02-26-2015, 11:56 AM | #576 |
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
I notice your frames PC Im gonna have my PC also but the only thing that worries me is the ground straps. Did you have trouble getting the PC off of the frame for the strap? And what did you use to get it off?
THanks Rich.. |
02-28-2015, 05:32 PM | #577 |
I've had no grounding issues. I used an 80 grit flapper wheel in my die grinder to remove the PC. The same way you would remove paint from your frame. Good luck.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
03-01-2015, 11:43 PM | #578 |
I installed the front light kit on my AAW harness this weekend and got most of the cab wired up.
03-01-2015, 11:47 PM | #579 |
Pic 2
03-02-2015, 12:07 AM | #580 |
Another pic
03-02-2015, 11:18 AM | #581 |
Coming along nicely. I like the AAW kits... It was easy to install for a rookie. I had never wired an entire vehicle before, but it was pretty simple. The hardest part was deciding where to run all the wires. It looks like you're doing a good job so far.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-02-2015, 03:13 PM | #582 |
03-03-2015, 06:03 PM | #583 |
Looking good! the wiring is fun to me. I'm kookie, though.
Just wanted to stop by and say thank you for all the question answering on the air filter set up. Using the truck brackets and intake I had to switch the tube around the other way, but I got it in! I may make it shorter but not fully decided yet.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
03-04-2015, 09:46 PM | #584 | |||
03-04-2015, 09:55 PM | #585 |
Here is a close up picture of the VHX control box which I will be mounting in my glove box along with my ECM/fuses/relays. I will add another picture once I finish the install.
03-04-2015, 11:16 PM | #586 |
Extremely bad$$! Keeps getting better man
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
03-04-2015, 11:45 PM | #587 |
Roto Reuter thats the name...
You'll be happy with the VHX gauges. I'm curious, what are you planning to do with the two push buttons used for setup? The VHX with digital clock has 3-push buttons installed on the center gauge. When you go to the analog clock, you have wire in the setup buttons. I have the VHX gauges with digital clock on my 69, so I didn't have to wire up the setup buttons. My next gauges will be the same ones you are installing.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-11-2015, 10:17 PM | #588 |
I know the VHX set comes with a water and oil sender. Do they also tie back into the LS ECU? Or is it Un needed?
03-12-2015, 09:22 AM | #589 |
Oil sender is only for the gauge on all LS engines from what I can tell. I have a 4.8 from a 2000 Silverado and while it plugs into the harness, it does not send to the ECM, just the gauge. I believe water is serial data from the ECM to the dash in most vehicles.
03-12-2015, 11:47 AM | #590 |
If you look at my build, you will see what I did to get everything to work. I have two sensors for waste and oil. If you try to use the ls senders you will get inaccurate readings for your gauges abd if you use the vhx senders for your ecu then your ecu will read inaccurately. It is best to just run two sensors since it isn't that difficult
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
03-12-2015, 01:19 PM | #591 | |||
Thanks!
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 03-12-2015 at 04:50 PM. |
03-12-2015, 02:37 PM | #592 |
ooh, fancy!
03-12-2015, 03:02 PM | #593 | |
03-12-2015, 03:03 PM | #594 |
Thank you for all the help, guys!
03-12-2015, 03:49 PM | #595 |
Wow this build is off the hook, I really need to sit down and read it all the way through.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
03-16-2015, 10:57 PM | #596 | |
Thanks....
Awesome compliment thanks!
03-31-2015, 10:43 AM | #597 |
Ok, man! Hows the progress coming? Got your new bed parts yet?
04-01-2015, 09:07 PM | #598 |
Thanks for asking. Well, I finished up all of my chassis wiring minus the rear tail lights. Finished wiring up my gauges. I sent my front cross sill's out for PC and should be done early next week. My painter finished painting the front bed panel and rear cross sill. The next step is ordering my bed wood, stainless steel wear strips and bolt kit so I can start assembling the bed.
04-02-2015, 03:44 PM | #599 |
Good deal, just checking to make sure you werent dead!
04-02-2015, 04:25 PM | #600 |
Right..lol
Also redid my backyard for the wife before the 100 degree weather hits.
