Old 07-24-2021, 11:16 AM   #626
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
Hood primed:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-27-2021, 11:54 PM   #627
SkinnyG
SkinnyG's Avatar
Made a wheeled dolly to move the cab around, as it's next to be blasted.
And then realized I need to add some more brackets to the frame, as it will be blasted after the cab.
I also machined the poly cab mounts. The 60-62 cab mounts are different than the 63-66 mounts, the early ones being square, and different thicknesses. My '61 had the 1" mounts on the rear, and 5/8" mounts on the front.
Energy Suspension's mounts are both 1" front and back, so I chucked the offending mounts in the lathe, and cut them down to 5/8" for the front.
Not sure I'm in love with poly mounts, but here we go. There isn't really other options that I've found, and rubber is a lot harder to cut down than poly.
Crap ton of smoke in the air as most of BC is currently on fire. Couldn't see the sun at all this evening, and it was a while 'till sunset.
Old 07-28-2021, 09:45 PM   #628
SkinnyG
SkinnyG's Avatar
Don't want to put the cab back on the frame without having Raptor under it.
Can't put Raptor under it if I'm going to weld something on it later.
Gotta figure out seats, and gas pedal now.
Dang it.
Old 07-29-2021, 10:23 PM   #629
SkinnyG
SkinnyG's Avatar
In preparing to remove and blast the cab, I need to locate mount the gas pedal. In order to determine the gas pedal location, I need to mount the seats.
I cut the mounts off the original (trashed) seat, and fabricated a method to attach some Honda Civic buckets. I will be modifying the Civic back seat to be a center-seat/console.
Old 07-30-2021, 07:50 AM   #630
Paul Y
Those seats fit remarkably well.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 07-30-2021, 12:06 PM   #631
SkinnyG
SkinnyG's Avatar
I set them so that the rails are centered on the brackets I made. The seat can go far enough back to touch the back wall. The seat also moves forward enough that even my wife can probably drive it (if she had to).
I fab'd the brackets to place the seat at the same angle that it was in the Civic - one challenge of fitting seats is getting the seat bottom at the right angle to support your thighs correctly.
The purists would cringe that I'm not using a bench seat. I totally don't care. (big grin).
Old 07-30-2021, 01:02 PM   #632
SCOTI
SCOTI's Avatar
You scoundrel.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-30-2021, 04:33 PM   #633
The Rocknrod
Moderator
The Rocknrod's Avatar
That's cool, at this level the purist head would explode anyway.
Old 07-30-2021, 09:20 PM   #634
SkinnyG
SkinnyG's Avatar
Drive-by-wire gas pedal mount. This took an entire day. I think it's needlessly complex. Looks good, though....
Old 08-01-2021, 10:21 PM   #635
SkinnyG
SkinnyG's Avatar
Seat belts, also from the Honda Civic. 3x3" 1/8" Shoulder mount washer, to be welded in from behind:
3x3" 1/8" Floor mount washer, to be welded in from behind:
1-1/2" x 1/4" "L" bracket:
Belts mounted (yes, I'll make a cover):
Also re-fabricated the turbo oil feed "T." The old one was too short (the turbo feed hindered the cam sensor connection), and did not have any way of removing it (no hex).
Old and busted (left), vs soon-to-be-new-hotness (right, unfinished):
Old 08-06-2021, 09:06 PM   #636
SkinnyG
SkinnyG's Avatar
Glass removed, decent mounting surfaces:
A bit of rust I need to fix:
Cab removed and flipped back to scrape the rest of the undercoating off:
Old 08-07-2021, 09:23 PM   #637
SkinnyG
SkinnyG's Avatar
Oil-pressure-sender-turbo-feed-"tee" finished and installed:
Welded some carriage bolts in a few un-needed holes to mount the gas pedal bracket, welded up the gas pedal linkage opening, and added nutserts for the fuel pressure regulator:
Patch. Will be welded once I've blasted and epoxy primered inside:
I "think" I'm ready to blast and prime the cab.
Old 08-09-2021, 05:24 AM   #638
Paul Y
Skinny,
Seen a few people use the oil pressure sender as the take off for the Turboooooo now rather than the blanking plate above the oil filter.
Was there a specific reason for this or just easier packaging?
Still a while away from having to make this decision but like to understand why people take a certain route.
Good progress as always.
P.
Woody's Build -
Old 08-09-2021, 11:20 AM   #639
SkinnyG
SkinnyG's Avatar
The blanking plate above the oil filter feeds the oil cooler, and is on totally opposite side of the motor. Not the easiest to get to, and snaking the feed line all the way over there seemed risky to me. I want the line to avoid any extra heat.
I don't believe it matters one bit. Pressurized oil is pressurized oil, and the sender is getting the same oil and pressure that is at the filter.
Old 08-09-2021, 10:14 PM   #640
SkinnyG
SkinnyG's Avatar
We had some rain recently, and the ground was still too wet to start blasting the cab.
So, I did some blasting in my blast cabinet, after changing the gun:
This in addition to the altered siphon-feed on the bottom of the cabinet, and this cabinet is freaking awesome. I love it!!
I had not yet epoxied the hood supports, so after blasting a few more items in the cabinet, I sprayed them:
I am going to hide the air ride gauges behind the ashtray door.
I cut off the back of the ashtray, and experimented with card stock to find the shape and position I wanted using a CNC-Plasma-cut gauges plate I made at work:
Folded up and TIG'd together, the gauge plate screws on from behind:
Then I had to figure out how to make the ashtray open again:
Which I did by making my own hinge and door:
Which reveals like this (roughly driver's seat - cab is on its back right now):
Old 08-09-2021, 10:37 PM   #641
realvc
realvc's Avatar
Fantastic job. You should be so proud.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 08-09-2021, 11:06 PM   #642
cwcarpenter98
cwcarpenter98's Avatar
I like where you put those gauges. That's rad
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-10-2021, 09:24 PM   #643
SkinnyG
SkinnyG's Avatar
Four hours today:
Old 08-11-2021, 04:52 AM   #644
Paul Y
I have to do the same to mine Skinny in the not too distant future.
Not looking forward to it.
P.
Woody's Build -
Old 08-11-2021, 11:27 PM   #645
SkinnyG
SkinnyG's Avatar
Six hours of "pressure pot sand blasting" done today. Should have stopped at five.
And made more changes to the "sand blast cabinet" gun (the clear braided hose that came with the cabinet is garbage):
Old 08-12-2021, 08:10 PM   #646
SkinnyG
SkinnyG's Avatar
I think I blasted three hours. Might have been four.
Right side A-pillar and part of the cowl, and I was pleased to find zero issues with the top of windshield:
Old 08-13-2021, 11:37 AM   #647
SCOTI
SCOTI's Avatar
Looks pretty clean from here as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-13-2021, 08:08 PM   #648
SkinnyG
SkinnyG's Avatar
Five hours to blast the roof:
Old 08-14-2021, 08:21 PM   #649
SkinnyG
SkinnyG's Avatar
Another four hours got more done, including the underside of the roof. Zero rust issues at all.
Old 08-15-2021, 10:46 PM   #650
SkinnyG
SkinnyG's Avatar
A little distraction on the weekend: some blasting; some primer.
