#576 | |
Still plays with trucks
Re: 67 cheby's Dropmember build thread
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#577 |
That looks MUCH better. Those will look great once finished out.
#578 |
Under Construction
I like it...... transitions alot better.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#579 |
67cheby
![]() Join Date: Sep 2008
thanks for all of your input , it is appreciated, this was my last idea , so hopefully it will turn out looking right, im thinking about shooting it with a quick coat of spray paint ,satin black , so i can get a little beter idea of what it will look like finished, the fenders flare in the front and rear, which is kind of cool because it gives extra turning room
#580 | |
#581 |
67cheby
68tt i havent forgot about the measurements for you, i just need to figure out for sure which way to measure what you are looking for
#582 | |
You can use your bed mount rails as a reference point to see how close it will be to the bed floor if you don't have the bed on or available. If the diff is not going to poke through the bed at the resting point you want to achieve then it might be worth the effort to rework the frame notch structure to try to get it all below your relocated bed floor.
#583 |
MUCH better!
#584 |
67cheby
is "much better" good or is much better, "they looked like crap before so they couldnt get worse this is an improvement"??
#585 |
Now that is using your noggin. Fantastic job!!
#586 |
67cheby
i didnt think that my love for vws would ever have any effect on my Chevy .....but hey , i guess you never know, what some crack head will dream up, it should be a fun conversation piece at shows
#587 | |
A little contouring at the forward transitions to the original inner fender will finish the look. You are on the right track and making good progress.
#588 |
![]() Join Date: Jul 2006
You nailed it, much more subtle.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#589 |
67cheby
Thanks Leevon and i am serious about the help , just let me know
#590 |
great idea i wouldnt have come up with it unless i had the stuf laying around and would be in a creatve mood , it looks a lot more like it belongs there than a trailerfender , i wouldnt be suprized if there more people that going to use this trick in the furure
i've seen sumtin simulair used once when the set an engine back inside a car and needed to put the firewhall back they used part of the bucket of a wheelbarrow they just cut it to size welded it up and they where done in no time flat , looked good too with the compound corners on the bucket and all that
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 08-25-2010 at 08:57 PM. |
#591 | |
67cheby
#592 |
Damage Inc
looks good
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
#593 |
Looks like it is about 9" above the top of the frame rail at the center line of the axle. How tall is the frame notch?
#594 |
It is really starting to take shape. That little change to the wheel wells really made a big difference. Great work.
#595 |
67cheby
thanks, i have alot of work left but im getting there!!
#596 |
Man, that is one great lookin' air cleaner.
Rex |
#597 |
67cheby
Thanks there is a great story behind it maybe i will tell you about it sometime !!LOL
#598 |
![]() Join Date: Jul 2010
Looks Great! Keep them pics coming!
#599 |
![]() Join Date: Nov 2008
looks great really coming along
#600 |
67cheby
Thanks Blacktop and Superfly , i appreciate the response..kinda keeps me motivated
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
