Old 07-31-2016, 03:04 PM   #501
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
Thanks Don. Still plugging away at it.
Welded the bedsides to the rear cross sill this morning, then stripped the passenger side to bare metal. Body work to commence next weekend.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 08-06-2016, 02:05 PM   #502
racecougar
racecougar's Avatar
One last look at the passenger side in bare metal before we started filling and blocking today.
Old 08-07-2016, 06:24 PM   #503
racecougar
racecougar's Avatar
Artsy progress shot.
Old 08-13-2016, 07:03 PM   #504
racecougar
racecougar's Avatar
We finished blocking out the filler, remasked it, then shot the passenger side with red oxide today.
Old 08-14-2016, 01:04 PM   #505
racecougar
racecougar's Avatar
We blocked it out and shot it again this morning. It's nice to be able to step back and see the whole panel in one color.
Old 08-20-2016, 02:33 PM   #506
racecougar
racecougar's Avatar
Spun the bed around and got started on the drivers side today.
Old 08-20-2016, 04:08 PM   #507
66ChevyMax
66ChevyMax's Avatar
Looking great, I like that color
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 08-21-2016, 04:34 PM   #508
racecougar
racecougar's Avatar
Thanks. That's just the red oxide primer in the photo above. The final coat is matte black.
It might not look like anything changed, but I assure you this is the result of another day spent filling and blocking. Getting there...
A pic I meant to post yesterday. I wish this site would allow the poster to edit his/her posts after the fact.
Old 08-27-2016, 07:28 PM   #509
racecougar
racecougar's Avatar
We finished up the bodywork on the driverside this morning, then laid down the first coat of red oxide.
Old 08-28-2016, 03:53 PM   #510
racecougar
racecougar's Avatar
"So Rod, what do you do on the weekends?"
"Me? Oh, I sand stuff."
Old 09-03-2016, 01:23 PM   #511
racecougar
racecougar's Avatar
Day 270 & Rod Sr.'s birthday: Laid down some high build on both bedsides.
Old 09-04-2016, 02:03 PM   #512
racecougar
racecougar's Avatar
A suitcase full of wiring has arrived. It's the AAW 500560 kit. If this was a stock build, this harness would pretty much drop right in. Of course we welded up the wiring pass-throughs in the firewall to hide them elsewhere, we're going to run a LS/auto drivetrain, and adding a bunch of other stuff, all of which requires more time/effort.
After wrapping up a few items on the interior this morning, we located and drilled the new hole for the headlight wiring to pass through the firewall (behind the fuse panel where the wiring will be hidden in the inner fender), then mounted the new fuse panel and main harness.
Old 09-05-2016, 01:33 PM   #513
racecougar
racecougar's Avatar
Dad blocked out the bed today while I kept plugging away on the wiring.
Old 09-17-2016, 09:17 PM   #514
racecougar
racecougar's Avatar
Photo collage of today's work. We yanked the seats so that I was better able to cram myself up under the dash. We warmed up the driverside kickpanel vent handle and persuaded it into a lower position, as it was interfering with the new fuse panel (known issue with this fuse panel/kit). Dad finished blocking out the bed, and I spent the day running wires, installing courtesy lamps, and making a list of all the tools/supplies that I forgot to bring over to the shop from my house.
Old 09-18-2016, 05:59 PM   #515
racecougar
racecougar's Avatar
The wiring is getting tidier. I'm waiting on a few parts (a missing connector from AAW, a new neutral safety switch, and some split loom) before I can proceed any further. The reworked driverside kickpanel vent handle now clears the fuse panel (before/after shot at the bottom of this photo). We also painted the instrument cluster bezel and shot the next coat of high build on the bed today. Busy day!
Old 09-24-2016, 06:47 PM   #516
racecougar
racecougar's Avatar
It's a repeat of last weekend: Dad blocked the bed, I worked on the wiring. Almost done under the dash...until more components arrive.
Old 09-25-2016, 05:40 PM   #517
racecougar
racecougar's Avatar
Other than the bed-mounted taillight harness, everything that currently can be wired, is wired. Even the fuel pump, fuel sending unit, and VSS circuits have been run to their approximate locations.
That's a 4-channel 600W amp sitting in the middle of the floor (it'll hide under the middle seat. I bought that amp from a friend about 17 years ago, used it in daily drivers until 2010, and stored it since. All Dad will need to buy is a head unit and a pair of rear speakers, and he'll have tunes.
Old 10-01-2016, 11:06 AM   #518
racecougar
racecougar's Avatar
We prepped the bed last night, then rolled the truck out this morning and shot the first coat.
Old 10-02-2016, 10:09 AM   #519
CURSED GEARS
Looks good. I'm about to shoot primer on everything. Can't wait to get to your stage!
CURSED GEARS is offline   Reply With Quote
Old 10-02-2016, 08:41 PM   #520
racecougar
racecougar's Avatar
Thanks. We're excited to get the bed back on the truck and pull it outside so we can step back and get a look at it.
It'll get striped next weekend, then it's time to put it back on the truck.
Old 10-07-2016, 08:07 PM   #521
racecougar
racecougar's Avatar
An hour of prep for two minutes of gun time.
Old 10-08-2016, 04:37 PM   #522
racecougar
racecougar's Avatar
Shot the second coat of white on the bed, painted the taillight housings, filled the diff with gear lube, installed the windshield decal, and gave the truck a quick bath today.
Old 10-09-2016, 02:52 PM   #523
racecougar
racecougar's Avatar
The bed is on the frame! The bed and cab need to be lined up and fully bolted down...we'll work on that next weekend. The big deal is that wheelwell mods worked out very well.
Timelapse video of the install today.
Old 10-09-2016, 05:15 PM   #524
bj383ss
bj383ss's Avatar
Very cool. Love the video.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 10-11-2016, 10:45 AM   #525
crazycrew
Holy hell. Quite the transformation! You guys did amazing work. Wish I had even a fraction of those skills
Brooks -- South Louisiana
2004 Tahoe, DD
Currently on the prowl for that right C10 project
https://www.facebook.com/brooks.landry.1
IG : brolandry
crazycrew is offline   Reply With Quote
