Old 04-09-2011, 10:20 PM   #626
tommys66
Re: Shrunken66Stroker's build thread.
Great job on the wheel tubs, I like. Those seats look good, I went with 99-06 buckets, but I like those better....
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 04-09-2011, 11:08 PM   #627
shrunken66stroker
shrunken66stroker's Avatar
Originally Posted by Strodder View Post
The seats look really good, but I would take off the head rests. Just my 2 cents.
I thought of that but I don't mind them sticking up in the window. If I do take them off the seat backs will be flush with the bottom of the window.
shrunken66stroker is offline   Reply With Quote
Old 04-09-2011, 11:13 PM   #628
shrunken66stroker
Thanks Tommy. I'm keeping an eye on your build too. How the hell do you crack an oil pump? Watch for the o ring on the pick up tube too. That's the culprit with a lot of oil pressure problems. There are two different colors or o ring and they're specific to the pick up tube you have. If you buy a Melling it will have both in the box and a diagram telling you which to use.
Old 04-10-2011, 10:49 AM   #629
Strodder
Daring to be Different
Strodder's Avatar
That's why I said to take them off.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-17-2011, 01:49 AM   #630
shrunken66stroker
I took a couple real pics tonight instead of the usual camera phone shots. I put the steering column back in to see how much room I had and get a feel for where the wheel is going to be. I almost have to squeeze my leg under the wheel when I get in. I'll probably get a smaller diameter aftermarket wheel at some point but it will work for now. I think I'm probably going to use the stock clutch and brake pedals. I adjusted both as far back as I think they'll need to go and they're in a comfortable spot. I also got some pics of the cab seams I welded.
Old 04-17-2011, 11:23 AM   #631
kell490
Where did you get the seats what are they out of? I will be in need of some for my 67
kell490 is offline   Reply With Quote
Old 04-17-2011, 01:07 PM   #632
daverod
SSN 706
daverod's Avatar
Is that paint I see.
daverod is offline   Reply With Quote
Old 04-17-2011, 02:17 PM   #633
shrunken66stroker
The seats are out of an 09 Silverado standard cab. They're all manual so no electrical to deal with. I got them off ebay from a seller called gandaauto08 out of Troy, Michigan.
Old 04-17-2011, 02:17 PM   #634
shrunken66stroker
There's a few spots on the cab that aren't stripped down to bare metal, but not many eagle eye.
Old 04-17-2011, 02:25 PM   #635
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Your moving along quickly
I like the seats, they do look like they fit well. Do you have them bolted in? I had to make some plates for my 05 seats to fit.
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 04-17-2011, 02:31 PM   #636
shrunken66stroker
Tony
No, they're not bolted in yet but it doesn't look like it will take much work either. I'm going to reenforce the floor, drill and bolt em in. I probably won't do it any time soon. They're just sitting there so I can fit everything up around them. I'm getting my transmission on Monday evening, if it's on time, and I'll just keep them in there till I see where the stick lines up. I'm going to clean them up and put them away till I finish the the dirty work. I'll take pics and post them when I do it.
Old 04-18-2011, 01:47 PM   #637
Daddy0
Daddy0's Avatar
You could always do a tilt column to get in & out if you don't want to go to a smaller aftermarket wheel...
Daddy0
Daddy0 is offline   Reply With Quote
Old 04-19-2011, 06:49 PM   #638
jimmydean
jimmydean's Avatar
I love the seats. Be glad you didn't go power, mine were a NIGHTMARE. 38 wires to sort through and ended up using a total of 16 per seat.
I was going to get Silverado seats, but I wanted something a little more old man.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-19-2011, 08:06 PM   #639
65Pickup
65Pickup's Avatar
Do the shoulder and lap belts come connected to the seats??
65Pickup is offline   Reply With Quote
Old 04-20-2011, 12:14 AM   #640
shrunken66stroker
"38 wires to sort through"
That's exactly what I was trying to avoid Jimmydean.
I think it's the law that you can't sell seat belts after the car has been in a wreck. They didn't come with the seats and I'll have to figure something else out.
Old 04-20-2011, 12:31 AM   #641
65Pickup
65Pickup's Avatar
But do they fit in the seats if they were there? I wired my '65 took forever, but all my stuff does
Old 04-21-2011, 10:29 PM   #642
shrunken66stroker
The trans finally got here. I bolted it up and jammed it in there to see if my measurements were correct. It's exactly where I thought it would be. The tape doesn't lie. I made a shifter out of 5/8" round stock. I put it in the vice and bent it with a pipe to get the 3" offset closer to me. I flattened out one side by cutting a little with a cutting wheel to get a flat surface to mate to the shifter mount. Then I drilled and tapped the top, cut the head off a bolt and screwed on the shifter. The pic of the shifter close to the seat is in 2nd gear. It's perfect. I think I saved $50 on a shifter.
Old 04-22-2011, 12:48 AM   #643
ratty 46
Nice install & way to recycle ... on the shifter.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 04-22-2011, 04:43 PM   #644
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Very good build!! Suscribed.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-22-2011, 10:56 PM   #645
shrunken66stroker
patching the old hole for the T-5 and cut the new one.
Old 04-22-2011, 10:57 PM   #646
shrunken66stroker
this upside down pic thing is pissing me off
Old 04-22-2011, 11:05 PM   #647
daverod
SSN 706
daverod's Avatar
I was trying it yesterday. My tip kept filling up with metal. I gave up figured I would weld it when I flip the frame over. If you figure it out let me know.
Old 04-22-2011, 11:14 PM   #648
shrunken66stroker
that's actually the top of the trans hump with the shifter coming through but my pics keep loading upside down for some reason.
Old 04-22-2011, 11:16 PM   #649
daverod
SSN 706
daverod's Avatar
I could have sworn it said upside down welding thing. I was just thinking it looked pretty good for welding upside down. About 5 more minutes of looking at it I would have figured it out, maybe.
Old 04-24-2011, 06:57 PM   #650
Strodder
Strodder's Avatar
Keep tacking it when upside down??? Maybe that would work better?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
1966, bagged, disc, long to short, stroker
