Old 11-09-2013, 12:14 PM   #576
chevyrestoguy
chevyrestoguy's Avatar
Re: Project Goldilocks, '66 C10 SWB BBW Build
John is one talented guy, and I always look forward to any updates on his threads. He's my favorite builder on this site because of his attention to detail and the fact that he doesn't run to the catalog when it's time to put something together. He thinks outside the box, and he concentrates on stuff that 95% of the people out there will never catch because it's done so well. My kind of builder.
I have told him many times that if I ever won the lottery, I'd keep him busy until he retires!!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 11-13-2013, 07:23 PM   #577
theastronaut
theastronaut's Avatar
Originally Posted by duallyjams View Post
I think you should change your user name to the MACHINE as it is unbelievable of all the builds you have going at the same time and all of them are over the top with attention to every little detail.
And this is what John does in his spare time, I sent him a air cleaner lid to convert it to a dual snorkel.
Attachment 1172673
Glad to do the air cleaner for you! It's getting harder to keep up with all the build threads since the International is back and I'm working on 'locks more.
Thanks a ton Alex, you do top notch work and it means a lot that you follow and dig what we're working on. Hurry up and cash in!
theastronaut is offline   Reply With Quote
Old 11-13-2013, 07:43 PM   #578
Dinos63
chevy only
Dinos63's Avatar
100% love your work always such a craftsman
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 11-13-2013, 07:48 PM   #579
theastronaut
Picked up a couple parts, a NOS reverse lens (need a matching one for the other side still) and a pair of new LCA shafts.
I'm not crazy about how much the shafts weigh but I guess there's nothing to do about it. I did weigh the No Limit rack kit and it's roughly 25 pounds lighter than the old steering system, and the CTS-V calipers are surprisingly 2 pounds lighter each than the old calipers. So I've taken almost 30 pounds off the front axle already. The rotors will be much lighter than the originals since they're dual-cast (aluminum hat, iron rotor), and will have separate aluminum hubs compared to the old solid cast iron rotors.
Since I have the LCA shafts, I'm looking into bushing materials for the A-arm shafts. I don't want urethane, it squeaks and I doubt that it's tough enough to use for such a highly loaded bushing. Been searching over the McMaster Carr website and either Delrin or UHMW Polyethylene look like good choices. I don't like that the bushing can rotate against the outer washer/nut so I'm thinking about adding thrust bearings at the ends of the bushing material. That should keep the bushing from binding against the outer washer and possibly loosening the nut over time. It's just an idea for now. I'll talk to a machinist buddy before making a decision.
Old 11-13-2013, 08:08 PM   #580
theastronaut
Thanks Dino!!
Old 11-14-2013, 10:43 AM   #581
chevyrestoguy
Are you planning to do the caster mod on your LCAs while you've got them out?
My build threads:
Old 11-14-2013, 11:08 AM   #582
theastronaut
Yes, going to relocate the ball joints to move the wheels forward 1" and tilt the spindle for around 7-8* of caster with that being the center of adjustment. I'm also going to make either a screw jack type bag mount, or just use shims under the bag so I can adjust bag pressure (spring rate) then adjust the bag mount to keep my ride height and alignment in spec. That way I can also balance the corner weights.
Old 11-14-2013, 11:18 AM   #583
jdoisher
jdoisher's Avatar
I wish we lived next goor to each other! I'm a good helper and love to learn, you are on a whole other level!!! As always, awesome work!!!
Jason
http://67-72chevytrucks.com/vboard/s...d.php?t=531177
Maggie's truck!
jdoisher is offline   Reply With Quote
Old 11-14-2013, 01:20 PM   #584
Hellion Customs
Hellion Customs's Avatar
Following quality work on an awesome build.... I really like the write up on detail sanding. It shows why quality prep takes time and skill, which cost money.....
Make sure you post up pics of the front suspension setup & build!!!
Hellion Customs is offline   Reply With Quote
Old 11-16-2013, 02:19 PM   #585
theastronaut
Jason
That's what's neat about forums, you can see what people are working on from all over.
Appreciate it! I'll definitely post the front end build. Can't wait to see the Tahoe build unfold!
Old 11-16-2013, 02:26 PM   #586
theastronaut
Found a '66 short/fleet, going to pick it up this afternoon.
Old 11-16-2013, 04:57 PM   #587
duallyjams
duallyjams's Avatar
REALLY ! you lucky whatcha gonna do with it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-16-2013, 05:21 PM   #588
pdxhall
pdxhall's Avatar
Great find. Looks like custom all the way from the outside. What's the inside look like?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-16-2013, 05:25 PM   #589
Bomp
Bomp's Avatar
Another one Saved!!!
Bomp is offline   Reply With Quote
Old 11-16-2013, 06:46 PM   #590
theastronaut
Just gunna get it on the road and cleaned up. The inside needs a lot of cleaning, I'll post pics when its cleaned up. Prolly hang onto it until tax return season then sell it.
Busted out the pressure washer to knock the worst crud off.
Old 11-16-2013, 07:10 PM   #591
duallyjams
duallyjams's Avatar
Well I have a 64,65, ,67 and just bought a 68 I need a 66 to fill in the gap.
James
IG duallyjams
Old 11-16-2013, 10:11 PM   #592
abraham.hd
Sick ass build, keep up the Good work
abraham.hd is offline   Reply With Quote
Old 11-18-2013, 10:06 AM   #593
LoRollinLS
LoRollinLS's Avatar
Congrats on the new 66. That thing looks great all cleaned up. Does it run and drive well?
LoRollinLS is offline   Reply With Quote
Old 11-18-2013, 01:05 PM   #594
likaroc13
Rollin' Old Skool
Congrats John! I saw your post on Facebook, & I think I even "liked" it. I didn't realize it was you at the time though.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 11-18-2013, 11:53 PM   #595
theastronaut
Thanks dudes. It doesn't run yet, no gas getting to the carb. I'm picking up a new tank Wednesday so I can get started on the fuel system. It'll run off starting fluid, no ticks or knocks and has good oil pressure. I started a build thread for it to keep from clogging up Goldilocks' build.
http://67-72chevytrucks.com/vboard/s...d.php?t=604632
Old 11-19-2013, 01:10 AM   #596
mcbassin
Still Learning
mcbassin's Avatar
That looks like a really nice truck! congrats on the score. Too bad you're not building it too. You have a full plate already though.
mcbassin is offline   Reply With Quote
Old 12-23-2013, 03:00 PM   #597
daveshilling
daveshilling's Avatar
Updates?! I firmly believe that you wake up every morning and work on your trucks until bed time. No job, no nothing, just fabbin.
daveshilling is offline   Reply With Quote
Old 12-23-2013, 04:52 PM   #598
theastronaut
I wish! Gotta work on our customer's trucks all day. I'm looking into front spindles now so I can mock up temporary A-arms. That'll let me map out the changes I want to make, and translate those dimensions to a jig. Probably going with CPP since they have separate caliper mounts and hubs are available for slip on rotors.
Old 12-23-2013, 06:36 PM   #599
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Nice truck! It washed up nicely!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-28-2013, 11:54 PM   #600
theastronaut
Picked up a pair of 283 air cleaners from member Southern Parts this morning. Not going to use them, but needed them for the snorkels and also to study the stamping designs so I can work them into the cleaners I'll make for the Webers.
