Old 02-12-2011, 06:40 PM   #551
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
The heart is coming out.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-12-2011, 09:41 PM   #552
VA72C10
VA72C10
VA72C10's Avatar
Cool!!!
Moving along nicely!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-13-2011, 11:56 PM   #553
drewskiren
drewskiren's Avatar
Placed the bed on the newly fabricated mounts and it fits very well. Mounted the wheels on a spare suburban rear axle to mock it up. Frame is sky high in the front, but I think this will be my rear ride height. The wheels look great and are the perfect width on the newer axle. Last picture shows what the tire does at full dump. This gives me 3 inches of suspension travel. Since I can raise the pressure for a heavy load, I don't need any rake to compensate for a load. I think 3 inches of travel is enough, anyone have any insight on this?
Drew
Old 02-14-2011, 12:19 AM   #554
mcbassin
Still Learning
mcbassin's Avatar
Hey Drew, that looks great! How did it go with the engine/tranny pull? You about ready to set it in the frame?
mcbassin is offline   Reply With Quote
Old 02-14-2011, 12:23 AM   #555
67chevy1series
67chevy1series's Avatar
wow those rims look great! i think those are the best rims gm has produced in awhile! oh finally the heart transplant!
67chevy1series is offline   Reply With Quote
Old 02-14-2011, 01:45 AM   #556
VA72C10
VA72C10
VA72C10's Avatar
That looks great! (especially dumped )
Although I think you'll want/need more than 3" of travel....maybe post that question in the suspension forum. Most bags have 9-10" of useable stroke...so why are you ending up with 3"? Final thing is you'll want to ask around for a good PSI for your planned ride height. If that is fully inflated, I don't think you'd like the ride at all.....
Also, keep in mind the rear height will change somewhat once you bring down the front end also as the frame rotates down....
Old 02-14-2011, 01:53 AM   #557
drewskiren
drewskiren's Avatar
Close to getting it out, maybe by Wednesday.
Drew
Old 02-14-2011, 02:02 AM   #558
drewskiren
drewskiren's Avatar
The Firestone F9000 sleeve type bag I am using for the back has a max height of 10.25 inches, ride height of 8.25, and dumped of 6.25. According to their website. This type bag rides the smoothest AND has the most weight bearing capacity, it's a small version of what you see on 18 wheelers. I was showing the ride height. And yes you are right about the rear bumper rotating up some. I need to yank my front springs.
Drew
Old 02-15-2011, 12:30 AM   #559
drewskiren
drewskiren's Avatar
Not a whole lot to report tonight, but I did get the front down to see what the front and rear ride height look like.
FYI- when you cut your springs watch out for the big BANG when you are almost through. Sounded like a gunshot, (I ducked).
Pretty tough looking I think.
Drew
Old 02-15-2011, 12:33 AM   #560
67chevy1series
drew i just saved those to my crew cab building ideas folder!
Old 02-15-2011, 12:39 AM   #561
mcbassin
Still Learning
mcbassin's Avatar
Looks great! And yes, you will get a bang if you're under a load. You could heat up each coil until the whole thing is shorter......takes forever though.
Old 02-15-2011, 12:45 AM   #562
63chevyll
gets board easy.......
63chevyll's Avatar
Wow, I can't believe you cut the springs out that way. Glad you all are ok
63chevyll is offline   Reply With Quote
Old 02-15-2011, 12:51 AM   #563
VA72C10
VA72C10
VA72C10's Avatar
I was thinking convoluted bags....so are you getting the full 4" of travel?
Looks really tough. Glad those springs didn't get you....I know there wasn't a lot of weight on there...but I've heard of people getting hurt cutting them out....
Old 02-15-2011, 01:28 AM   #564
drewskiren
drewskiren's Avatar
I knew there was just the weight of the frame, and I was cutting in the middle. There was at least two coils above and below wrapped around the shock, so it wasn't going to come flying out. I ended up cutting the small piece a second time to wiggle it out.
Drew
Old 02-15-2011, 07:53 AM   #565
Hart_Rod
Hart_Rod's Avatar
Looks good. Are you going to run the Shockwave airbag on the front?
Hart_Rod is offline   Reply With Quote
Old 02-15-2011, 10:30 AM   #566
67cheby
67cheby
67cheby's Avatar
nice stance
67cheby is offline   Reply With Quote
Old 02-15-2011, 10:56 AM   #567
drewskiren
drewskiren's Avatar
No, I am going for maximum comfort which means maximum air volume. Just a normal 8 inch Firestone double and a soft shock.
Drew
Old 02-15-2011, 05:18 PM   #568
drewskiren
drewskiren's Avatar
I just found these pics and thought I would share. This is where it happens.
Drew
Old 02-15-2011, 06:30 PM   #569
67cheby
67cheby
67cheby's Avatar
now i like the house and shop more than the truck !!
Old 02-15-2011, 07:07 PM   #570
mcbassin
Still Learning
mcbassin's Avatar
Drew, your shop looks great thanks for sharing the pictures. BTW, you build some awesome houses too
Old 02-15-2011, 07:13 PM   #571
brn agn
brn agn's Avatar
I would like to order one just like that (the shop). Please deliver it to the mailing address that I sent you via PM. I will be patiently waiting on the front porch.
Seriously, that is a really nice looking shop. My wife and I have been kicking around the idea of building a detached garage, but most of the ones we have seen have vinyl siding and are just big enough to store one car and some camping supplies. I really like the look and size of your shop! Did you build it? Do you have any other details about it you can share (square footage)?
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 02-15-2011, 07:23 PM   #572
JHT67
JHT67's Avatar
edit: question answer'd
JHT67 is offline   Reply With Quote
Old 02-15-2011, 07:33 PM   #573
drewskiren
drewskiren's Avatar
Drew
Old 02-15-2011, 07:38 PM   #574
67chevy1series
beautiful shop almost looks to pretty to work in!
Old 02-15-2011, 07:40 PM   #575
drewskiren
drewskiren's Avatar
Thanks,
Yes I am a custom home builder, see Drewrenshaw.com. I drew it myself and wanted the bungalow look, eventually I will remake our house to match.
It is 28 by 36 with an 800 sq foot apartment upstairs to house missionary families when they come home from overseas; places like Africa, India, China. When missionaries sell everything and go to do the Lord's work, we feel like we should support them by providing housing when they return on furlough or vacation. Our family gets to learn about different cultures and the difficulties of being on the mission field as well as the joys. It is our desire to go serve ourselves, but until we are able to we do this instead.
Drew
