Old 02-16-2010, 01:14 AM   #476
highperf4x4
Re: And so it begins................
As for the valves and seats, all of my heads have 3 angle valve jobs. I won't run heads without this mod and I won't install heads without a valve job unless they're pre-assembled performance heads.
highperf4x4 is offline   Reply With Quote
Old 02-16-2010, 01:34 AM   #477
'72customdeluxe
Originally Posted by highperf4x4 View Post
I can make out the list no problem. I don't know PaulD though. Are these his own numbers? Actually the 461 casting with 64cc chambers and 2.02 intake valves can flow up to 224cfm. With 441 you're looking at 76cc chambers. So, flow is not the only consideration unless you're blown or supercharged.
My question would be this. At what lift do the old heads pull the 202cfm and does he have a comparison chart for those heads by lift?
I am still dropping from a 72cc chamber to a 65cc chamber and increasing valve lift by way of rocker ratio although I can do that to either head.
The thing about the list spacing are his words, I know 461's will flow better than a smogger. I just mentioned that even a crap smog head is better. 40 cfm is no where near made up by the compression, just running a .04 quench height along with two eyebrow flat tops will get you over 9:1 with 76cc heads. The flow numbers on the 882's are from my chevy high performance small block build book. here they are.
I e
.050 39 34
.100 70 59
.200 125 109
.300 175 136
.400 204 143
.500 205 144
.600 206 145
The miniscule low lift flow advantage the tbi heads have over a smogger wouldn't win still. Also, by the time you get the tbi heads ready you could get reman vortecs for around 280 or so a pair on ebay
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 02-16-2010, 01:57 AM   #478
highperf4x4
What is he considering a modded SP? Is he referring to porting? Where does he list the valve size and seat angles? A 3 angle valve job improves flow rate. What I'd like to see is a side by side comparison of the TBI's and the "smoggers" with the same size valves, ported, and the 3 angle valve grind. That would be very helpful.
As for the ebay vortecs can you grab me a link for those? You would usually pay that much for EACH head especially if they already had the 3 angle grind. Shipping has to be considered too.
I can have the TBI's ready for much less than 280.00.
I appreciate the conversation by the way. In 20 years of building performance engines the one thing I've learned is that I haven't learned it all. I'd also like to add that for a 16yr old you've been doing some studying and my hats off to you for that and I will think over what you've presented here. Stay involved hombre!
Old 02-16-2010, 03:01 AM   #479
highperf4x4
Ok, before I hit the sack I'm gonna drop some final info on ya just for the sake of improving general knowledge.
TBI heads are considered low flow heads because they have "high swirl" intake runners provided by a "ramp" in the runner itself. They're not alot of good above 4000rpm. However, the high swirl runners make really good low end torque and improved "fuel economy". The 193 casting of the TBI head also has the 65cc combustion chambers making them pretty much the only ones worth my time. Especially since my truck is a '72 with a TH400 as the tall 1st gear needs all the low end torque and compression it can get with no stall converter and since it isn't an overdrive the additional fuel economy will be nice too.
As with most modifications you have to think application specific. I'm working out a performancne build for my 4x4, not this '72. This is just a temp engine swap that will put close to 400hp in my '72 for the time being. I could cetainly dump more money into the 355 and make lots of power but that would defeat the purpose of the temp engine. It's only going in the truck to give me time to build the 402bb that's in it now. I don't want to spend money on it. The TBI heads will make an improvement over my old heads for the '72 and I got them for free! The 383 I'm buidling for the 4x4, as stated before, will be a completely different setup with Vortec heads.
The discussion has been great though and feel free to provide any more info you dig up.
Old 02-16-2010, 09:50 AM   #480
JohnC
JohnC's Avatar
This has become a very informative thread. I don't know squat about all these different numbers, and such.
JohnC is offline   Reply With Quote
Old 02-16-2010, 10:09 AM   #481
0331grunt
Now what??
0331grunt's Avatar
No doubt!
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 02-16-2010, 10:38 AM   #482
highperf4x4
That's the reason for discussions like this. Education. Other than that, I would keep my secrets to me self.
Originally Posted by scotts62 View Post
As for the gears heck yeah but if your planning on hopping up the engine that much and want something to last just plan on spending about $500 on an Auburn Locker, you will like that bad boy
I'm going to talk to you some more about this.
No tbi is work truck material i would stick some vortec heads on it just mildly pocket port them, have them stud and guide plated put a 292 comp cam in it for 500/501 lift, do the 383 short block and find some mud puddles
But thats just me..
I have a fresh bored and decked block and stroker crank thats ground and ready to go just waiting for the 62
Your vortecs have already had some spring work then? Factory vortecs are only good for .470 lift because the retainer hits the seal plates under the valve springs that the factory modified to stop all oil from getting past the valveguides to meet stricter emission requirements.
Old 02-16-2010, 06:57 PM   #483
'72customdeluxe
I'll get you a link to that guy's thread about the tbi heads, but the ebay vortec were simple stock everything remans, i've seen them from 280-300 somthing. However a three angle valve job isn't going to make up for the 70 cfm (160->23x.xx) deficit from the tbi heads to the vortecs I wouldn't think. I was going to pick up some tbi heads cheap because those motors make decent power stock, but then I saw the flow numbers. Another option is patriot vortec heads. They're cheap for new performance heads but still expensive 600$. I won't list all the specs but here's a link https://www.patriot-performance.com/...&cat=76&page=1
Old 02-16-2010, 09:43 PM   #484
highperf4x4
Yeah I've seen the patriot heads online. I'm a little skeptical about a company that can sell aluminum cylinder heads as cheap as they do. I'm not sure where they're cutting corners as I've never seen one of their heads up close.
Remember, the advantage of a TBI head is different than what people perceive. It's high compression and makes really good low end power for trucks and the high swirl runners make fuel burn alot more efficient for better economy. They're not a drag racing head though that's for sure. Fortunately GM was able to continue the "swirl" effect in the vortecs they simply changed the design and increased the size of the runners so it doesn't impede flow at high rpm.
Old 02-16-2010, 09:57 PM   #485
'72customdeluxe
Yep, they'll make torque for sure but the point I was argueing is that they'll make nowhere close to 400 horsepower
Old 02-16-2010, 10:52 PM   #486
highperf4x4
Ok, I smell a challenge. Looks like I'll need a dyno sheet. If I win, you'll have to come up here and rub my feet!!
Alright, back to business. I picked up the goodies from the montster today and I've run all the numbers just for kicks.
Block (I'll need new main caps) - 10243880
350...95-00...4bolt...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
Heads - 10239906
96-up...350.........."Vortec 5700", "L31", 64cc chamber, 170cc intake port, 1.94"/1.5" valves
Crank - 3951529B
400.......cast....large journal....3.75" stroke
The crank is stamped 383 and 10/10 without visible wear so it has plenty of life left in it. But, it's an older 2 piece rear seal and it's cast so I'll probably just go with a forged crank. He also included the rods which look good too but they're also stock (and someone has mixed the caps up) and I'd like to use H-beam. Of course, then I'd want to punch the valves out to 2.02. Oh man, it's never enough!!!!!
Old 02-16-2010, 11:48 PM   #487
scotts62
One day...
scotts62's Avatar
Your vortecs have already had some spring work then? Factory vortecs are only good for .470 lift because the retainer hits the seal plates under the valve springs that the factory modified to stop all oil from getting past the valve guides to meet stricter emission requirements.
Yeah i hear ya on the secrets, i worked at a automotive machine shop for almost 3 yrs now i dont know everything but know some tricks
Thats all i did was bore blocks, valve jobs, drill for guides, machine for bigger springs, machine heads for studs and guide plates. You would cry if you knew what i paid for mu new engine over haul
I dont have any vortec heads, The TBI's i just did are just built plano jano. I have a set of double hump cheater heads that have the accessory holes for alternator brackets that im going to bore for 2.02 1.60 valves, they are already machined for studs and guide plates so it will be a quick upgrade for the most part.
Scott
93 crew cab build
Project 62
Old 02-16-2010, 11:48 PM   #488
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
why would you need new main caps?
they make an adapter for the one piece block to drop in a two piece crank
http://www.gmpartsdirect.com/perform...CATID=883.html
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 02-16-2010, 11:52 PM   #489
scotts62
One day...
scotts62's Avatar
I bought one of those adapters one time to use a crank that i had laying around hell it was over a hundred bucks and i could have exchanged a crank for 75 oh well i take the long road sometimes just for different scenery
Scott
93 crew cab build
Project 62
Old 02-16-2010, 11:56 PM   #490
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
good god i didnt know it was that high
you cant get a 383 crank for 75 bucks can you?
Gage
Old 02-17-2010, 12:16 AM   #491
highperf4x4
Boring for some 2.02 valves huh? You and I need to get together for some coffee soon brother. I've got things to talk about!
Because some of the caps were missing young grasshopper. See you made assumptions!
No but he was likely talking about 350 cranks and his connections.
Old 02-17-2010, 12:20 AM   #492
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i didnt make assumptions
damn thats gonna cost you for those main caps
line boring and honing isnt cheap
i looked into it because i wanted splayed caps (i dont anymore!!!!)
it would probably be cheaper to get another block
Gage
Old 02-17-2010, 12:27 AM   #493
highperf4x4
Yes you did, you assumed I was referring to the rear seal issue young grasshopper.
I usually align bore anyway. Don't you? And straighten the crank?
I don't hone anything though. I bore the cylinders if that's what you meant.
Old 02-17-2010, 12:30 AM   #494
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
no i just slapped mine together
i needed something to get me by for a while
how much do you want for that crank i need it
Gage
Old 02-17-2010, 12:40 AM   #495
highperf4x4
I'm not entirely sure I'm not going to use it. But, I will let you know if I don't.
Old 02-17-2010, 12:43 AM   #496
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
alright
i want to make some torque
what rods are you planing on using
Gage
Old 02-17-2010, 12:49 AM   #497
highperf4x4
He gave me some stock rods with the crank and if I use the crank I'll use the rods but if I get a steel crank, I'll get h-beam rods
Old 02-17-2010, 08:40 AM   #498
scotts62
One day...
scotts62's Avatar
No but to grind a 400 crank to fit in a 350 is around $150 which still isnt too bad.
Scott
93 crew cab build
Project 62
Old 02-17-2010, 10:28 AM   #499
JohnC
JohnC's Avatar
Glad to hear you got the stuff man. The ole red beast is really going to scream now!
Old 02-17-2010, 11:09 AM   #500
highperf4x4
Fortunately this crank is stamped "383" right beside the 10/10 so it's been done already
yes................ yes it is.
