Old 07-07-2021, 07:45 AM   #501
MT65
Re: New 64 Stepper Project
That is perfect, now drive the wheels off it and enjoy it…..
MT65 is offline   Reply With Quote
Old 07-07-2021, 08:17 AM   #502
66C10LB
Having a bit of sidewall height looks great. It gives the truck a hint of historical originality.
66C10LB is offline   Reply With Quote
Old 07-07-2021, 10:27 AM   #503
88Stanger
88Stanger's Avatar
Very classy and nice, i like it! Beautful truck
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 07-07-2021, 01:59 PM   #504
aggie91
I'm just glad to be here!
aggie91's Avatar
Truck looks amazing, Well Done Master Chief!
Hope to see it out someday. Do you ever go up to the Hill Country Swap meet in Fredericksburg? It is the weekend of July 23-25th this year. I plan on having a spot to sell some stuff and possibly buy other stuff...LOL.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-07-2021, 03:27 PM   #505
The Rocknrod
Moderator
The Rocknrod's Avatar
Thank you, did it more for driving. But I like that thought.
Thank you.
Thanks for that. No to tell you the truth I have never been to Fredericksburg.
Old 07-08-2021, 12:40 PM   #506
The Rocknrod
Moderator
I took it out on Wortham bend today, it's a 65MPH road. Drove up and down to get a feel. Need an alignment, that happens Monday AM at China Spring Collision. The trans shifts just like advertised by Lonie at Extreme Transmissions, easy when your easy, put your foot in it and it's around 3-3500 RPM nice and firm Couldn't ask for more.
Old 07-09-2021, 06:27 AM   #507
The Rocknrod
Moderator
I tried to do a scrub line check on the rear so I laid some tape on the cement ran the rear tire over the end and pulled it over to the other side rim tight to see. Darn tape twisted but it's clear as far as a scrub line. I know the fronts clear as I had that moment previously.
Old 07-09-2021, 08:29 AM   #508
joesscamaro
I’m missing something. What is the purpose of the scrub line test?
joesscamaro is offline   Reply With Quote
Old 07-09-2021, 09:34 AM   #509
SCOTI
SCOTI's Avatar
To know if in the event of a tire failure there is no anchor point below the lip of the wheel that can make contact w/the roads surface.
Certain methods of lowering alter the scrub-line so when making changes you need to be aware.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-09-2021, 09:34 AM   #510
The Rocknrod
Moderator
If you loose a tire on a wheel - to see if your framework or suspension will not hit the pavement.
https://www.steffysgarage.com/downlo...line-chart.pdf
Old 07-09-2021, 01:07 PM   #511
350TacoZilla
Having lost a wheel before I can get the idea here, problem is it looks like your ok if the tire goes flat and peels off rim but if studs fail (or someone steals your lug nuts like what happened to me) then the shock mount\U-bolt is going to become your skidplate.
350TacoZilla is offline   Reply With Quote
Old 07-09-2021, 01:35 PM   #512
SCOTI
SCOTI's Avatar
You can plan for only so much.
One doesn't expect to lose the entire assembly & I don't think you can prevent something else under the chassis from becoming 'next in line' unless you build it for that failure.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-09-2021, 03:22 PM   #513
The Rocknrod
Moderator
Anyway, that's what a scrubline is and I'm looking good in that regard. So I'm happy about that.
Old 07-11-2021, 02:30 PM   #514
lunatic1968
Good information, thanks.
lunatic1968 is offline   Reply With Quote
Old 07-12-2021, 01:06 AM   #515
350TacoZilla
For sure man, I dont think many people will ever have a situation where the whole assembly comes off.
Old 07-12-2021, 05:33 AM   #516
The Rocknrod
Moderator
Since you could see the long ends of the U-Bolts through my wheels , I trimmed them down with a 4.5" cutting wheel and painted the ends. Looks much better now.
Old 07-12-2021, 06:03 PM   #517
The Rocknrod
Moderator
So here is a pic from the rear to the front under the truck. Wonder if they make shock mounts that sit higher? Maybe I could swap them, but then I'd have to trim them. Probably just overthinking it in that regard.
Old 07-12-2021, 08:31 PM   #518
SCOTI
SCOTI's Avatar
Originally they were flipped vs. how they are oriented now. Thats one of the first low buck mods (flip the lowers upside-down & re-locating the upper mount position).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-12-2021, 08:47 PM   #519
roll_the_dice
roll_the_dice's Avatar
I just caught up on your thread...dude! Love your truck! Great job!
roll_the_dice is offline   Reply With Quote
Old 07-13-2021, 09:25 AM   #520
The Rocknrod
Moderator
Theyre POL mounts, I had the originals when I got the truck.
Thank you.
Old 07-13-2021, 09:49 AM   #521
SCOTI
SCOTI's Avatar
Thank you.
I assumed they were aftermarket based off of their shape. The pre-67 lower brackets are beefier than the 67-72 brackets. That being said, you make some that keep the bottom of the shock flush w/the bottom of the T/A hardware if you're concerned.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-14-2021, 11:29 AM   #522
The Rocknrod
Moderator
Getting the alignment at China Spring Collision this morning.
Old 07-19-2021, 03:15 PM   #523
The Rocknrod
Moderator
Did the front scrub line also.
Old 07-21-2021, 06:05 PM   #524
The Rocknrod
Moderator
I just checked and it's been six years since I started this build. The pinstriper came by today to put the cherry on the cake.
Old 07-22-2021, 07:53 AM   #525
The Rocknrod
Moderator
Some of the finished product, didn't want to overdo it. Haven't wiped the sweat and hand prints off yet but you get idea.
