleeder will suck air back into the line. Pump the brakes until resistance is felt then have them hold the pedal down, you open the bleeder, let the air or bubbly fluid escape and close it. THEN resume pumping the pedal, holding, opening and closing the bleeder however many times it takes until no air comes out. As stated earlier, start with the rear brakes. Also make sure someone didn't install a caliper upside down with the bleeders on the bottom
06-08-2023, 04:03 AM | #38 | |
He said he bottle bled the brakes, it's even in the part you quoted. When you bottle bleed it doesn't suck in air it sucks in brake fluid.
06-08-2023, 07:01 AM | #39 |
Some auto parts places just sell a bottle with a hose to catch the brake fluid so it doesn't go everywhere. The don't have the siphon tube. Idk just lending my $.02
06-08-2023, 07:11 AM | #40 | |
06-08-2023, 09:00 AM | #41 | |
06-08-2023, 10:15 AM | #42 | |
06-08-2023, 11:47 AM | #43 | |
You're the second one that said something like that, so I was just pointing it out so there was no confusion.
06-08-2023, 12:37 PM | #44 |
Post Whore
Times like this is when I realize how much I like my pressure bleeder..
Hundred bucks well spent..
06-09-2023, 11:14 AM | #45 |
Does this look like okay pressure for the rear brakes? Looks like maybe the rear brake line is bad because it's pumping air bubbles. Or is that a part of bleeding a master cylinder?
https://youtu.be/l7hl23f5f5k
06-09-2023, 12:38 PM | #46 |
Bench bleeding involves hooking up tubing from the outlet ports back into the reservoirs.
This kit will show you the process. You only bleed the master and nothing else. https://shop.wilwood.com/products/ma...er-bleeder-kit |
06-09-2023, 12:43 PM | #47 | |
My question is, is this amount or pressure/flow I'm getting good? i.e. showing that it is working as expected?
06-09-2023, 12:56 PM | #48 |
In your video I can’t see where your lines are connected to.
I assumed they might be coming from the outlet of the prop valve or elsewhere. If I’d known their source I’d of made no comment. Apoligies for that. |
06-09-2023, 01:00 PM | #49 |
Quite a difference in air bubbles.
Which reservoir is which? |
06-09-2023, 01:01 PM | #50 |
Oh gotcha, yeah I see, I shot that video really close you can't see where the lines are coming from.
