Old 11-07-2015, 06:40 PM   #551
MP&C
MP&C's Avatar
Re: 55 Wagon Progress
The more I looked at our panel with the spot weld carnage, the more I disliked the result, so with new linear guides installed, we made all new today using stainless pop rivets to hold the guides in place. This will leave a few 1/8" holes to fill, but should be much less issue than cleaning up after the spot welds...
We needed just a bit more throat for this set of "lengthened" hood sides, so one bolt was removed from the material clamp and then rotated the clamp inward 90". This lets the panel pass through rather than bottom out in the clamp.
Guides riveted in place....
Here's the new version 1, much cleaner, less distortion, and we can re-use the guides...
The cowl piece was done without guides....
And version 2 with the cowl piece.....
Dave (the car owner) stopped by this afternoon and picked up the samples, and indicated he was being over-ruled by most parties on louvers in the cowl, so likely that version won't be used...
Robert
MP&C is offline   Reply With Quote
Old 11-09-2015, 01:34 PM   #552
MP&C
MP&C's Avatar
....And, in the interest of showing the good with the bad, the lessons learned if you will, Safety tip of the day is to deburr your sheet metal even if it's only for practice pieces....
Robert
Old 11-09-2015, 07:43 PM   #553
oldman3
oldman3's Avatar
OUCH!!!!!!...Jim
oldman3 is offline   Reply With Quote
Old 11-09-2015, 09:00 PM   #554
duallyjams
duallyjams's Avatar
That's a good chunk, keep it clean my brother inlaw just spent a week in the hospital for a infection in hes finger.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-10-2015, 11:48 PM   #555
MP&C
MP&C's Avatar
So far so good, nothing oozing..
Tonight we worked on the frame, used some poster board to make a pattern for a strengthening plate to span the pocket kit on each frame rail..
While Kyle filled in some frame holes by plug welding to the pocket kit, I cut out the frame plates...
And the shop vacuum is about on it's last leg, it leaves behind about as much as it picks up. For anyone at DYSON or SHARK vacuum that would like to send a test sample, we can sure do a stress analysis on your product..
Robert
Old 11-13-2015, 12:08 AM   #556
MP&C
MP&C's Avatar
More prep and welding on the frame....
and we cleared out the remaining vacuum inventory from the yard sale pile.. This one is working a bit better!
We've been going through a dry spell here in the shop, it's been quite some time since we've seen any yellow body panels. Soon to change....
Robert
Old 11-13-2015, 09:12 AM   #557
Cape Codder
Cape Codder's Avatar
My first summer working in a body shop was spent sandblasting school buses from the cowl back. I think we did 5 that summer. That was 1974
Cape Codder is offline   Reply With Quote
Old 11-13-2015, 09:53 AM   #558
MP&C
MP&C's Avatar
Were they trying to keep ahead of the salt corrosion in stripping/repainting?
Robert
Old 11-13-2015, 02:24 PM   #559
Cape Codder
We were stripping and repainting due to old paint peeling in spots. We did one every two weeks. It took as long to tape the windows with cardboard as it did to actually blast them. The paint blew right off. Then sanding ,priming painting plus the two tone. All in Dupont Dulux enamel
Old 11-13-2015, 02:30 PM   #560
Low Elco
Lovin' the louvers. What is the pocket kit for? Will this one be going bags and a 4-link?
Low Elco is offline   Reply With Quote
Old 11-13-2015, 02:42 PM   #561
MP&C
MP&C's Avatar
They make a pocket kit for the tri five Chevy that allows moving the leafs into/suspended under the frame for additional tire clearance for those larger meats and still leaves the room between the rails for fuel tank/exhaust.. Like here:
Robert
Old 11-16-2015, 01:42 AM   #562
swamp rat
swamp rat's Avatar
Love that spring mod! Great idea.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-17-2015, 11:58 PM   #563
MP&C
MP&C's Avatar
Still working on the frame, Kyle was prepping the frame for welding on the strengthening plates while I drilled the plates for plug welds..
Plug welding....
The outer perimeter will be Tig welded...
Robert
Old 11-18-2015, 08:57 PM   #564
Advanced Design
Advanced Design's Avatar
Continued nice work. Reinforcing the frame along the pocket is a good idea. Logical and I haven't noticed it done before.
Advanced Design is offline   Reply With Quote
Old 11-20-2015, 12:54 AM   #565
MP&C
MP&C's Avatar
Thanks, I just wasn't keen on the pocket kit alone, a little added security blanket, if you will..
Still working the frame, here's the driver's side plate all clamped up and ready to go.. Hindsight and all that, should have made the plates about 2" longer and we wouldn't have those pesky holes in the way at the front end..
So we decided to cut out some 14 gauge and fill in those holes. Cut a piece the same width as the hole, and rounded the end. Then used the band saw to cut a vee on the back side of the "plugs" and continued to clean up the radius with the 3" Roloc sander. Once close, a bit more on the band saw and break off the remaining, then fine tune with the sander..
Magnet used to hold in place for tacking..
For TIG welding the perimeter of the plates, we decided to make up a "crutch" that we could rest our hand on for better holding the torch...
Kyle is getting a pretty good hold on this welding stuff...
He even let me get in some practice....
Robert
Old 11-20-2015, 10:22 AM   #566
oldman3
oldman3's Avatar
Looking great as always...Jim
Old 11-21-2015, 07:54 PM   #567
Turtleman
Turtleman's Avatar
LOL... Have you heard anything yet?
I just read the whole thread.. Really nice attention to details, I've learned allot,, thank you for the time it takes to do the images and post the information also
Turtleman is offline   Reply With Quote
Old 12-02-2015, 12:19 AM   #568
MP&C
MP&C's Avatar
No, they are dragging their feet and in the meantime the dirt is piling up
Kyle got the welds finished up on the frame plates...
Frame is ready to send to get media blasted...
And the rear was busted apart for some media blasting as well
Getting the bus parts prepped for paint, the owner had a used bumper in stock so it will get repainted...
Robert
Old 12-05-2015, 12:26 AM   #569
MP&C
MP&C's Avatar
We've been waiting for an opening at the machine shop's blasting booth, we're going to get the frame done first. They have some large platform in there now for the US Navy, so it looks like another couple weeks.. So in the meantime, Kyle has been prepping some front end components for paint..
......and we should have this showing up tomorrow, need to get some metal cut out of the side and new replacement made up...
Robert
Old 12-05-2015, 10:24 PM   #570
MP&C
MP&C's Avatar
Here's what we had to contend with on the bus. Some can opener effect going on....
After cutting some of the mangled mess out of the way.........
......we saw that the bottom structural member was not going to cooperate. The horizontal section behind the weld tear at the top used to be vertical... So to save some time, we'll cut this out and make a replacement. This is 16 ga, and is there to keep vehicles out of the passenger compartment. It did it's job, so let's put in a new one to restore the integrity..
Here the bottom flange is pushed in over an inch..
Here's the replacement we made up..
Comparison....
All trimmed, we'll get the replacement panel formed and fitted Tuesday..
Spare parts...
Robert
Old 12-08-2015, 12:03 AM   #571
MP&C
MP&C's Avatar
Well our bus side panel is just shy of 8' long and about 24" wide. We did a light pass on the wheeling machine just enough to break the grain, figured it would have less chance of waves that way... We found out real quick that 8' is a bit long, so some 1x2's were pony-clamped under the outside edges to provide a bit of support. We tried to make a pass through the bead roller for the stepped flange at the bottom, with less than stellar results, a bit wavy up and down. Good thing we had the other half of the sheet. More wheeling, and used the offset / step dies in the Lennox Tru-Edge.
Given our challenges with the long panels, we had to call in reinforcements. Regardless of the late hour that Scott's attire suggests, it was only 8 at night!
Linear slides really came in handy, nice straight detail this go round..
Comparing the bend relief above the rear bumper ear...
Tomorrow evening well get it fitted to the bus and final trimmed..
Robert
Old 12-09-2015, 12:22 AM   #572
MP&C
MP&C's Avatar
Finished the welding of the lower structural member on the bus repair...
.....and underneath it is tied to the floor cross members
Added the frame around the fuel door, this helps prevent the side panel from flopping around as the fuel door is pushed closed..
Thursday evening we'll get all the holes pre-drilled for the skirting and start prepping for paint..
Robert
Old 12-09-2015, 02:28 AM   #573
Advanced Design
Nice clean fix going on there. The channels came out really well. How did you make them? Almost looks like press brake work and am thinking they are too narrow for that.
Old 12-09-2015, 07:36 AM   #574
MP&C
MP&C's Avatar
The channels are 16 ga cold rolled, they were bent on the Baileigh magnetic brake.
Robert
Old 12-10-2015, 09:02 AM   #575
MP&C
MP&C's Avatar
Took delivery yesterday of a Blocking Hammer from Peter Tommasini. To give you an idea of the size of this beast, the stump is 24" in diameter..
This should come in handy in making the 16 ga repair panels for the front fenders on John's Beiderman truck..
Robert
