Old 07-21-2020, 09:50 PM   #551
cwcarpenter98
cwcarpenter98's Avatar
Re: Frankentruck
Did an oil change today on the truck. Had not done one since August of 2019, so it was definitely time Last time I did an oil change, I didn't have an odometer in the truck!
I'll be doing changes based on mileage rather than months now that I have a working odometer thanks to member TBONE1964
I've also been having an issue with the starter. I think the bendix doesn't always shoot out. The reman starter that failed on me still had a good solenoid, so I swapped solenoids. Seems like it got a little better, but I wouldn't be surprised if the starter ends up dying. I'm using the starter that was on the truck when I first bought the truck. I don't think the starter has been rebuilt, but if it has, it was done well before my time
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-22-2020, 12:58 PM   #552
cwcarpenter98
Re: Frankentruck
Today's project consists of replacing knock sensors on my dad's truck. Got the intake out before taking a lunch break, so now it's time to get back to it
Christian Carpenter
Old 07-25-2020, 09:22 AM   #553
cwcarpenter98
Re: Frankentruck
I broke the fuel pressure regulator vacuum line on my dad's truck on Wednesday. Got everything back together except for that part, so I had to track it down on Thursday. Got it done and back together though!
Yesterday morning, I hopped in Frankentruck and drove down to Milledgeville for the weekend. Several years ago, before the overdrive transmission and all the work that I've done related to the drivetrain, suspension, and steering this year, I was scared to drive the truck on the interstate. I got the overdrive in last year, and that made me less scared because I could actually go highway speeds, but I was always worn out whenever I got to my destination from sawing at the steering wheel the entire drive just to keep it in a lane. Finally replaced the steering gear, since that was the last steering component that needed my attention, and I didn't have to saw at the wheel as much to keep it going straight. It was a whole lot better, but the truck was still loose when I went over heavy bumps or potholes. As y'all read earlier this month, I had the u-bolts loosening on the rear axle this entire time, so now that the axle is actually bolted in solid, the truck drives super straight, doesn't wobble around, and actually goes the direction that I point the steering wheel at. I can now comfortably drive the truck on long trips without getting super tired, and I'm not longer scared of driving the interstate.
Long story short, the truck is not done yet, but it's at a point where I can really enjoy it and take some longer road trips without feeling exhausted about half way through the trip.
Also, my new front license plate showed up yesterday! Gotta rep my C10 Georgia club
Christian Carpenter
Old 07-26-2020, 10:55 AM   #554
Johns 66
Johns 66's Avatar
Re: Frankentruck
Coming along more and more Christian.....Love It!!!!
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 07-26-2020, 12:15 PM   #555
flashed
Re: Frankentruck
Christian aint afraid to tackle anything on his trucks , love it , and his truck is just old school cool.
flashed is offline   Reply With Quote
Old 07-26-2020, 05:35 PM   #556
cwcarpenter98
Re: Frankentruck
Thanks John and John! I've still got plenty to do with it, but I've been driving and enjoying it this weekend
Christian Carpenter
Old 07-28-2020, 10:30 PM   #557
cwcarpenter98
Re: Frankentruck
I got back home yesterday around noon, ate some lunch, then pulled the bed wood out of the truck. I used a stain and sealer combo thingy when I put new wood in 3 years ago. Well, unfortunately, that product was not up to the task, so I need to refinish it again. This time, I'm going to use the same stain/sealer as before, but also put an additional sealer on top. Hopefully that will work better.
I started working on sanding the wood today to remove the dirt, grime, and old stain. It will probably look a little different than when I first installed the wood 3 years ago, but that's ok.
I did find one rotted board. The driver's side rear corner piece that goes under the flange got soft right under the flange. I think I might have scratched off the stain by accident when I was installing it 3 years ago. Good thing I kept all the scrap pieces because I still have a piece to replace it with.
The board leaning up against my truck all the way to the left is the rotted out piece. The bottom side of all the boards lasted pretty well since they were not exposed to the sun. The board on the saw horses has not been sanded at all. The board on top of that one has been sanded
Christian Carpenter
Old 07-29-2020, 07:42 AM   #558
Johns 66
Johns 66's Avatar
Re: Frankentruck
Christian...the issue is heat and water....the sun and the heat from your truck wreaks havoc on wood and unfortunately it will continue.
There are a couple of things you can do to slow down the process.
First option is to not use pine simce pine is a softer wood, but no matter what wood you use this will become a periodic thing.
Secondly use a penetrating oil...like tung oil, linseed oil etc....this will penetrate into the wood and help protect it.
Lastly you will need to seal the wood on every edge and flat surface.
Water gets on the wood and it soaks it up, then the heat dries it out causing damage each time.
Something like a Spar Urethane works pretty good.
This wood is no different than wood put on houses, fences, decks etc...
If you look at cross ties and telephone poles it lets you kinda see what different types of preservatives do. While I dont recommend either chemicals used on telephone poles or cross ties, it kinda gives you a reference point to go from....especially if your truck sits outside and is exposed to the elements day in and day out
2019 GMC AT4
Old 07-29-2020, 08:56 PM   #559
cwcarpenter98
Re: Frankentruck
Thanks John, that's some new knowledge to pack in the ol' noggin. What about using some sort of marine boat wood sealer?
Christian Carpenter
Old 07-30-2020, 06:44 PM   #560
Johns 66
Johns 66's Avatar
Re: Frankentruck
I would use some type of penetrating oil suck as tung oil, boiled linseed etc....I would mix it 50/50 with thinner. This allows the wood to soak up the oil....I would do it a couple of times for sure...the thinner evaporates but allows the oil to get deep in the wood...once it dries then I would put a protective coating on it like Spar Urethane, etc....
The heat will pull the oil out of the wood over a period of time and you will need to reapply, but the oil should protect it from the elements..
On my wood I did 3 coats of tung/thinner mix and then applied many coats of spar urethane on mine...looks like glass now.
I have been tempted to put some epoxy on some wood just to see how it will fare outside...just hadn't had time lately.....Still steadily chasing bolts...lol
2019 GMC AT4
Old 07-30-2020, 09:40 PM   #561
cwcarpenter98
Re: Frankentruck
That epoxy might be a good idea.
For now though, since I'm somewhat on a time crunch to finish up the truck before I go back to school, I'm using the same stain/sealer combo that I used the first time, but instead of doing just that, I'm going to also put some sort of actual sealer on top of that. Would the Spar Urethane be a good choice for that?
Today, I finished sanding down the boards. The underside of the boards still looked good in most places, so I put one coat of the stain/sealer down just on the back side. Going to be doing at least 2 coats of the stain on the top side starting tomorrow, then whatever sealer I use will start going down over the weekend or next week
Christian Carpenter
Old 07-30-2020, 09:43 PM   #562
Johns 66
Johns 66's Avatar
Re: Frankentruck
Looks good..Spar Urethane will be just fine
2019 GMC AT4
Old 07-30-2020, 10:31 PM   #563
flashed
Re: Frankentruck
Looks great Christian .
Old 07-30-2020, 10:41 PM   #564
cwcarpenter98
Re: Frankentruck
Thanks John, I'll be picking some up this weekend.
Thanks! How's your stepper coming along?
Christian Carpenter
Old 07-30-2020, 10:53 PM   #565
flashed
Re: Frankentruck
Im still taking the control arms apart , Im a rookie at that and found no help here with my questions . Im so Dang close to having the frame and everything else ready to send out for sandblasting and paint . So Close , more tomorrow after work .
Old 07-30-2020, 11:00 PM   #566
cwcarpenter98
Re: Frankentruck
Shoot me a text on the control arms if you haven't figured them out yet. I can't wait to see it all shined up!
Christian Carpenter
Old 07-31-2020, 09:38 AM   #567
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Frankentruck
Bed wood is looking good. Tell me again what you are studying is school?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-31-2020, 09:41 AM   #568
roll_the_dice
roll_the_dice's Avatar
Re: Frankentruck
He should be teaching post graduate classes in truck repair and restoration. Great job Christian!
roll_the_dice is offline   Reply With Quote
Old 07-31-2020, 03:35 PM   #569
Johns 66
Johns 66's Avatar
Re: Frankentruck
Next time Im at my cousins house Im gonna see if I can find you some old Barn Wood for your bed....I think it would look killer.
2019 GMC AT4
Old 08-01-2020, 12:15 AM   #570
cwcarpenter98
Re: Frankentruck
Thanks! I am studying accounting.
Haha, thanks Andy, but I don't think I have enough knowledge to do that yet
Thanks John, I appreciate the offer, and I think it would look cool, but I'm going to stick with the wood I have for now. Yeah, it's white pine, so not the strongest, but my dad and I were on a budget and time crunch when we did it 3 years ago, so we decided to use the white pine, then ripped it to size, used a small router to cut the grooves, and stained it. It was a fun project living up to our last name
Christian Carpenter
Old 08-01-2020, 12:24 AM   #571
cwcarpenter98
Re: Frankentruck
So a big life decision happened today. I accepted an internship offer at a CPA firm for the 2021 tax season. I'll be diving into the world of public accounting from January to April. I was blessed to have 3 firms to choose from, and the decision was a tough one, but I feel like I made the right choice.
I spent all morning and several hours into the afternoon making the decision, and then I also spent some time selling some parts locally. Didn't get anything done on Frankentruck, but I started replacing the AC compressor on my Dakota. The clutch went out on it a couple weeks ago, and I couldn't find just a clutch without grabbing a junkyard one, so I went ahead and got a new one. That'll be finished up tomorrow, and I hope to get one coat of stain on the top side of the boards
Christian Carpenter
Old 08-01-2020, 10:00 AM   #572
roll_the_dice
Re: Frankentruck
Congratulations Christian! One of the Big 4 Accounting firms? There are 7-8 accountants in my family. A great profession. My son was majoring in Accounting, but changed to Finance this past year. He had a somewhat weird internship this summer...2-3 days a week for about 6 hours a day.
Old 08-01-2020, 02:06 PM   #573
Johns 66
Johns 66's Avatar
Re: Frankentruck
AwesomeChristian...so very glad and proud of you.
2019 GMC AT4
Old 08-01-2020, 11:18 PM   #574
cwcarpenter98
Re: Frankentruck
Thanks guys, I'm excited for it!
Christian Carpenter
Old 08-01-2020, 11:23 PM   #575
cwcarpenter98
Re: Frankentruck
Got the AC working in the Dakota again today. Also got a coat of stain on the top side of the boards. Going to get some sealer for them tomorrow and probably start on that on Monday
Christian Carpenter
