01-20-2013, 09:55 AM | #6826 |
Re: What did you do to your truck today?
Well I when and picked up a 1969 short bed this makes my 2nd 69 short bed
1st truck is 502 BBC w/ T56 6 speed 2nd old pantina 6 cyc. W/auto going in it from the first donor truck 1st truck build; http://67-72chevytrucks.com/vboard/s...d.php?t=468622 2nd truck; http://67-72chevytrucks.com/vboard/s...=1#post5829151 Posted via Mobile Device |
01-20-2013, 11:46 AM | #6827 | |
In my spot weld count I've removed two dashes, approximately spot welds on my burb. -2X front driver kick panels at 3X on one panel and 43 on the second. -3X Rocker panels with unknown number of spot welds.. I was able to order two of the 3-Pack's of 3/8" Blair cutters at my local NAPA for only $20... I thought that was far.. I'll likely need at least one.. And then I'll have extras for the next project.
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
01-20-2013, 08:40 PM | #6828 |
Installed my wood bed and set the bed back on the truck.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
01-20-2013, 09:00 PM | #6829 |
holy blue I love that color
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
01-20-2013, 09:31 PM | #6830 |
Really nice Barnfind.
01-20-2013, 09:32 PM | #6831 |
Muahaha I got a blower for my 350 build. The flame has been reignited.
Dang it, I can't seem to post this pic straight. |
01-20-2013, 09:37 PM | #6832 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Worked on my project low and go ....front inner fenders and rear steel bed mods.....it's getting closer
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
01-20-2013, 09:41 PM | #6833 |
I cleaned out the insulation/deadener and vacuumed up the new/older cab.
It will need rockers, both from floor supports, part of both sides of the floor boards and some dummy beat in two spots on the firewall to fit in an engine it appears. Not even close to as bad as the first cab even though it's more area. All in all, I am still stoked about the cab. I am still debating on shaved drip rails... Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
01-20-2013, 09:42 PM | #6834 |
There is NO WAY IN HE DOUBLE TOOTHPICKS That I would ever take a project down to the spot welds like you have. Where do you draw the line?
60' GMC 4000 15' flatbed dump |
01-20-2013, 09:44 PM | #6835 | |
There's no way I'd take a project down so far. I'd let it go and get something with a little less work involved.
01-20-2013, 10:17 PM | #6836 |
Picked up my seat at the upholsterer's place.
01-20-2013, 11:06 PM | #6837 |
Yesterday was new fuel pump and rubber lines. Today I installed my west coast mirrors that I picked up yesterday.
01-20-2013, 11:10 PM | #6838 |
Picked up a Flarestat hazard switch at pick-n-pull today. It's one of those things that I always wanted but couldn't bring myself to pay $100 for. $16.00 out the door. Has gmc on it instead of the bowtie, but I'll live with it. I drilled out the hole for the choke cable (don't have a choke anyways) with a 5/8" bit and it fits perfect.
01-21-2013, 09:20 PM | #6839 |
Wiring, steering column, windshield wiper motor and linkages, brake booster and master cylinder, inner fenders, inside side vents installed with new seals. Started it for the first time in 4 months..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
01-21-2013, 09:25 PM | #6840 | |
01-21-2013, 09:30 PM | #6841 |
Moderator
That B Body cluster looks right at home in there! Nice job. The LT1 is going to really haul.
01-21-2013, 09:35 PM | #6842 |
Thanks for the positive feedback... I have driven it on the road sitting on a bucket, no doors, windshield, fenders, inner fenders, bed, etc. It does run good..
01-21-2013, 10:33 PM | #6843 |
Had a good day working on the truck despite the fact it was only 32 degrees out. All went well until I broke off a bolt that holds down the thermostat cover...Snap!
01-21-2013, 10:53 PM | #6844 |
Haha, only 32 degrees, it is minus 32 degrees here, no working outside like you can.
01-21-2013, 11:02 PM | #6845 |
Isn't it always frozen in Canada? Ha ha ( I am originally from BC so I can make that comment!) I forgot to add that I have no garage but with no rain it was not too bad!
01-21-2013, 11:45 PM | #6846 |
Actually did it last week, but installed a class V trailer hitch, Rick's fuel tank with gen 5 Camaro fuel pump module and new poly bushings for my CPP panhard bar all in preparation to tow a mustang home from Ventura
01-22-2013, 12:10 AM | #6847 |
In the Northern part of Saskatchewan Canada we get a whole 2-3 months of semi warm car weather, whoohoo.
01-22-2013, 12:24 AM | #6848 |
Hey if it got too hot your igloo would melt!
01-22-2013, 07:30 PM | #6849 |
Somedays I wish I was further North where the igloo's are, easy and cheap to build not like all my insulation I put in my house to keep the -20 to -30 plus weather out. Oh well a few more months and the ice will melt and a couple of months of summer, haha.
01-22-2013, 08:23 PM | #6850 |
I know this weather is horrible. It is almost 80 out there and I would do some work on my truck but I fear I might break a sweat.
