#501 |
Re: 72 k20 project
Getting the picture in the morning! But I already have a quote and think my name is on it already haha. Before I could run twins tho I need to have a rebuilt engine and dont have that money and cant justify spending all that money right now and have this project take two more years.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#502 |
Re: 72 k20 project
Nonsense!
#503 |
Re: 72 k20 project
pretty decent haul for the old chev this week
the rebuild for the front diff came in. OEM spicer stuff. ring and pinion, carrier and pinion bearings, shims and ring gear bolts. oh, and a gasket. 3.54:1s to match the rears. ![]() this arrived so i could show Matt. Thanks again Ryan Hx55 for my compound set. ![]() and these came from ballistic. the tube bungs and the jambs came from ruffstuff. i ordered 1.25"x1" rod ends, misalignments and adapters from ruffstuff also, but they wont be here till next week. they had an inventory issue with the jamb nuts and didnt send them. ![]() ![]() |
#504 |
Re: 72 k20 project
I swear you and dieselwrencher are against me....
Looks like a nice pile of parts you got there. Yup, I think this proves that you can dieselwrencher are trying to get me to spend more money...
#505 |
Re: 72 k20 project
Against you! we are just trying to help you have the baddest truck possible!
#506 |
Re: 72 k20 project
Well apparently it's working, I should have something showing up sometime this week...
![]() Posted via Mobile Device
#507 |
Re: 72 k20 project
Do go on! what did you get? how big and bad?
#508 |
Re: 72 k20 project
You will have to wait haha, Ryan told me some about it but I'm a turbo noob.
#509 |
Re: 72 k20 project
i guess ill have to go to the source
#510 |
Re: 72 k20 project
That's cheating haha
#511 |
Re: 72 k20 project
#512 |
Junk Yartist
Re: 72 k20 project
That's purdy.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#513 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 72 k20 project
Impressed! Are you a sculptor or a mechanic....I can't tell!! Strong work either way but please don't add a fountain to the bed....
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#514 |
Re: 72 k20 project
That looks awesome man! Nice work as usual.
#515 |
![]() Join Date: Jul 2012
Re: 72 k20 project
You gonna mount the remote filter in the cab where you can look at it all the time? It's a shame to put some of this stuff where nobody can see it!
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. Last edited by Mustard72; 04-13-2013 at 12:58 PM. Reason: correct punctuation... |
#516 | |
Re: 72 k20 project
thanks!
thank you sir i hadnt though of an in cab mount, i think it may do a little rough for the carpet. not sure on the location yet. id like to mount it next to the fuel filters but they will be on the wrong side. i think it may end up up front behind the bumper, but i am skeptical of that because i dont want it in the way of flying carcasses should i ever encounter the neighbors cat or a wayward porcupine. |
#517 |
Re: 72 k20 project
#518 |
Re: 72 k20 project
GET BUSY!
#519 |
Re: 72 k20 project
Man those look beefy . I bet there at leats $ 15 each
![]() Have you ever built any trac bars before ? Im looken to build a set for my 56. Lookin for some pics so I know what I Should be trying to do .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#520 | |
Re: 72 k20 project
as you wish here are the permanent links panhard just kisses the ball in the stowed position. ![]() gonna have to clip the speed sensor "cage" but it should work just fine. ![]() ![]() ![]() ![]() |
#521 |
Re: 72 k20 project
That looks really good man! The fab skills are awesome!
#522 |
Re: 72 k20 project
Oh my . That is some nice work you have done there. Ive seen lots of trac bars that are just the bar with a heim mounted on the lower portion of the axle tube. Then the upper heim mounted to the frame closest to another vital pivot point . Ie center of u joint if using a hanger bearing, or even with u joint at the transfercase if 1 peice shaft.
Wont this work? I think the truck is kinda squirely under accelleration and decel becouse my current setup is the orriginal 56 1/2 ton springs with the 4inch dodge blocks on them. Thats a lot of leveredge and not too much spring pressure . I hope to get some new springs under all 4 corners later this summer . But for now I need to make it feel a little more comfey when you get on it and grab a gear. ! I was hoping some cheepy bars would bandaid this. I allready have the heims.
#523 |
Re: 72 k20 project
That style will work, but will not do as much as if it is triangulated. it will still be able to twist the spring but just do it on the axis of the rod instead. it will certainly help but if the springs are soft it may still twist them a little under hard accel with good traction. |
#524 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 k20 project
Great work Ryan! Just ditch the speed sensor and put a plug in it. Then you will have a little room there.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#525 | |
Re: 72 k20 project
