Old 11-19-2018, 09:12 PM   #476
tinydb84
tinydb84's Avatar
Re: Used Parts Build
Finished welding up my down(up) pipe.
Have a small about of sugaring on the inside. Thought my purge was good but must of had some air in there.
Made another exhaust pipe to run off of my waste gate. I was thinking of routing it back into the down pipe but since this one is just for show I thought two would be cooler. I am going to brace them together next.
Here is where it is it now. I need to rub them both down with a scotch brite pad so the finish matches.
David
Instagram: myfabguy
Old 11-19-2018, 11:14 PM   #477
Joe Pass
Joe Pass's Avatar
Crazy Sh##t going on..lol
Joe Pass is offline   Reply With Quote
Old 02-22-2019, 03:29 AM   #478
Ulf
It looks great.
Ulf is offline   Reply With Quote
Old 02-22-2019, 02:31 PM   #479
808_67C10
808_67C10's Avatar
How did I miss this build until now... holy crap, cats and dogs living together! I love it! That pic of the front of your truck with the drop and turbo set up is my new screen saver! Can't wait to see more!!!!
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 02-26-2019, 12:35 AM   #480
tinydb84
tinydb84's Avatar
Thanks guys. I haven't done much recently. The usual excuses (saving money, no time, getting burned out, blah, blah) but I started getting parts for it. Got a TBSS intake, throttle body, radiator, got the front clip back on but didn't get a pic of that yet.
Here it is right before I put the front clip back on. I hope to drive it this summer...
David
Instagram: myfabguy
Old 03-04-2019, 10:20 PM   #481
tinydb84
tinydb84's Avatar
Got my radiator in. Front clip on. Started running my cold side piping.
David
Instagram: myfabguy
Old 03-05-2019, 12:19 PM   #482
daddyjeep
daddyjeep's Avatar
Glad your back at it... summer is coming
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-25-2019, 01:28 AM   #483
tinydb84
tinydb84's Avatar
Got my bov flange welded on. Crappy casting that fought me the whole way.
IAT fitting on.
Extended my intercooler.
Cut my core support and fabbed up a mount for the top side.
David
Instagram: myfabguy
Old 04-01-2019, 10:07 PM   #484
tinydb84
tinydb84's Avatar
Finished my cold side
Used my harbor freight beadroller to add flanges to my tubes. Here was a practice piece.
David
Instagram: myfabguy
Old 04-02-2019, 12:17 PM   #485
daddyjeep
daddyjeep's Avatar
I really need to move a bead roller up on my list of new tools. The last time I needed a lip like that I welded bead around the tube.
04 1500 crew cab
Old 04-02-2019, 03:14 PM   #486
tinydb84
tinydb84's Avatar
Honestly that is the only time I have used it. My back up plan was to weld a bead. I might have to do that for the throttle body if it doesn't hold.
David
Instagram: myfabguy
Old 04-03-2019, 10:57 AM   #487
808_67C10
808_67C10's Avatar
I have to admit, I cant wait to see youtube video of this truck on the road. Please tell me that is in the plans....
Old 05-02-2019, 07:23 PM   #488
tinydb84
tinydb84's Avatar
My buddy does film and special effects editing for a living. I am sure I can talk him into something.
Got a bit of work done.
Had to make room for my brakes but the new booster didn't have a bracket. So I removed the old one and made it work.
Installed a Corvette disc/disc master cylinder
Need to make a new connection to the rod next.
David
Instagram: myfabguy
Old 05-15-2019, 06:29 PM   #489
tinydb84
tinydb84's Avatar
Had to modify the rod a bit to fit my set up:
Welded brackets onto a cheap aluminum overflow:
Mounted it but need to adjust my air cleaner a bit:
Its interesting buying parts and actually installing them. Kinda scary.
David
Instagram: myfabguy
Old 05-28-2019, 04:26 PM   #490
tinydb84
tinydb84's Avatar
Got a bunch of little things done to the truck. None were really picture worthy. Then made a hidden panel that will go behind the tailgate just in case I get a dead battery or my compressors fail.
Then made a mounting plate out of stainless steel for my vacuum block and fuel pressure regulator. I welded all the bolts on for easy install.
David
Instagram: myfabguy
Old 06-17-2019, 02:23 PM   #491
tinydb84
tinydb84's Avatar
Got my fuel lines ran (they look terrible...)
Made a vent for my rearend
Made a lower radiator hose set up
Started on the upper hose but didn't order enough fittings to finish it
David
Instagram: myfabguy
Old 06-19-2019, 09:18 PM   #492
808_67C10
808_67C10's Avatar
yes! pics! ohhh ahhh.
Old 06-20-2019, 01:00 PM   #493
daddyjeep
daddyjeep's Avatar
I don't think anyone is going to lay on the ground under your truck and give you **** because your fuel lines aren't straight enough. Do they move fuel? That's all they need to do.
04 1500 crew cab
Old 06-20-2019, 01:52 PM   #494
skyphix
Haha, considering the quality of everything else, who cares about some wavy fuel lines! that hidden box idea is great. A little envious at your ability to do that stuff!
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 07-08-2019, 01:05 PM   #495
tinydb84
tinydb84's Avatar
I try not to post unless I have something to show for it
My goal is to be so low they cant see them even when it is aired up!
Thank you. I mostly just "borrow" ideas from the internet and tweak them a little.
David
Instagram: myfabguy
Old 07-08-2019, 01:11 PM   #496
tinydb84
tinydb84's Avatar
Finally some pictures worth showing.
Here is a little tool I made to do my flange on my radiator lines since they wont fit in my bead roller.
Got some crimper/cutters off Amazon
Cut off the top, ground down this spot, and radius the edge of the inside
Then clamp away!
David
Instagram: myfabguy
Old 07-08-2019, 01:14 PM   #497
tinydb84
tinydb84's Avatar
Started my fuel filler neck
Made a tab
Second tab
Welded the cap to the tube
Almost there
Adding the vent line
David
Instagram: myfabguy
Old 07-15-2019, 07:31 PM   #498
tinydb84
tinydb84's Avatar
Finished up my filler tube
Started a little panel for relays for my compressors and fuel pump
Lastly made a bracket for my throttle cable
I also installed a shifter rod and throttle cable but didn't bother with pictures of those.
David
Instagram: myfabguy
Old 07-15-2019, 10:09 PM   #499
Joe Pass
Joe Pass's Avatar
This is getting crazy.....lol...nice work
Old 07-16-2019, 09:05 AM   #500
TrybalRage
Me reading this thread....
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
TrybalRage is offline   Reply With Quote
