12-09-2021, 07:27 PM | #576 |
Re: The 60-66 "PAYING IT FORWARD" thread!
Id like the shop manual, and the steering box if still available.
I have a job interview in Palo Alto on Friday afternoon, but would be headed down south through Mountain View if I could pick up on Saturday AM. Thanks, Keith
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
12-09-2021, 08:47 PM | #577 |
01-13-2022, 11:53 PM | #578 |
I have two good original wire harnesses that need new homes. One from a 66 K20 and one from a 62 C20. The wires and connectors are in good condition. They both have the dash and engine portions. Neither one has a complete harness to the rear.
The 66 had gauges and hazard light switch. The 62 had idiot lights.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 Last edited by 72cs20; 01-14-2022 at 06:56 PM. Reason: Clarification |
01-13-2022, 11:59 PM | #579 |
All from a 1964 C10:
* Used master cylinder - Single reservoir original type * Approximately 2 year old used master cylinder - Single reservoir original type * Used OEM track bar * Radiator. Has leak Local pickup only.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
01-14-2022, 12:46 AM | #580 |
I need the 66 wiring harness. Mine is all taped up and ready to start a fire.
01-14-2022, 06:57 PM | #581 | |
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
01-14-2022, 07:00 PM | #582 |
New repro 64-66 2wd gas pedal.
01-14-2022, 07:20 PM | #583 |
I posted these awhile back and had no takers. Here goes again.
Four hub caps from a 62 C20 with 17.5 tubeless wheels. Five 17.5 tubeless wheels with good clips for the caps. I can ship the hubcaps. The wheels need to be picked up. For the wheels - If no arrangements are made or they are not picked up by the end January, they're off to the recycler. I'm cleaning house. Located in Los Gatos, Ca.
01-14-2022, 08:40 PM | #584 | |
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 01-14-2022 at 09:01 PM. |
01-14-2022, 09:28 PM | #585 |
They're yours. PM me your shipping info.
01-14-2022, 10:32 PM | #586 | |
01-14-2022, 10:51 PM | #587 |
If you really want them, I foresee a road trip in your near future
01-14-2022, 11:07 PM | #588 |
PM sent with shipping info. Thank you!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-16-2022, 05:19 PM | #589 |
* Used master cylinder - Single reservoir original type * Approximately 2 year old used master cylinder - Single reservoir original type * Used OEM track bar * Radiator. Has leak * Left and right doors.
01-16-2022, 06:36 PM | #590 |
72cs20, I'll take the 62 wire harness if it's still available.
01-16-2022, 06:55 PM | #591 |
It's yours. PM me your shipping details.
01-22-2022, 03:44 PM | #592 |
72CS20 just got the wiring harness today! It's in great condition and I can even read the lettering on the fuse block! Already got my fire-hazard wiring out. Going to get on cleaning this one up and ready for install. Thank you very much. Good looking out!
01-22-2022, 06:29 PM | #593 |
Great! Glad to help.
01-24-2022, 11:32 PM | #594 | |
Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
01-24-2022, 11:46 PM | #595 | |
Andy |
01-25-2022, 11:34 AM | #596 | |
Thanks Tom
01-25-2022, 02:16 PM | #597 |
Yes, I am in MV near SF. I'll send a PM.
01-25-2022, 02:39 PM | #598 |
PM sent.
01-28-2022, 07:41 PM | #599 |
01-31-2022, 08:52 PM | #600 |
