Old 09-06-2013, 12:38 PM   #501
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Originally Posted by SeTx67 View Post
Moving right along. Are you going to fab some brackets to hold the ls1 radiator in place?
Yeah, I haven't really looked at it yet to figure out how I wanna do it though.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-06-2013, 04:14 PM   #502
steelhorse
steelhorse's Avatar
Nice.
steelhorse is offline   Reply With Quote
Old 09-06-2013, 07:26 PM   #503
gdavis
gdavis's Avatar
your are getting close there man. looks good.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 09-07-2013, 05:29 PM   #504
Xeen
Xeen's Avatar
Hey all;
I just purchased a universal Bolt in Battery tray from Speedy Bill.
http://www.speedwaymotors.com/Bolt-I...-Box,5334.html
I also ordered a -6AN to -6AN coupler and tube nuts so I can section my return fuel line because right now it's all one piece from front to back which isn't easy to work with if there is a problem.
Old 09-09-2013, 11:13 PM   #505
El Campo
El Campo's Avatar
Hey Brian what kind of sway bar is that that you have in the front? I have one very similar and without thinking about it I cut one coil off of my front springs to get a little lower and now I don't know if the sway bar will work, any thoughts? You are getting close!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-09-2013, 11:19 PM   #506
Xeen
Xeen's Avatar
It's a factory GM 1/2 ton sway bar.
I have two inch lowering springs and it worked fine.
Old 09-10-2013, 11:52 PM   #507
Xeen
Xeen's Avatar
The battery tray was delivered today.
The construction is solid and it is heavy duty.
Old 09-11-2013, 12:01 AM   #508
67_C-30
I have a radical idea!
67_C-30's Avatar
That bad boy should be fun with that LS!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-11-2013, 12:15 AM   #509
Xeen
Xeen's Avatar
Oh yeah, I can't wait to take it out for the first drive.
Old 09-11-2013, 12:29 PM   #510
gdavis
gdavis's Avatar
Good I am glad it came in and now you can get the battery in and start wiring the cab. You put it off long enough.
Check out Patches
Old 09-11-2013, 01:16 PM   #511
SeTx67
SeTx67's Avatar
I'd like to see pics of the battery tray installed. Looks nice
SeTx67 is offline   Reply With Quote
Old 09-11-2013, 01:22 PM   #512
Xeen
Xeen's Avatar
Fortunately according to the 10 day forecast today is the last hot day for atleast the next 10 days, I'm supposed to have beautiful weather high 70's to low 80's so I should be able to get a lot of work done on the truck.
Old 09-11-2013, 01:41 PM   #513
SeTx67
SeTx67's Avatar
We should see weather like that in late October lol
Old 09-13-2013, 12:17 PM   #514
Xeen
Xeen's Avatar
Hey all;
Today I went and exchanged the LH front brake caliper because the manufacture that rebuilt it used a help coil where the bleed valve is and when I tried to release the bleed valve the help coil unscrewed instead.
Here is the new one having recieved a fresh coat of high temp paint.
Old 09-13-2013, 01:22 PM   #515
El Campo
El Campo's Avatar
Hate it when that happens! Heli coils can be amazing life savers IF DONE RIGHT but it sounds like they didn't do it that way. Glad u got another without too much hassle.
Hook em Horns!!!
Old 09-13-2013, 02:50 PM   #516
Xeen
Xeen's Avatar
Hey all;
I finished the caliper swap.
Old 09-13-2013, 04:17 PM   #517
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!
mcbassin is offline   Reply With Quote
Old 09-13-2013, 04:24 PM   #518
gdavis
gdavis's Avatar
I have used the heli coils before on head bolts and never had one come out. But at least it was where you could take it back and get a replacement. Keep working and looking forward.
Check out Patches
Old 09-13-2013, 07:01 PM   #519
Xeen
Xeen's Avatar
Hey all;
I got tired of all the black in the engine compartment so I decided to paint the battery tray silver.
I don't know if I will keep it this color or not but I wanted to see what it would look like.
I used a black primer then sprayed the silver on.
Old 09-14-2013, 07:11 PM   #520
gdavis
gdavis's Avatar
I want to see it in the truck. Not hanging on a set of wires. It look good from here.
Check out Patches
Old 09-14-2013, 07:41 PM   #521
El Campo
El Campo's Avatar
Amen to what he said!
Hook em Horns!!!
Old 09-14-2013, 07:55 PM   #522
Xeen
Xeen's Avatar
Old 09-14-2013, 08:09 PM   #523
Xeen
Xeen's Avatar
Hey all;
Today I put together my own HD fuel pump wiring kit per Aeromotives specifications, and started installation, I didn't get completely done but I will finish it up tomorrow.
I got everything I needed at O'reilly including the 10ga wire they sell it by the foot.
The kit consists of the following items.
1) 1x 30amp, 12vdc automotive relay.
2) 1x 30amp, 12vdc circuit breaker.
3) 2x Blue Female Blade Connector.
4) 2x Yellow Female Blade Connector.
5) 5x Yellow Ring Connector for #10 Stud.
6) 1x Yellow Ring Connector for 3/8” Stud.
7) 1x 25ft 10ga. Red Wire.
8) 1x 3ft 10ga. Black Wire.
9) 6x 6 inch cable ties.
*Connectors required will vary per application.
Old 09-14-2013, 08:55 PM   #524
68basket
subscribing to see how your battery box install goes. I am in about the same position on my ls swap and trying to find the easiest way to get the battery to the drivers side. build looks awesome!!
68basket is offline   Reply With Quote
Old 09-14-2013, 09:39 PM   #525
El Campo
El Campo's Avatar
Very interested to see your fuel pump wiring when u are done!
Hook em Horns!!!
1968, chevrolet, restomod, stepside, swb
