Old 07-20-2018, 12:18 PM   #5576
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
needless to say this oil leak has been bothering me, so after I found some flanged bolts I went to town on attempting a solution
first I dry cleaned the oil puddles and yanked the old bolts out
then I goopedetized the new flanged bolts in a liberal coat of Permatex gasket sealer, an old engine builders trick
and then I torqued them back in to spec (as hard as you can, plus a quarter turn, as Mustang Frank used to say, ha ha) jk
Gregski is offline   Reply With Quote
Old 07-20-2018, 12:31 PM   #5577
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then I spick and spanned the bellhousing [again]
for the record the last mess took just over 1,000 miles of driving to get yucky that's when I did the new top end, so I will provide an update after the next blissful 1,000 miles
current mileage just over 16,300
Old 07-20-2018, 02:59 PM   #5578
LT7A
Re: Restoring Rusty
Originally Posted by Gregski View Post
bonus points for proper use of the word "malodorous" had to look it up... ahem, for a friend
Hahaha, had me choking on my morning beverage. I hope that the new intake bolts do the trick. Did you pull the manifold and reseal or are you hoping the squinch power of the new bolts does the job?
Old 07-20-2018, 09:07 PM   #5579
peabobble
Re: Restoring Rusty
Watching your solution closely since I have the same dysfunction.
peabobble is offline   Reply With Quote
Old 07-22-2018, 12:21 PM   #5580
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well right after I scored the Mr. Gasket T handle, I happened to win the eBay auction for this shifter ball, well it ain't the $700 dollar one but it might do
looks just like the white one I already had but this one gots the right thread in it
Old 07-23-2018, 08:48 PM   #5581
MikeB
MikeB's Avatar
Re: Restoring Rusty
I have maybe $3k-$4k more in my 82 C10 than it's worth, but I'd bet you've outdone me!
My latest sink hole is dropped spring hangers and new rear springs (with all the associated bolts and bushings) and a cool non-step bumper with required brackets, bolts, etc. Around $800 all-in. Ka-ching!
I keep telling my wife that it keeps me out of the bars and strip clubs.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-24-2018, 11:14 AM   #5582
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
funny shizwah you always make me laugh, chics dig the non-step bumper! LOL
Old 07-24-2018, 11:17 AM   #5583
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
cool, well it looks like we won't have to wait 1,000 miles, seems like after about 100 miles the solution did not take on the driver side
hard to see in the second pic but the bell housing is wet on the driver side, my oil is nice and clean so it's hard to tell it's running down that side
That does it, we're doing an LS Swap!!! jk
Old 07-24-2018, 12:09 PM   #5584
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
There are grade 8 bolts with an o-ring in a groove to fix this problem. Not sure where I saw them...
If you have a lathe you can make your own...
Just like a Harley. It's not leaking... it's marking its' territory.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-26-2018, 09:58 PM   #5585
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so the Saginaw 4 Speed Transmission rebuild kit showed up
Old 07-27-2018, 02:34 AM   #5586
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright so the first thing I done did the night before was clean off an entire work bench, I don't know about you but I just function better in clean space, also I never rebuilt a transmission so I need all the help I can get and this ought to help me lay the parts out propper
Old 07-27-2018, 02:39 AM   #5587
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I was a hopin' the truck gods would smile upon me as I removed the side cover first with the gear box still attached to the engine, I figured what the hewk lets go for the easy win, maybe some spring or clamp or bracket fell off in there and is just bouncin' around
well no such luck, everything appeared in order, although at first I thought could that fork be broken like that, well no a quick stare and compare with the new one on All State Gear dot com revealed that's just how the 3-4 ? I think they mean 1-2 shift fork is
Old 07-27-2018, 02:40 AM   #5588
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
even stuck my hand inside the belly of the beast and tried to wiggle things a bit but nothing out of the ordinary other than worn bearings and syncros I believe, I felt around in the puddle of left over gear oil for broken bits gear teeth etc, but nothin'
Old 07-27-2018, 02:43 AM   #5589
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so out she came, and I hoisted her up on the work bench for disassembly...
so happy I can yank the transmission out without disassembling my dual exhaust, saves so much time
Old 07-27-2018, 02:47 AM   #5590
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so took some pics of the guts, ie the orientation of the gears and syncros so I know how they all go back in
and after removing the input shaft housing, the speedo gear I just loosend the tail housing and call it a night on the account that I apparently do not own a set of snap ring pliers (shame on me)
Old 07-27-2018, 02:51 AM   #5591
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
For The Record: this is the second GM aka Chevy transmission (the 833 overdrive one being the other) that aint all that popular, so finding info on how to rebuild a Saginaw 4 speed, or better yet how to take it apart took some doing, I saw a few nut job YouTube videos, most were for the 3 speed, and then this guy who calls himself Melrose RS saved the day on our sister Camaro forum How to disassemble a Saginaw transmission
Old 07-27-2018, 11:10 AM   #5592
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
a quick stop at the local Napa and we were back in business
these babies were xpensive, $40 bucks, but sposely they are reversable, for in and out bound rings
Old 07-27-2018, 01:20 PM   #5593
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by hatzie View Post
Input shaft center support needle bearing or the cluster gear needles make noise in the Saginaws.
GM only used two rows of needles inside the cluster gear in the Saginaw 3 & 4 speeds vs four rows in most other transmissions so the countershaft and cluster gear sometimes wear badly.
Not difficult to repair as long as the cluster gear isn't knackered.
Thank you, much appreciated as always, I aint no expert but to me it sounds like the noise I hear is the noise coming from the idler gear when it is engaged, of course I am testing with a try gear box, ie no gear oil so maybe with oil it don't sound like that, anyways that would be the noise of gear teeth meshing
Old 07-27-2018, 02:33 PM   #5594
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so equipped with my new tool, wrong tool mind you (it's not the type of snap ring pliers you need) I began to take this transmission apart
first I removed the four bolts that hold the input shaft housing to the front of the transmission (but we've been over this before when we swapped the smaller car style housing for the larger truck housing)
then I snapped out the ring that holds the input shaft bearing and that was a bear
for the record I was expecting / hoping for some slop in the front bearing but it felt nice and solid
Old 07-27-2018, 02:37 PM   #5595
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
with the front bearing snap ring out, and the bearing off, I was able to separate the tail housing and pull the main shaft out of the back of the transmission case
Old 07-27-2018, 02:43 PM   #5596
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
naturally the input shaft separated from the main shaft and half a dozen needle roller bearings were on the run, there are 14 total
Important Lesson Learned: I sorta knew this already but the eye opening experience is to discover that although the short input shaft is on the same plane as the main shaft ie they make one horizontal line, they are actually two separate spinning shafts independent of each other, don't laugh it's obvious to sum, but us idiot savants need time to digest, jk
I believe the 4th gear ie direct drive, so 1:1 ratio lives on the input shaft
Old 07-27-2018, 02:47 PM   #5597
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
started taking the parts off the main shaft, I think this is the 3-4 slider
Old 07-27-2018, 03:02 PM   #5598
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Saginaw 4 Speed Transmission schematic from DriveTrain.com, wish it had parts names to go with it
it's really hard to find anything on these four speed Saginaw's seems like every time you search they want to shove Muncie pics at your, ha ha
so I had the second pic from AutoZone but deleted it cause they say it's a Muncie, but clearly it's my four speed Saginaw
Old 07-27-2018, 03:10 PM   #5599
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I think here I am taking off the 3rd gear, sorry about the shifting my transmission on the bench left to right and front to back it may be difficult to make sense of any of this
Old 07-27-2018, 11:30 PM   #5600
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
at this point I didn't quite know what was holding the main shaft in the tail housing still, so I decided to remove the rear oil seal to see if I can find a snap ring in there, but nope, turns out that's not what hold the shaft in there
though I had a proper seal puller this seal was in there for 40 years and was too stubborn to go quietly into the night, so I had to tickle it a little bit
