Old 09-14-2012, 01:28 PM   #6426
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread (CLOUD 9)
Thanks guys, just talked to my Upholstery shop McClellands Auto Upholstery he has my dash pad done and is working on my door panels today !! WOOO HOOOOOOO ! cant wait !!
67cheby is offline   Reply With Quote
Old 09-14-2012, 04:19 PM   #6427
watahyahknow
watahyahknow's Avatar
maibe you need a tan a mohawk and some gold chains
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-14-2012, 05:30 PM   #6428
bodydropped68
bodydropped68's Avatar
Originally Posted by 67cheby View Post
a BIG THANK YOU to Paul Church...i now have a hole in my dash filled !
Thanks for the shirt and other swag Mike it just came in the mail today. Can't wait for the day when I need some Slosh Tubz. Keep up the great work and thanks again for the shirt it will be seen at the show. Later Paul
bodydropped68 is offline   Reply With Quote
Old 09-15-2012, 04:50 PM   #6429
67cheby
67cheby
67cheby's Avatar
Thank you man ! Ok Question, obviously i have the wrong piece here anyone have the right one ? I also am looking for the little retainer clip that goes on the end of the steering column that holds the metal end cap in place ?
Old 09-15-2012, 05:34 PM   #6430
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
U check with classic parts of America? They have all sorts of those little parts
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 09-15-2012, 05:35 PM   #6431
67cheby
67cheby
67cheby's Avatar
yes i am actually picking up my windshield and back glass from them on monday, they dont have either part in their catalog ?
Old 09-15-2012, 09:03 PM   #6432
tantrumpipeline
ask when you're there, I'm finding with a lot of these suppliers they miss small things like that, I can't wait to see this truck done, getting so bad I have buddies at work that are into 67-72's from my constant blabbing about mine and showing them yours, so badass, there should be a warning when you enter the site.......this site contains an addiction for which there is no cure, enter at your own risk....got it on my sled trailer lol
20 Duramax tow pig
52 short project
Old 09-16-2012, 12:53 AM   #6433
Xeen
Xeen's Avatar
Here is a picture of a 1968 non-tilt column at the area in question, apparently there are some differences between 1967-68 Columns because mine doesnt have those slots cut in it under the wiring loom shield like yours.
I dont know if this is helpfull at all but I thought it couldnt hurt to have a good reference picture.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-16-2012, 08:00 AM   #6434
67cheby
67cheby
67cheby's Avatar
Cool thanks for the reference
Old 09-16-2012, 10:43 AM   #6435
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Hey Mike, have you figured out your column issue? I have a 67, and 68 non tilt columns, and they both have the same wire cover and two small tabs that it slides under. I couldnt find slots like yours anywhere on either column. Hope you already have it sorted out.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 09-16-2012, 02:50 PM   #6436
Xeen
Xeen's Avatar
A couple of questions that could clear up a few things for us.
Is it a 1967 GM Truck Column, 36"L X 3/4" OD shaft?
Is it a genuine GM column or a Reproduction?
Is it tilt or non-tilt?
A little more information would be helpfull.
Im sure there are tons of experts on here that could help you with this, now if we could only get them to chime in.
Old 09-16-2012, 02:53 PM   #6437
watahyahknow
could it be that the slots are for tabs that are on the original cover itself?
it might be that the cover sticks in on one end and get screwed tight on the other end or that the tabs are hooked and on both sides and you need to push it in untill the tabs fall in the holes and the setup click shut , it would make more sense in a factory setup than using 4 clips to hold it down
Old 09-17-2012, 09:12 AM   #6438
67cheby
67cheby
67cheby's Avatar
nope not yet ?? i dont know , anyone else have any input ?
it is a genuine GM column and it is tilt
I dont know i will look ?
Old 09-17-2012, 09:19 AM   #6439
67cheby
67cheby
67cheby's Avatar
Sorry i have been slacking on updates so here are a few, Interior lights working, wipers working, installed the PAINLESS courtesy lights, Spal fan contoller installed, front clip completely wired, DELTA Hid's done, Complete wiring harness 90 % done includes Painless 18 circuit wiring, Painless EFI wiring, Spal fan controllers, Delta HID harness, Accu-air, Vintage air, and the DAKOTA DIGITAL VHX dash setup ......i have been wiring and plumbing for 2 weeks now about 1 week and the truck should be ready to fire up !! here are a few pics !
Old 09-17-2012, 09:27 AM   #6440
67cheby
67cheby
67cheby's Avatar
and a few more, all the wire on the whole truck will be wrapped with PAINLESS CLASSIC Braid loom...this stuff is so cool has that cloth factory look but it is split like the plastic loom and wraps around the wires...it is too cool, here is a quick run of it that will be tucked behind my fender, i didnt spend a ton of time on it here since it will all be hidden. I used 6 way wiring plugs to make the front wiring able to disconnect if the front clip needs to come off. Also working on ac lines, in the process of blacking out the aluminum lines to make them disappear and on my third set of AC to compressor lines trying to achieve the look i want (i am still not thrilled ) I just got in my new bed reinforcement strips last week i will be running them in place of the standard cross braces (because they are shorter to go with the bolt on body drop) i ordered the ones without holes so we could tighten up the factory gaps in the wood...a little to wide in my opinion !
Old 09-17-2012, 09:44 AM   #6441
smartass12
smartass12's Avatar
Your truck is amazing as you've been told a thousand times, been following it since i joined. A couple questions if you had a minute...Your fuel cell is set up for fuel injection right? I really like the price point compared to others (these builds add up quick). Second, it seems you completely scraped the old wiring and your rewiring all new? Just wanted to know if i cant throw away all my old wiring.
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 09-17-2012, 09:50 AM   #6442
67cheby
67cheby
67cheby's Avatar
The cell does have a return line and yes i am running an outside fuel pump...i hope it works well we will see ! And yes i went to it because of price also , i hope that doesnt bite me later..LOL ! As for the wiring, it just depends on what all you will be running on your truck i have so many different things to power up that i needed to go to the 18 circuit wiring harness ...and of course the fact that PAINLESS sponsored my truck sure helped ALOT !!! I would deffinately recommend their product, very straight forward install !....quite PAINLESS...LOL
Old 09-17-2012, 09:57 AM   #6443
smartass12
smartass12's Avatar
When you say bite you (fuel cell) should i wait to order it? Now you have me worried...Im sure i will need a PAINLESS as well with air management and such...speaking of which i guess im going to have to bite the bullet and call Nate..time to order more stuffhttp://67-72chevytrucks.com/vboard/images/smilies/crazy.gif
Old 09-17-2012, 10:00 AM   #6444
67cheby
67cheby
67cheby's Avatar
well if you are going fuel injection i would think the ideal thing would be a tank with the fuel pump in it , this keeps the pump cool ! Plenty of people have done it with an outside pump like i am doing so it will probably be fine i would just prefer to go the other way...but price wise this was far cheaper ! i hope it works i will know soon ! anyone else have any input on this ?
Old 09-17-2012, 10:14 AM   #6445
oldman3
oldman3's Avatar
Mike, everything is looking super and moving right along, nice job...Jim
oldman3 is offline   Reply With Quote
Old 09-17-2012, 10:16 AM   #6446
67c10rustbuket
67c10rustbuket's Avatar
Here is the right wire cover mikey I didn't know tilts were different either, learn something new every day! Truck is looking great btw!
http://www.brotherstrucks.com/prodin...number=WHC6772
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 09-17-2012, 10:18 AM   #6447
big_al_71
big_al_71's Avatar
It's almost alive!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-17-2012, 10:23 AM   #6448
67cheby
67cheby
67cheby's Avatar
AWESOME...thanks !!
SOON .....VERY SOON !
Old 09-17-2012, 11:37 AM   #6449
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Are you going to be able to charge the a/c with the high and low side ports facing down?? It all looks great!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 09-17-2012, 11:44 AM   #6450
67cheby
67cheby
67cheby's Avatar
They arent crimped on yet just mocked up , will this be a problem ? I just thought it looked better ?
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
