#26 |
Re: I知 sorry
>>OK, this thread has gone over the top for weird...<<
And, that is only half the fun. No one screamed out that the sky was falling. No one cried foul. No none insisted that the engine couldn't even be running much less than be running better than a Q-jet. He has committed the offensive sin of using the ported vacuum port. Oh, the horror of it all. This carb doesn't even appear to have the manifold vacuum port drilled. Surely, a sin against the gear-head gods has been committed. How's that for redirected topic?
'67 GMC 2500, 292, 4spd, AC |
#27 |
![]() Join Date: Jul 2000
Re: I知 sorry
If someone hasn't mentioned it yet, the carb in the OP's picture is a Carter AFB. Each of those carbs was calibrated for a specific engine, in this case maybe an AMX 390.
Edelbrock sort of copied it and has probably sold at least tens of thousands over the years. They are rated at 500, 600, and 750CFM and have the fuel inlet on the passenger's side. Also, some of the AFBs had 3-step metering rods, whereas the Edelbrocks are 2-step. I call TMI on myself!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#28 |
Re: I知 sorry
That is really cool!
#29 | |
Re: I知 sorry
Edelbrock bought the rights to these and they were made along side of the Carter AFB on the same Webber carb line .So the really didn稚 copy it
#30 |
Re: I知 sorry
>>some of the AFBs had 3-step metering rods,<<
Actually, only the Carter AVS carbs used the 3-step rods. That includes the newer Edelbrock AVS carbs that are also the 2-step rod design. >>Each of those carbs was calibrated for a specific engine,<< Not as critical as some might assume. I have a 1970 383 Mopar Carter AVS on my 292 six and it works just fine with no jet changes. I did change the springs on the vacuum pistons above the rods. Its been on there about 17 years.
#31 |
Re: I知 sorry
These guys did bad rebuilds, I don't care what their reputation "was". Never had an issue in my 50 years of running these trucks. I use a local benchwork rebuilder. Bolt on and go every time. The valve bodies or any number of parts not normally replaced in a routine rebuilt can wear out in over 50 years. A carb specialist could possibly just run a carb through not being as thorough as required for that particular carb. All carburetors go bad, have some kind of issue, and it doesn't happen to everyone. I've never had any carb rebuilt that didn't come back with pleasing results, any brand. I love the Carter square bores, but spread bore is the superior design by far except for WassOT race uses. I feel your pain, Mark. Your experience sucks
#32 | |
Re: I知 sorry
Had an AFB been used on a 292 six back then, you can bet it would have been a lot different than one meant for a Chrysler 383, or even a Chevy 327. But it's cool that yours has been working fine on the 292 all these years. So, I'm not saying they won't work from car to car, all I'm saying is there tons of different model numbers for specific engines. Back in the day, I actually had one with a manifold from an Impala 327 that worked just fine on my 283 that had been bored to 292. The Impala's owner decided he needed a Z28 carb and manifold, as I recall. Just found this: CHEVROLET 1958 8 348 Carter AFB 2859 828 1959 8 348 Carter AFB 2897 828 1960 8 348 Carter AFB 3012 828 1961 8 348 Carter AFB 3221 831 1961 8 348 Carter AFB 3012 828 1961 8 409 Carter AFB 3270 829 1962 8 327 S/T Carter AFB 3269 567 1962 8 327 A/T Carter AFB 3310 567 1962 8 409(Front of 2) Carter AFB 3361 830 1962 8 409 (Rear of 2) Carter AFB 3362 830 1962 8 409 Carter AFB 3345 832 1963 8 327 300, 340 HP Carter AFB 3461 567 1963 8 327 300, 340 HP Carter AFB 3460 567 1963 8 409 Carter AFB 3499 829 1963 8 409 (Front of 2) Carter AFB 3361 830 1963 8 409 (Rear of 2) Carter AFB 3362 830 1964 8 327 S/T Carter AFB 3721 567 1964 8 327 A/T Carter AFB 3720 832 1964 8 409 Carter AFB 3783 833 1964 8 409 (Front of 2) Carter AFB 3361 830 1964 8 409 Carter AFB 3499 829 1964 8 409 (Rear of 2) Carter AFB 3804 830 1965 8 327 A/T Carter AFB 3720 832 1965 8 327 S/T Carter AFB 3721 567 1965 8 409 Carter AFB 3783 833 1965 8 409 (Front of 2) Carter AFB 3361 830 1965 8 409 (Rear of 2) Carter AFB 3804 830 1966 8 327 275 HP Carter AVS 4027 1442 1966 8 327 275 HP Carter AVS 4028 1442 Lots of AFB info here, from American Motors to Studebaker. Must be 200 P/Ns for Chrysler! https://www.hemmings.com/partslocator/carburetors.html I wonder if some of these "aftermarket" carbs are what Edelbrock Performer series carbs are based on? 9400 Aftermarket 400 CFM AFB 9410 Aftermarket 400 CFM AFB 9502 Aftermarket 500 CFMAFB choke less carb, with GM linkage 9511 Aftermarket 500 CFM AFB Chrysler linkage, for square-bore manifolds 9605 Aftermarket 600 CFM AFB manual choke carb, with GM linkage 9625 Aftermarket 625 CFM AFB 9626 Aftermarket 625 CFM AFB 9627 Aftermarket 625 CFM AFB 9635 Aftermarket 625 CFM AFB 9636 Aftermarket 625 CFM AFB 9637 Aftermarket 625 CFM AFB electric choke carb, with Ford linkage For Aftermarket Competition Series: CS 4758 500 cfm AFB CS 4759 625 cfm AFB CS 4760 750 cfm AFB CS 4761 500 cfm AFB CS 4762 750 cfm AFB
#33 | |
![]() Join Date: Dec 2017
Re: I知 sorry
#34 |
Re: I知 sorry
The two rebuild shops are local . Both have been in business for years but like anything else time change . The ship that did my AFB also did the last Qjet . Now to be fair the guy that did my AFB was in his 80s and started the business in the 60s he had since passed and his grandson who worked there took over . Guess quality went down as now the shop is focused on new tuner stuff .
The other Qjet was done in new jersey . Again a long time shop I just got two bad ones . My 85 runs great with a Qjet .
#35 | |
Re: I知 sorry
Go down to "Carburetor Selection -- Single Carburetors" here, for some interesting info and insight. https://www.thecarburetorshop.com/Carbshop_carbs.htm And this statement by Jon makes me shake my head at Holley and Edelbrock for continually pushing square bore carbs on us. (OK, Edelbrocks are semi-spread bore.) We have found that, for modern 8 cylinders of 300 CID or larger, almost without exception, a spread-bore carburetor (small primary, and large variable secondary) will perform best on the street.
#36 |
Re: I知 sorry
At the risk of going off topic, but still on the Q-Jet topic (maybe?), Many years ago, before I knew some of those issues with Q-Jets, I purchased a new Holley spreadbore q-jet replacement 450 cfm "economaster?" carb. I put that carb on a 400 small block with headers but bone stock otherwise with TH350 trans, and 3.31 gears in a mid 70's Chevelle (probably heaviest Chevelles every built). While some would argue that carb was too small for a heavy Chevelle with 400 in it, it was surprisingly responsive, and avg of low 20's in fuel mileage. Keep in mind this was at a time before fuel injection, or really any emission requirements, yet fuel prices were on the rise (or so we thought). That was the only Holley I have ever owned. I currently have a 72 C20 with factory (stock) 402, just rebuilt the factory Q-Jet and put on an aluminum Edelbrock high rise intake, and headers. Interested to see how it does. TH400, Dana 60 with 3.54 gearing. Should have put in a little more cam, but lets see what happens, and I can always do that during winter months if I am not happy.
#37 | |
Re: I知 sorry
Years earlier I had installed a Economizer 2-bbl carb on a 74 emissions-laden 350 Buick engine. It made the car run smoother at low-mid RPM and increased gas mileage by around 2 MPG. Bought that carb from a customer mine of who owned an auto parts store. He said it was a very popular item, and I can see why.
#38 |
Re: I知 sorry
I run one of these on my truck and love it. The way it keeps pulling from 1st to 2nd with little pedal is very nice. Over time I've collected a pile of them. They're also simple to rebuild although the kits aren't cheap. The list numbers to look for are 7454, 7455, 7456 and all have mechanical secondaries. For our purposes those are all interchangeable.
#39 | |
![]() Join Date: Feb 2002
Re: I知 sorry
Turned out to be for a late '60s Mopar 440 from the numbers. Someone had played with it, however. The primary jets were in the secondary position and the other jets were missing. Also the secondary area had these perforated tubular probes, not annular rings. The jets were these deep cups. The 3-stage metering rods looked shot. [Worn and grooved.] New AVS 3-stage parts are inobtainable. When Edelbrock came out with the Thunderer AVS, I bought some fresh Edl- parts for it, but nothing came of it. The project lost my interest when I couldn't find any information on AVS tuning.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-28-2023 at 11:31 PM. |
