Old 02-09-2014, 12:47 PM   #601
Bigru
Bigru's Avatar
Re: How about some pics of bagged 60-66
There's some bad ass bagged trucks on this thread. I'm getting motivated...Nice!
Bigru is offline   Reply With Quote
Old 02-15-2014, 08:17 PM   #602
Desert.Chevy
Desert.Chevy's Avatar
Originally Posted by FlowerForwarder View Post
1965 c10 swb Bagged
Stock Cross Member and Stock Arms.
Stock Bed Floor Height.
Clean truck!
Do you have a build Thread or more pictures?
Thanks.
Desert.Chevy is offline   Reply With Quote
Old 02-16-2014, 04:26 AM   #603
Jmorales3181
Jmorales3181's Avatar
Haven't posted in a while here are my Most recent pics....
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 02-16-2014, 09:31 AM   #604
FlowerForwarder
Originally Posted by Desert.Chevy View Post
Clean truck!
Thanks.
In the front we weld the flat bottom plate, then the top flat plate we notched so the bag would fit inside when deflated. We did take pictures. The fronts also drop spindled too. It sits the front flat on the ground and the tires touching the factory inners with a 215/70/15. I used the bigger Firestone bag on the front just cause it collapses down better the the AirLift bag.
In the rear we build our own weld in notch, I plate the inside rail for strength and use a 6.5" inside diameter pipe to fit the axle and u-bolts into a little better. I spent a little time with it on the rack just grinding little issues to make sure everything cleared the way I wanted it to. Has a 2" block, Airlift Bags stock locations, Rear end goes thru the bed floor (no kissing it here). But still not crazy like I'm use too. But I think we trimmed it off nicely!!!
Double switch panel, dual needle gauges, 5 gallon tank, 2- ViAirs 444s, 175 pressure switch.
FlowerForwarder is offline   Reply With Quote
Old 02-19-2014, 12:40 PM   #605
CMFT
CMFT's Avatar
Stock cross member truck, tubbed front inner fenders, C-notched, custom 2-link, plated LCA's, drop spindles.
'58 Apache
CMFT is offline   Reply With Quote
Old 02-19-2014, 03:40 PM   #606
tjabv2
very nice!!!
tjabv2 is offline   Reply With Quote
Old 02-19-2014, 04:05 PM   #607
Desert.Chevy
In the front we weld the flat bottom plate, then the top flat plate we notched so the bag would fit inside when deflated.We did take pictures.The fronts also drop spindled too. It sits the front flat on the ground and the tires touching the factory inners with a 215/70/15. I used the bigger Firestone bag on the front just cause it collapses down better the the AirLift bag.
Ok cool, you said you did take pictures, could you post some or if you have a build thread a link to that. Thanks
Good looking truck!
Do you have a build thread? If not please post more pictures.
Originally Posted by tjabv2 View Post
very nice!!!
I agree!
Old 02-19-2014, 05:05 PM   #608
CMFT
CMFT's Avatar
Good looking truck!
I agree!
Link to build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=600003
'58 Apache
Old 02-19-2014, 05:33 PM   #609
likaroc13
Rollin' Old Skool
Nice!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 02-20-2014, 11:26 AM   #610
likaroc13
Rollin' Old Skool
Saw these via Facebook:
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-20-2014, 06:16 PM   #611
lowslow64
lowslow64's Avatar
Here's mine; stock A frames, RideTech Level 1 with E3, C-notch, drop spindles.
lowslow64 is offline   Reply With Quote
Old 02-20-2014, 07:02 PM   #612
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Nice
Sick5 is offline   Reply With Quote
Old 02-20-2014, 08:48 PM   #613
HumphreyMurdoch
HumphreyMurdoch's Avatar
Wow I really like that orange! Black scallops look awesome with the white break.
Fantastic truck!
HumphreyMurdoch is offline   Reply With Quote
Old 02-20-2014, 11:25 PM   #614
CMFT
CMFT's Avatar
That bed is sexy! Excellent job
'58 Apache
Old 02-21-2014, 02:49 AM   #615
**grumpy**
**grumpy**'s Avatar
We moved in October and just finally got the garage in order. So time to tear my 61 apart.
It's bagged now but I want to redo some stuff.
Road Hounds
**grumpy** is offline   Reply With Quote
Old 02-22-2014, 12:52 AM   #616
j.walters
j.walters's Avatar
My 64
j.walters is offline   Reply With Quote
Old 02-23-2014, 08:05 PM   #617
NEWFISHER
NEWFISHER's Avatar
Mines in the weeds lol
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-23-2014, 08:09 PM   #618
FlowerForwarder
You can get it lower!!!
Old 02-23-2014, 08:35 PM   #619
NEWFISHER
NEWFISHER's Avatar
Ya, don't want to cut up the bed floor. My 105lb dogs need all the bedside they can get when I take them.
GOD BLESS AMERICA!
Old 02-23-2014, 10:31 PM   #620
likaroc13
Rollin' Old Skool
Cool pic!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-24-2014, 12:57 PM   #621
Bigru
Bigru's Avatar
Nice! What's your specs if you didn't raise the floor?
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Old 02-24-2014, 02:45 PM   #622
NEWFISHER
NEWFISHER's Avatar
Mild rear C notch with 5 1/2" pipe, rear 2" blocks, front 2" spindles and a bag kit from Borris aka way2lo2.
The rear diff touches the bed floor and just presses slightly on the boards. I have another 1 1/2 inch in the notch, but don't really want to open up the bed floor. I found a cool old diff cover and had it line x'ed fill the hole if I cut it and then pocket my LCA's or get a set of tubular arms and drop it another 1 1/2".
GOD BLESS AMERICA!
Old 02-28-2014, 01:24 AM   #623
60apache
60apache's Avatar
here is my 1960
60apache is offline   Reply With Quote
Old 02-28-2014, 01:30 AM   #624
NEWFISHER
NEWFISHER's Avatar
^^^ Bad A$$$$$$!
What method did you use to bag it, are you cutting the bed now? What are your wheel tire specs?
GOD BLESS AMERICA!
Old 02-28-2014, 01:47 AM   #625
60apache
60apache's Avatar
20x8.5 only thing I did to the bed was cut out a square for the chunk to come up in the bed. tires are 245 35 in the front and 275 30 in rear
