04-25-2022, 08:53 PM | #5176 |
Re: What did you do with your truck today, Part 3
Yep, most people aren't going to see what I did till it hits them it's thinner.
The hood will look stock, open or closed. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
04-26-2022, 03:19 AM | #5177 |
Junior Member
My 56 getting the NAPCO front axle and t-case finally
Posted via Mobile Device |
04-26-2022, 05:04 PM | #5178 |
04-26-2022, 07:17 PM | #5179 |
I even got an NOS moulding.
Brian
04-27-2022, 09:19 AM | #5180 |
When I saw the outside lift I thought, "Must be Texas". Sure enough (although I know of one here in Cincinnati too).
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
04-27-2022, 07:47 PM | #5181 |
Worked on saving the old bent and rusty running boards. But also, during the 'my arms are on fire from all the hammering', saved this from the ugliness of it's previous life.
Perfect for the Rust-Mod.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 Last edited by fauXGT; 04-27-2022 at 08:48 PM. Reason: No gratuities hairy leg necessary |
04-27-2022, 10:54 PM | #5182 | |
Brian
04-27-2022, 11:32 PM | #5183 |
04-28-2022, 12:27 AM | #5184 |
Yep.
Cool seeing the original paint underneath it. 70 years of history is amazing. Going to pressure test the core tomorrow to see if salvagable and start prepping/painting the housing.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
04-28-2022, 12:44 AM | #5185 |
Plus, saving of what you can of the original should always be the goal(apologies to the new parts sellers).lol
04-28-2022, 07:43 AM | #5186 |
When I bought my 53 3100 in SoCal it had no heater. When I moved to Indiana I bought one at a junkyard. I got the same feeling of satisfaction When I restored it. That was over 30 years ago and the OEM core is still fine.
04-28-2022, 08:31 AM | #5187 |
Careful with the pressure test, they ran a lower pressure than newer vehicles.
04-28-2022, 11:47 AM | #5188 |
6-8 psi was what I'm going for on the test. I am putting in a 350, so hopefully it will handle up to 10-12 psi at max.
04-30-2022, 10:57 PM | #5189 |
It rained all week and it's supposed to continue through the weekend. I just keep cleaning and hoping for dryer weather. At least all the road salt is being washed away..
05-01-2022, 10:04 AM | #5190 |
Beautiful...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-01-2022, 06:38 PM | #5191 |
we can only hope, 2 seasons here in MI,
it's sort of like the kids game of green light, red light no salt, salt.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-01-2022, 11:31 PM | #5192 |
Still working on replacing the old/rusted running board mounts onto the old/rusted running boards.
At least the rusty parts will take longer to fall off.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 Last edited by Rickysnickers; 05-02-2022 at 09:57 AM. |
05-17-2022, 09:27 AM | #5193 |
It finally got nice here so I got back on the donor frame rails. I did the first one last fall and am doing a few things differently on the second one. I used the mag drill to round out the holes a little larger and get a uniform size. Now I only have 4 sizes. I don't have a cutter larger than 1" so a couple will have to be custom made. I'm hoping a better fit will mean less grinding. I TIG these so I don't get the hard MIG weld because there will be cutting, drilling and tapping and I don't want to drill on the harder MIG weld. If I end up half way on a weld it's a hassle. There are 149 holes in each frame rail to weld up. Thank you for your time.
05-17-2022, 10:07 AM | #5194 |
Nice drill setup you have there. Car guys have to be crazy doing all that work on parts that don't even show. It's a sickness, an expensive sickness, LOL.
05-17-2022, 05:57 PM | #5195 |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
05-17-2022, 06:48 PM | #5196 |
Soon to be a rich mans game.
05-17-2022, 08:01 PM | #5197 |
05-22-2022, 06:50 PM | #5198 |
I finished making the 149 little plugs for my donor frame rail. Now I just need to TIG them in. I realize that I could probably could have bought these cheap from someone. I could also take the truck to someone and tell them to call me when it's done. I think mine are better and cleaner. I like making stuff. I have a lot of mild steel rod and I didn't have to buy anything or wait on anybody. Thank you for your time.
06-02-2022, 07:58 PM | #5199 |
I started TIGing up the holes in the 2nd donor frame rail.
06-03-2022, 08:22 PM | #5200 |
spilled some oil on my primered hood. now I have to figure out how to clean up the mess.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
