Old 12-08-2010, 07:08 AM   #476
spike38
spike38's Avatar
Re: Project Lemon Drop: anything but stock!
Originally Posted by jugernot View Post
Well I have become a victim of the financial crunch. My bills have got the best of me and I couldn’t ignore them any more. So I used the money I was saving for Lemon Drop to help ease the burden.
Tis the season man! I'm feeling it myself.
Spike
spike38 is offline   Reply With Quote
Old 12-18-2010, 01:39 PM   #477
Rokcrln
Rokcrln's Avatar
Before you pull the trans lets talk and I will come up and give you a hand and pull the front sheet metal off so you don't scratch that cab bottom. Get a hold of me after the 1st of the year and I will bring your X-mass gift to you in the form of 2 hands (for truck use only!) for the day!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-21-2010, 09:06 PM   #478
jugernot
Life, Be In It.....
jugernot's Avatar
Kevin
LFD Inc.
Will do, sounds good. Thanks
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-29-2011, 11:51 PM   #479
jugernot
Life, Be In It.....
jugernot's Avatar
Finally we made some progress. Kevin came by today and we pull off the dog house, removed the th350 transmission. Which I must say I'm glad we did because Kevin noticed that the flex plate was bent. We replace the flex plate and then install the new 700r4. There is an issue with the Early Classic transmission cross member doesn't quite meet up with the transmission mount.
While the fenders were off Kevin sorted out the AC and Heater hose issue at the bulk head fitting. We then put the dog house back on. Kevin re-aligned the front sheet metal and installed the inner fender wells.
We got a lot done in about 9 hours.
Old 01-30-2011, 03:13 AM   #480
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Hey...something fishy is going on there, are you sure Kevin is working? He does not seem to have moved in any one of the pics. Could he be sleeping under there? lol
Glad to see you getting back on this truck, looks like you guys got a few more things crossed off the list, keep at it!
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 01-31-2011, 10:31 AM   #481
67cheby
67cheby
67cheby's Avatar
what electric fan set up are you running ?? and looking KILLER by the way
67cheby is offline   Reply With Quote
Old 01-31-2011, 12:54 PM   #482
jugernot
Life, Be In It.....
jugernot's Avatar
No luck on the lower Rad hose, I think I will have to buy one of those metal flexible ones. I just recently ordered and received my electric fans and fan shroud from GMCPauls Truck Parts www.gmcpauls.com.
I followed this how to link and assembily was easy. http://67-72chevytrucks.com/vboard/s...d.php?t=216128
But I have a question, which electric fan relay switch should I use?
There is the info on the fan set up. It a few pages back. I painted the top and sides of the Radiator to match the engine bay. The fan shroud in powder coated
Old 01-31-2011, 01:07 PM   #483
67cheby
67cheby
67cheby's Avatar
thanks for the info , looks like a nice set up
Old 02-08-2011, 06:33 PM   #484
jugernot
Life, Be In It.....
jugernot's Avatar
Today I lined up my Early Classic 700r4 transmission cross member and marked the spots where I need to drill holes.
I also test fitted the LFD's gas pedal adapters (http://67-72chevytrucks.com/vboard/s...d.php?t=371099 ) . I noticed that my 71 pedal assembly has a large cover plate/bracket. I'm not sure if I will need it. Looking at Kevin's thread about the adapter I believe I can cut it off at the top. Once I know for sure I will pull it off, through some paint on it, remove some sound dampener from the fire wall and drill a hole for the throttle cable.
Old 02-09-2011, 01:39 AM   #485
butternut1972
butternut1972's Avatar
Looks good, keep up the good work.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 02-09-2011, 02:01 AM   #486
LooseCannon
Looks Great! Are your hood hinges anodized?
LooseCannon is offline   Reply With Quote
Old 02-10-2011, 12:13 AM   #487
jugernot
Life, Be In It.....
jugernot's Avatar
No. They are painted the same color as the block. I had a set powder coated but the thickness of the coating prevented them from moving. So for that reason I could not use them.
Old 02-10-2011, 08:44 PM   #488
chevytruckluver
Man that stinks about not being able to use powdercoated hood hinges. I was thinking about getting mine done, I'm glad I could learn about this before hand. (thanks jugernot) I wonder if the powder coat guy would know that this would be an issue and warn a customer?
Trey
72 Short Step
Old 03-09-2011, 10:51 PM   #489
chevytruckluver
anything new going on?
Trey
72 Short Step
Old 03-10-2011, 12:09 AM   #490
Orangetonicclicc
Orangetonicclicc's Avatar
Wow I was in the process of powder coating my hood hinges. So that's not a good idea? Or did they just coat yours too much?
Orangetonicclicc is offline   Reply With Quote
Old 03-10-2011, 12:50 AM   #491
PipsC10
PipsC10's Avatar
just got my hinges back from the powder coater today and they work fine. I just pulled the springs off and had to break them loose again. Look and work great
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 03-21-2011, 11:51 PM   #492
jugernot
Life, Be In It.....
jugernot's Avatar
I received some parts this week and may try figure where I should put them on the frame. I'm thinking of putting the tanks under the cab and the compressors just behind the tanks. I'm not sure where I'm going to put the air valves, maybe on one of the cross members. I may ditch the plastic line and go with hard lines.
Old 03-22-2011, 05:20 PM   #493
jugernot
Life, Be In It.....
jugernot's Avatar
I had a few hours to spare, so I went into the garage and mocked up the tank and compressor on the driver’s side. I made some templates so the passenger side install should go a bit quicker. I'm thinking of splitting the Big Red valve unit into two pieces, one on each side of the frame near the tank and compressor. I plan on running a line connecting the two tanks together, just in case one of the compressors fails.
Old 03-22-2011, 05:24 PM   #494
67cheby
67cheby
67cheby's Avatar
very nice , very clean work
Old 03-23-2011, 10:54 AM   #495
6772owner
Gearhead
6772owner's Avatar
X2 Looks great!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 03-27-2011, 01:49 AM   #496
Rokcrln
Rokcrln's Avatar
Looking great JD. Just remember that drain is the lowest point and the top of your driveway is the tallest!
Kevin
LFD Inc.
Old 03-27-2011, 04:41 PM   #497
jugernot
Life, Be In It.....
jugernot's Avatar
Kevin
LFD Inc.
I HOPE that with eveything aired up It will clear. Maybe I could sell tickets and made a show out of the first ride up the driveway.
Hey Kevin, on another note, what fitting do you use when you run hard lines for the airbags? thanks
Old 03-27-2011, 09:21 PM   #498
Rokcrln
Rokcrln's Avatar
I use standard brake lines and the fittings are pipe on one side and flare on the other for the brake line.
Kevin
LFD Inc.
Old 04-25-2011, 07:33 PM   #499
jugernot
Life, Be In It.....
jugernot's Avatar
Well lately it seems like I've been fighting a uphill battle with Lemon Drop. So today when someone was drove by and made me an offer, well I could not refuse. The wife is happy that she can now park her car in the garage. At least until i find a vehicle that is complete and running order.
Old 04-25-2011, 07:38 PM   #500
hotrodhomi
hotrodhomi's Avatar
What do you plan on getting next? Was this for sale or did someone just see it from the road and ask about it?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
