Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-05-2016, 11:57 PM   #526
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Hey mike
Sorry been coaching 2 football teams and my older son moved to Montana for college.
So I have not had any free time.
The calipers are 80-85 caddy rears. I don't recall the part numbers. I bought them off eBay actually. The best price I could find.
7dee2 has the link he just posted about the custom cables I had made. I am sure it is back in My build also. Hope this helps. I will be back on the truck this winter.
I ordered new body mounts and will coating under the cab and then get the cab on the frame.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 09-06-2016, 10:11 AM   #527
7dee2
7dee2's Avatar
Life gets pretty busy sometimes, looking forward to more when you’re ready Scott.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 09-07-2016, 03:03 AM   #528
swamp rat
swamp rat's Avatar
Originally Posted by First c10 View Post
Hey mike
Yea his post is what prompted my question, Just my constant quest for information to be tucked away in case i need it later. Currently i'm running 72 front calipers out back with no E brake, i figure some day i ether try the Caddys or add a driveshaft caliper and rotor behind the 205.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-07-2016, 11:40 AM   #529
First c10
First c10's Avatar
Mike,
I used Captain Fabs 6 lug bracket with the 88-90 GM 1500 Front rotors and the caddy's calipers. I did have to turn down the center hub on my axles to fit the rotors.
Scott
GO GO!!!
Old 09-07-2016, 12:08 PM   #530
swamp rat
swamp rat's Avatar
Mike,
Scott
OK, mines a K20 so probably have to use a different bracket and rotors. Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-08-2016, 01:50 AM   #531
First c10
First c10's Avatar
OH yeah forgot. 3/4 ton stuff is almost Greek to me.
GO GO!!!
Old 09-20-2016, 05:06 PM   #532
First c10
First c10's Avatar
Hey Guys , I started working on the body mounts and ordered new front body mounts for the 68 front radiator support. The problem is the frame is a 70. So the hole in the frame mounts are large for the 69-72 style bushings, too large for the 67-68.
Do I have to cut down the 69-72 bushing to the same thickness as the 67-68 thickness ?
GO GO!!!
Old 09-21-2016, 11:54 AM   #533
swamp rat
swamp rat's Avatar
I'd call the vendor and see if the bushing kit is suppose to be different and is it just the hole diameter, i assumed they were the same....
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-21-2016, 01:15 PM   #534
Deer_hunter_088
Deer_hunter_088's Avatar
nice truck, your son is a lucky kid,
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 09-21-2016, 04:22 PM   #535
First c10
First c10's Avatar
I know they are different as far as the radiator support and the hole size in the body mount. My question is since the frame is a 70 can I use a 70 bushing set and not worry about the 68 radiator support being too high? i will also check with the vender
Thanks Deer_Hunter_088
and you are correct!!!
GO GO!!!
Old 09-22-2016, 11:11 AM   #536
First c10
First c10's Avatar
This is a picture of the driverside radiator support mount. The hole size is larger than the 67-68 frame so the 67-68 bolts and washers don't fit. Does anyone know if the 69-72 mount is located at a different height than on a 67-68 frame? or is the radiator support stamped differently at the bottom of the radiator support?
GO GO!!!
Old 09-22-2016, 12:36 PM   #537
7dee2
7dee2's Avatar
I can tell you the poly replacements we used spaced the core support a little higher than the original 2wd version we removed (all 72 rubber stuff). This set our shroud a tade higher but still cleared our fan. Ended up shimming the front cab mounts to make everything come back in line. Worked out OK because we needed this to help clear the transfer case anyway. I'd leave it high till you can mockup everything up on your frame, cuz you can always shave um later. http://67-72chevytrucks.com/vboard/s...&postcount=365 BTW we might have to add even more cab mount shims to allow for TC flex before it's all done?
Brett
Old 09-22-2016, 01:22 PM   #538
First c10
First c10's Avatar
Hey Brett
Thanks for the info... I seen that post from you and agree about the TC room. I am using a 68 frontend on a 70 k20 frame and was wondering if I can use 69-72 bushings. On hulk JR it has a 68 frame and front end I used 69-72 bushing kit and had to raise the cab 1/2" in the front and 1/4" at the rear of the cab to get it right.
GO GO!!!
Old 11-23-2016, 11:48 AM   #539
First c10
First c10's Avatar
I had a chance to meet with my paint and body guy last night to discuss getting the cab to his shop to start the body work and get the underfloor and firewall sprayed so I could get it on the frame. He told me that he should only have it for about a month as he didn't want it in the shop longer than that. I told him as long as it was right. Keep you posted!
I am thinking about Big Blue Pearl code 930849 (its what I have on my 2014 Harley Street Glide)
GO GO!!!
Old 11-27-2016, 03:39 AM   #540
swamp rat
swamp rat's Avatar
You wouldn't be the first guy with matching toy's in the garage!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-30-2016, 02:33 AM   #541
First c10
First c10's Avatar
We now have an A/C Cab.
I was able to spend some time cutting in and test fitting the a/c ducts. I am not happy with the center ductwork fitment. The chrome grill fits it's the black abs plastic duct that fits behind the dash. I may get out the heat gun and reshape it.
GO GO!!!
Old 11-30-2016, 11:41 AM   #542
7dee2
7dee2's Avatar
Nice color choice and glad to see you working on this one again!
Brett
Old 11-30-2016, 02:44 PM   #543
First c10
First c10's Avatar
I agree!!!
I am waiting on the estimate to get the cab body work done......Hope its not to bad and doesn't need any metal work other than possible the cab to door area. I will hang the doors and post a picture.
GO GO!!!
Old 12-01-2016, 01:34 PM   #544
First c10
First c10's Avatar
Driver door gap looks pretty good.... even the window frame looks good. still needs a little adjusting but I think it is pretty good.
GO GO!!!
Old 12-01-2016, 01:38 PM   #545
First c10
First c10's Avatar
Now the Passenger side not so good as far as the window frame.
Any ideas???
I cant really move the door back any as i think it maybe to close to the back part of the cab.
The window frame is very close to the drip rail of the cab.
AGAIN ANY IDEAS???
Bend the door window frame in????
GO GO!!!
Old 12-01-2016, 10:55 PM   #546
mjensen
mjensen's Avatar
I don't know how the pros do it, but I had to adjust my window frames by placing a 2x4 in and closing the door on it. Bent the tops out like a champ, but mine were closer to the jamb than the opposite way. They actually move easier than I anticipated.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-02-2016, 01:24 AM   #547
First c10
First c10's Avatar
Thanks for the info. I thought about placing a 2x4 across the the door on the inside and placing another in from the outside of the window and push the top frame towards the cab.
Trying not to bend the inner door.
GO GO!!!
Old 12-03-2016, 09:39 PM   #548
swamp rat
swamp rat's Avatar
Mine are both closer (in more) at the top, but the door shells aligned with the cab and front fenders fine, been kinda afrade to try an "adjustment" so I await your results. I know not much help, sorry.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-04-2016, 01:17 PM   #549
First c10
First c10's Avatar
Hey Mike. I talked to my body guy and he said don't do anything until the cab is on the actual frame with new bushings and tightened down. Right know it is on the rotisserie.
He said he will need the cab in about 2 weeks be it will be ready to put on the frame in 30 days as he doesn't want it sitting around. Works for me.
GO GO!!!
Old 12-04-2016, 03:02 PM   #550
First c10
First c10's Avatar
Anybody know where I can get the stamped nuts that fit the brake light switch? I need 2.
GO GO!!!
