Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-16-2016, 11:31 PM   #551
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Sorry but no. If you are running stock Ford housing ends, just about everyone runs the Explorer rear disc assembly. If you are running a narrowed 9" with the correct Impala/truck housing ends, I have the correct base brackets that will retain the axle bearings and allow you to be able to run these D52 brackets.
Originally Posted by Joemomma1 View Post
Anything in the works for this same setup on a Ford 9"?
Old 07-28-2016, 12:17 AM   #552
gijoecarlos
Do you still sale these brakets?
gijoecarlos is offline   Reply With Quote
Old 07-28-2016, 12:55 AM   #553
Captainfab
60-66 Nut
I replied to your PM
Old 08-08-2016, 12:53 AM   #554
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
Old 10-25-2016, 11:20 PM   #555
69_C10_project
69_C10_project's Avatar
Thumbs up Re: D52 Caliper Rear Disc Brake Brackets
Are you still making these brackets? They look way sturdier than the junk on eBay.
69_C10_project is offline   Reply With Quote
Old 10-25-2016, 11:38 PM   #556
Captainfab
60-66 Nut
Yes, I make all of my products everyday including these D52 brackets. Send me a PM for ordering/payment info.
Old 11-13-2016, 03:32 AM   #557
Sinisterv10
Sent you an email Capt
Sinisterv10 is offline   Reply With Quote
Old 11-13-2016, 11:53 PM   #558
Captainfab
60-66 Nut
I replied to your email.
Old 11-17-2016, 10:19 PM   #559
Sinisterv10
I received my brackets today!!!!! I'm excited!!!! These things are heavy duty. I had purchased a set of weld on brackets from anther vendor but when they arrived, i wasn't too convinced with the 1/4" steel. You get what you pay for. Those 1/4" brackets were only about 10 bucks a piece and no hardware. These Captain brackets are worth every penny. I was very impressed with the packaging. I have had delicate items delivered with much less padding than these brackets did. Sorry for jumping around, its just a good day. I'm hoping to finish my propane tank smoker this weekend so my son and i can get started on this. Thanks Capt.
BTW, whats everyone doing for the MC and the proportioning valve. I was thinking using a MC from a 1982 corvette and a PV4 combination valve. Any thoughts
Old 11-17-2016, 10:53 PM   #560
crakarjax
crakarjax's Avatar
I'm using a Mopar MC since they are aluminum & plastic and make for a really clean & cheap install. They have 3/8" fittings and come in a wide range of bore sizes. You need to open up the mounting holes slightly but otherwise they bolt right onto the firewall.
Here are the part numbers I've gathered:
https://snag.gy/oDkjZ5.jpg
I am using a cheap ebay prop. valve inline with the rear circuit.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 11-18-2016, 12:01 AM   #561
Sinisterv10
Thanks crakarjax, i'll check into those. That's some good info you got there on the MC's.
Old 11-18-2016, 02:06 AM   #562
Captainfab
60-66 Nut
I would just use a '77-'82 Corvette master and the prop valve for that application and/or an adjustable valve in the rear line. If you want an aluminum and plastic master, the '83+ Corvette, '85+ F-body's, '85+ Eldorado's, '94-'96 Impala SS. Caprice 9C1's as well as C/K1500 trucks in the 90's with 4 wheel disc will work.
Old 11-22-2016, 05:05 PM   #563
akdg87
akdg87's Avatar
will these work with a 15" wheel? i currently have them on my pickup but want to step down to a smaller rim.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 11-23-2016, 01:30 AM   #564
Captainfab
60-66 Nut
Yes, 15" wheels will work as long as they are disc brake compatible wheels.
Old 12-05-2016, 10:49 AM   #565
elf w/capital T
You selling axle flanges by them selves? I need a 1/4 inch thick for Myou different swap...pm sent
elf w/capital T is offline   Reply With Quote
Old 12-05-2016, 06:18 PM   #566
Cj Davidson
I need a set of bracket for my 1968 GMC. How much for the ones you sell for the Camaro calipers? What rotor will I need to purchase?
Thanks CJ
Cj Davidson is offline   Reply With Quote
Old 12-06-2016, 01:16 AM   #567
Captainfab
60-66 Nut
I replied to your post in the Camaro Caliper Bracket for sale thread.
Thanks CJ
Old 01-07-2017, 11:27 PM   #568
c10-72 II
Active Member
c10-72 II's Avatar
What about brackets for a six lug 12 bolt? I saw that you discontinuing the six brackets to make a better set in another thread. thanks
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
c10-72 II is offline   Reply With Quote
Old 01-08-2017, 12:32 AM   #569
Captainfab
60-66 Nut
I have these:
http://www.67-72chevytrucks.com/vboa...d.php?t=494411
and these:
http://www.67-72chevytrucks.com/vboa...d.php?t=637489
Old 02-01-2017, 12:18 PM   #570
68Stepbed
68Stepbed's Avatar
I received my stuff today! Thank you, sir!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-02-2017, 12:57 AM   #571
Captainfab
60-66 Nut
Thank you for the purchase Matt
Old 02-17-2017, 10:28 AM   #572
68Stepbed
68Stepbed's Avatar
In case anyone is wondering, rockauto.com sells the Centric brand rotors, which is also branded as StopTech. Since I'll have corss drilled and slotted Wilwoods up front, i figured the rears needed to somewhat match.
Matt
Old 02-18-2017, 12:32 AM   #573
Captainfab
60-66 Nut
Thanks for sharing the info on the rotors.
Old 02-18-2017, 11:28 PM   #574
Greywolf200
Nice job.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 02-25-2017, 04:28 PM   #575
68Stepbed
68Stepbed's Avatar
Matt
