Old 08-09-2010, 02:07 PM   #551
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread
72bb, not yet....SOON must get dune buggie sold, Eric thanks for all of the compliments , hope the hood hinges help , Mac thank you
67cheby is offline   Reply With Quote
Old 08-12-2010, 07:36 PM   #552
mac72
Mike, done anything about a driveshaft yet?
mac72 is offline   Reply With Quote
Old 08-13-2010, 01:57 PM   #553
67cheby
67cheby
67cheby's Avatar
yes i am running a 2piece drive shaft , the rear shaft is a CPP shaft with a slip joint, a CPP billet carrier bearing raised 1 1/2 inches and a shortened front driveshaft
Old 08-13-2010, 03:01 PM   #554
colin_havens
colin_havens's Avatar
Mike, where did you get your spacer for your carrier bearing? Mine has a little vibration when I really stomp on it, and I think raising mine a little may help.
colin_havens is offline   Reply With Quote
Old 08-13-2010, 03:33 PM   #555
67cheby
67cheby
67cheby's Avatar
i had a shop here in town make it
Old 08-13-2010, 11:09 PM   #556
jasonhall
jasonhall's Avatar
What did you think of your rear shaft from CPP? What did it cost?
jasonhall is offline   Reply With Quote
Old 08-13-2010, 11:20 PM   #557
mac72
Is your front shaft A 2" tube?
Old 08-14-2010, 09:10 AM   #558
67cheby
67cheby
67cheby's Avatar
very nice piece , dont know if i really need the slip joint or not but it made sense to me, because you are moving up and down, i think about 189 cost
Old 08-14-2010, 09:11 AM   #559
67cheby
67cheby
67cheby's Avatar
it is the factory front one , just shortened, i would guess it is 2 inch
Old 08-14-2010, 10:45 AM   #560
mac72
does the tubing size look the same front to rear? I'm pretty sure the cpp piece is 2".Mine has to be at least 2" to be strong enough for my setup.Fyi your rear suspension moves in an arc when it goes up & down hence the slip joint
Old 08-14-2010, 10:48 AM   #561
67cheby
67cheby
67cheby's Avatar
i will look this weekend and see if they look the same size
Old 08-15-2010, 09:40 AM   #562
68 TT
Still plays with trucks
68 TT's Avatar
Great build. Keep up the good work.
Hope the buggy sells soon and for what you need to get out of it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-15-2010, 09:42 AM   #563
68 TT
68 TT's Avatar
How much above the bed floor do the tops of the notch sit?
Old 08-16-2010, 09:01 AM   #564
67cheby
67cheby
67cheby's Avatar
about 4 inches
Old 08-16-2010, 11:28 AM   #565
68 TT
68 TT's Avatar
about 4 inches
How thick are the tops of the notches and how thick is the bump stop you showed that was under the arch? Is the bump stop still under the arch or did you change the location?
At full drop will the center section of the differential or the watts link hit the bed floor if it was all at one level?
Old 08-16-2010, 11:31 AM   #566
67cheby
67cheby
67cheby's Avatar
you do realize that my bedfloor has been raised 4 1/2 inches right ??
Old 08-16-2010, 11:55 AM   #567
68 TT
68 TT's Avatar
Yes I know you moved the bed up, just seeing if structural mods to the frame will gain you anything as the top of the pumpkin may hit the floor anyway with the rails on the ground.
I have done rear rails with the arch on the bottom instead of the top in low slung back halved race cars is why I was curious. Its possible you could leave a section of the legs of the arch in place above the rails to anchor your air bags & cross braces to but have the main structural member of the frame below the axle tubes. Absolute pain in the butt to remove the housing but it could give you the clearance you need to keep it all below your relocated bed floor. You have to have room to pull the wheels off at full lift before the axle tube hits the frame rail too so it might take a bit or a reverse arch to do this in a 67-72 with round wheel wells.
Old 08-16-2010, 01:06 PM   #568
67cheby
67cheby
67cheby's Avatar
i think the pumpkin get way up there, i havent had my bed on in a while ,(its at the body shop) if i had it on i would do some measuring for you
Old 08-16-2010, 03:15 PM   #569
68 TT
68 TT's Avatar
You can see where it sits relative to the frame notch arch and take some measurements to see how high up the center section gets.
Old 08-18-2010, 12:56 PM   #570
colin_havens
Hey Mike, I was just thinking... dangerous, I know.... The Relaxed Atmosphere Allstar Event show is coming up in a few weeks, on Labor Day Weekend. You planning on going? I know you wont have your truck there, but lots of bagged rides and an absolute blast, and some of the best built rides (magazine quality, not hack jobs) always show up. I'm taking the 67, just wanted to see if you were planning on going.
Old 08-18-2010, 01:02 PM   #571
67cheby
67cheby
67cheby's Avatar
i know nothing ?? where will it be ??and dates
Old 08-18-2010, 03:13 PM   #572
lolife99
67-72 parts collector,…
lolife99's Avatar
http://www.relaxed-atmosphere.com/Re...t.aspx?page=13
Keith
Convert to disc brakes.
Old 08-20-2010, 01:27 PM   #573
colin_havens
Thats the show I was talking about. Thanks lolife! Gonna be a good time, and hell, even the event flyer has a C-10 on it lol. You should check it out
Lolife, are you going?
Old 08-23-2010, 10:09 AM   #574
67cheby
67cheby
67cheby's Avatar
good news...sold the Dune Buggie , started working on the truck again last night put the rear disc brakes back on (should be the last time the rear end is completely powder coated and done, minus running the brake lines)NOW.... back to the "NIGHTMARE FRONT INNER FENDERS"
Old 08-23-2010, 10:52 AM   #575
VA72C10
VA72C10
VA72C10's Avatar
congrats on the sale! Now you know that means we expect to see shiny new parts and progress on this now...right
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
