Old 02-04-2017, 06:15 PM   #501
Liltroy
Liltroy's Avatar
Re: Project "Steppin Wolf" LS swap
Originally Posted by reaper71 View Post
When I post pics, I just transfer my pics from phone /camera to my computer then upload to the site as I need to. Very simple and free!
Mark..
what site are you referring to? Because this site wont let me upload pics to my thread, it works by links only.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 02-04-2017, 07:20 PM   #502
reaper71
reaper71's Avatar
This site and several others I belong to all have the same process.
Start by going to the bottom of the (post reply) box click on (go advanced)Then scroll down to the box (manage attachments) and click on that, another box will open this is where you (choose file) that will bring up your files on your PC, select your pic and click on (upload) it is faster going one pic at a time.
Hope this helps, if you have any issues just PM me and I'll help you out.
Mark...
reaper71 is offline   Reply With Quote
Old 02-04-2017, 09:01 PM   #503
RodsGreen10
RodsGreen10's Avatar
Mark...
This is how it works on my phone also.
Follow me on Instagram @rodsgreen10
Hit my YouTube page up http://www.youtube.com/c/RodsGreen10
RodsGreen10 is offline   Reply With Quote
Old 02-05-2017, 07:49 PM   #504
Liltroy
Liltroy's Avatar
ok thats weird cause I could have swore that I tryed that before and it would work. Thats why Ive been using photo hosting sites all this time. But Ill try it now. I just started back on making my cold air intake box so heres the photos after primer and paint.
Old 02-05-2017, 07:50 PM   #505
Liltroy
Liltroy's Avatar
Well Ill be....it actually worked! Guess Ive just been doing things the hard way all this time.
Old 02-05-2017, 07:52 PM   #506
Liltroy
Liltroy's Avatar
I guess Ill start taking more pictures again now that I know this works but Im also making videos of my projects on my youtube channel so heres the series I started on this air box and how I made it. https://www.youtube.com/watch?v=MVi3qLSjBnw&t=9s
Old 02-06-2017, 10:37 AM   #507
reaper71
reaper71's Avatar
Awesome man....Glad you got it figured out!
And good to see more pics up and progress being made.
Mark..
Old 02-07-2017, 04:36 PM   #508
Liltroy
Liltroy's Avatar
ok so update on my intellitronix crap gauges. Those of you who dont know the whole story can read it in this thread but quick recapp.....THEY'RE JUNK!!!! Ordered a set about a year ago, speedo kept resetting, oil pressure didnt work right dispite using 3 different sending units they sent. Speedo would go black when I turned headlights on. Basically they just didnt work right. Well it took me over two months and numerous calls and emails but they finally sent a replacement set. Well by that time I had already reassembled my dash and didnt feel like taking it apart again so Ive just been sitting on the replacements until today. Got the replacements installed and they sent a mixmatched set!!!! top is white bottoms are blue!! Ive had them too long to ask for refund now so screw them. Im keeping both sets and combining them to hopefully make one functioning set and Ill keep the other set for spare parts when something else screws up! DO NOT BUY THESE PEOPLE!!!! Unfortunately I also bought a window switch from them for my nitrous. Im almost afraid to use it.
Old 02-08-2017, 10:08 AM   #509
reaper71
reaper71's Avatar
Dammit Man....It just doesn't stop on some of these build's!
I feel your pain. I have things go wrong on customer builds all the time, it's part of it I guess.
The Gauges Iv'e been using exclusively are Speedhut Gauges They are 100% customizable, from backlight color,font,tick style,pointer color etc,etc, and they come in GPS so NO sending unit to deal with!! I have used 6 sets so far and all are perfect! (my .02 worth) hope you get the gauges sorted out!
Mark.
Old 02-08-2017, 07:10 PM   #510
Liltroy
Liltroy's Avatar
I have no issues calibrating my pcm to whatever speedometer I buy. I don't care much for the delay on the gps gauges. Whenever I can afford it I will definitely be getting rid of these pieces of crap though. I'll look into speed hut. ����
Old 02-11-2017, 08:55 PM   #511
Liltroy
Liltroy's Avatar
Airbox is coming along. Got it coated with bedliner and closed cell foam around the top. Hoping to install it in the truck tomorrow and start work on the lid. Only problem is the piece of lexan I was going to use wasnt long enough so Im gonna have to see how another piece is going to cost and if I can afford it right now. But as long as its not too much Im hoping to at least have it cut out tommorow.
https://www.youtube.com/watch?v=8RCz4bQj-go&t=232s
Old 02-12-2017, 09:56 PM   #512
Liltroy
Liltroy's Avatar
got more done on the air box today. Its coming along nicely. I just need to make some more exact lines around the edges, then Im making a metal frame around the edges out of some aluminum channel stock to hide the edges of the Lexan. Then Ill remove the air box to weatherstrip the bottom edges that contact the inner fender, paint around the edges of the lexan and its done. It should be noted that this piece of lexan will be used as a template to cut a piece later thats not all scratched up. Im using it now because I dont have money to buy a new piece and had this piece laying around.
Old 02-19-2017, 04:45 PM   #513
Liltroy
Liltroy's Avatar
More updates. Lid is finished and installed witht he exception of a few bolts. Need to make some adjustments but over all it turned out great. Ill be redoing the lid out of a new peice of lexan that itsnt all scratched up when funds allow but for right now its gonna seal off the engine bay heat as intended.
Old 02-19-2017, 08:55 PM   #514
Liltroy
Liltroy's Avatar
air box part 5 youtube video
https://www.youtube.com/watch?v=YNFficRc_qQ
Old 02-20-2017, 08:08 PM   #515
Liltroy
Liltroy's Avatar
Ok so Im moving on to trying to chase down my fuel pressure issues . Spent my day taking apart the fuel system and trying to track down the sources of my problems....
https://www.youtube.com/watch?v=VTZ4...ature=youtu.be
Old 02-22-2017, 12:22 AM   #516
Jeramy
Jeramy's Avatar
really like the way air box turned out
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 02-22-2017, 01:49 AM   #517
Liltroy
Liltroy's Avatar
Thanks! Its still not technically finished but I needed to finish up the video series. Ill probably post one more video down the road when I get all the rest of the little bits done.
Old 04-12-2017, 12:42 AM   #518
Liltroy
Liltroy's Avatar
https://www.youtube.com/watch?v=4yRbfireIvU&t=291s
Old 08-20-2017, 12:09 AM   #519
Liltroy
Liltroy's Avatar
Well I'm not really sure if anyone's still following th this build but all updates are now being done on my YouTube channel. And we're officially going turbo! I invite everyone to subscribe to my channel and follow along. https://www.youtube.com/watch?v=5QBPswoUd6E
Old 08-21-2017, 12:51 PM   #520
daddyjeep
daddyjeep's Avatar
I'm still here.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-22-2017, 07:59 PM   #521
Liltroy
Liltroy's Avatar
Originally Posted by daddyjeep View Post
I'm still here.
you sir are awesome.
Old 08-22-2017, 08:03 PM   #522
Liltroy
Liltroy's Avatar
Just a teaser of whats about to come.....
Old 08-23-2017, 09:22 AM   #523
aggie91
I'm just glad to be here!
aggie91's Avatar
Which Turbo you gonna go with?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-27-2017, 01:42 AM   #524
Liltroy
Liltroy's Avatar
I bought most of a used STS turbo kit from a friend. It came off his nephew that passed aways 1999 firebird formula. Its just a T66 P trim. Thats all I know about it. Compressor wheel measured 66/91 and turbine wheel measured 73/64. Its kinda small but he was making 490@ the wheels with it in a rear mount setup. We're fabricating manifolds for front mount. Im pretty sure this thing is gonna spool right off idle but probably not make a ton of power up top so if I feel like I need more Ill upgrade later. Ive only got a total of $500 in parts so far and the only thing I have left to buy is injectors.
Heres the video of the manifolds we fabricated today.
https://www.youtube.com/watch?v=a10wsm9_I8w
Old 08-27-2017, 01:45 AM   #525
Liltroy
Liltroy's Avatar
Original goal for this truck was just to be a 13 second, reliable daily driver. We added Nitrous and its now become a reliable low 12 second daily driver. But I dont want to have to fill bottles all the time so Im moving on to the turbo set up. (although the nitrous will still be there...just jetted down )
