Old 08-31-2015, 01:49 PM   #551
cad
Re: How about some pics of '73-'87 Short Beds Part II
just needs some "clearance" work done on the a-arm. it's a common thing with drop spindles. carries over into the gmt400 platform as well.
Correct, but I'd rather not modify a component that carries all of the truck's weight.
cad is offline   Reply With Quote
Old 08-31-2015, 02:41 PM   #552
SCOTI
SCOTI's Avatar
Originally Posted by cad View Post
On a lowered front end, 15" rallys with wheel weights on the inside do not work. Son knocked 2 wheel weights off turning into the driveway.
Need at least 16" wheels to clear the lower control arm.
The weights can still hit w/20" wheels if attached to the edge of the rim depending on the spindle/a-arm combo. They just make contact farther inboard on the a-arm vs a smaller diameter wheel. My 18x8" Torq Thrusts would contact the a-arm as well as some 20x8.5" Coys on my old 74. I have 2" drop spindles on my 90 w/15x6.5" van ralleys up front & the weights don't hit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-31-2015, 03:38 PM   #553
UKNOWME
UKNOWME's Avatar
I think with the right drop spindle it'll work. Western chassis spindles do not have that issue from what I've been told. You could also run tape weights instead of regular weights.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 08-31-2015, 03:48 PM   #554
OutlawDrifter
i think belltech's also push the hub out 1/2" to account for this.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-31-2015, 06:40 PM   #555
jones9j
jones9j's Avatar
I just installed bell tech 3" spindles and 2" springs. Had to cut bout 1/8" off the bottom of the control arm, for my rallys to not rub. Well worth it, in my opinion.
jones9j is offline   Reply With Quote
Old 08-31-2015, 07:08 PM   #556
BADAZ chevy guy
BADAZ chevy guy's Avatar
77 Silverado. Just got it running after 15 months. Rebuilt 1993 700R4/4L60
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 09-01-2015, 02:05 AM   #557
bbbc10
Diggin The SquareLife
i know this....I had a 5/6 drop on mine with western chassis spindles an didn't have any problems.....
bbbc10 is offline   Reply With Quote
Old 09-01-2015, 07:19 AM   #558
ms2335
ms2335's Avatar
just finished my daily driver
[ATTACH]Name:  IMG_0256.jpg
Size:  49.8 KB[/ATTACH]
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 09-01-2015, 07:59 AM   #559
Blackfox
Blackfox's Avatar
[ATTACH]Attachment 1442636[/ATTACH]
I'm a fan of blue, I wouldn't mind having a white truck with blue interior. I got my carpet installed yesterday. Very happy with ACC. Still,waiting on seat. Grrrr
Blackfox is offline   Reply With Quote
Old 09-01-2015, 07:53 PM   #560
Blackfox
Blackfox's Avatar
Did the front swap today. It'll have to wait till tomorrow to get a bath. It also needs a grill and head light bezels...only reason I went ahead with the swap was I had a buyer lined up for my old parts.
Old 09-01-2015, 07:57 PM   #561
UKNOWME
UKNOWME's Avatar
Damn you suck! I'm jealous! Was it just the header panel with grille, lamps and wiring? Used your original hood and fenders?
1964 Chevy c10
Old 09-02-2015, 06:02 AM   #562
Blackfox
Blackfox's Avatar
LOL Yep! I bought from the radiator support forward from a 91 suburban. Bolted right in and wires were a exact match. Only thing I had to do was drill two holes for the fuel canister and bolt it in. Other than that it was straight forward. Still took half a day by myself and hand tools. I love her new look though. A cowl hood and paint eventually and I'll be happy with the look. Then comes the engine swap . ( head/cam LS 6.0) May be a year or so for that, only about 32k on this motor...
Old 09-05-2015, 11:04 PM   #563
Low84
Low84's Avatar
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 09-06-2015, 08:12 AM   #564
Lambchop76
Beautiful truck!! What are the specs on the wheels and tires?
Lambchop76 is offline   Reply With Quote
Old 09-06-2015, 03:02 PM   #565
Louisianagmfs
Finally got the back end down on the 85. Its a leaf flip, drop hangar, and drops spindles with I think a 1or2" spring. Its sitting on the shocks in the pic so it will come down some more. What kind of rear shocks do you guys run with a flip?
Louisianagmfs is offline   Reply With Quote
Old 09-07-2015, 07:31 PM   #566
bbbc10
looks good....but if your rear end is sitting on the shocks an you get shorter ones like you said its gonna bring it down some an the rear might just be lower than the front.....
Old 09-07-2015, 07:32 PM   #567
Louisianagmfs
Yea its already lower by 1.5" to the fender. So I'm sure I will need more front drop, or to get stock front leaf spring hhangars.
Old 09-07-2015, 10:40 PM   #568
BLP86
Here is mine after 15yrs. in the garage apart I finally got er' done. I have put about 200 miles on it, still working out some bugs, but so far very happy.
BLP86 is offline   Reply With Quote
Old 09-07-2015, 10:42 PM   #569
Louisianagmfs
Truck looks great
Old 09-07-2015, 10:46 PM   #570
BLP86
Originally Posted by Louisianagmfs View Post
Truck looks great
Thank you very much
Old 09-07-2015, 10:54 PM   #571
BLP86
Here are a couple more. Wouldn't let me load all at one time.
Old 09-08-2015, 01:42 PM   #572
Blackfox
Blackfox's Avatar
I bought Belltech drop shocks but they bottomed out on medium sized bumps so ended up buying shock mount extensions... No problems and rides great but wish I had done a little more research in that part...
Old 09-08-2015, 04:58 PM   #573
BLP86
Louisiana,
First of all your Truck really looks great, I'm partial to your stock theme. On your question about shocks I had Duetsch brand on the rear of my truck with shock extenders but because I lowered the rear by a flip kit plus lowered rear springs the rear was lower than the front. The truck was almost level with just a hint of lower in the rear.
Front was lowered 5in. So the Duetsch shocks were replaced with Gabriel air shocks so I can raise the rear a little for a rake.
Good Luck with your truck.
Bruce
Old 09-08-2015, 05:02 PM   #574
BLP86
Blackfox,
Swap looks good, very nice truck. I like!
Old 09-09-2015, 03:15 PM   #575
81ChevyC10inSC
81ChevyC10inSC's Avatar
Here is my 81. I want to lower it and put a 5.3l vortec in it. It still has the original i6 250 with a little over 150k miles.
81ChevyC10inSC is offline   Reply With Quote
