Closed Thread
Old 02-28-2013, 09:35 PM   #7051
Hx16457
Hx16457's Avatar
Re: What did you do to your truck today?
Went to the Falls TX. and got my drive shaft shortened.
Installed it when I got home. Connected the trans cooler lines.
Also received my JEG's order today; Edelbrock carb brackets for the 700r4 TV cable.
Just like everything else, they are going to work with some modifications for my liking, but at this point I am used to buying stuff and having to modify/change it.
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 02-28-2013, 10:10 PM   #7052
Trsmotrhed
Trsmotrhed's Avatar
Installed the 4" drop rear coils. Need to install the front drop components now.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 02-28-2013, 10:41 PM   #7053
dantimdad
dantimdad's Avatar
Picked up grade 8 bolts for the motor mounts today. DANG! Those things have gone through the roof. Not a huge purchase, but still...
Hopefully, test fitting the motor and trans this weekend so I can build a cross member. The PO used a piece of angle iron that was not even bolted in, just laying there!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 03-01-2013, 06:35 PM   #7054
Trsmotrhed
Trsmotrhed's Avatar
The UPS guy, oops mean lady dropped off two lost boxes. Off to the garage I go.
63 SWB C10
Old 03-01-2013, 10:20 PM   #7055
bschoolz1
picked up a nice rust free hood on cl today.on the east coast these are like striking gold
bschoolz1 is offline
Old 03-01-2013, 10:28 PM   #7056
azdude1964
azdude1964's Avatar
adjusted the rear end so the new 29x18x15 tires were centered in the tubs. I also stretched hood springs for the fiberglass hood
azdude1964 is offline
Old 03-01-2013, 10:34 PM   #7057
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
photos??
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 03-01-2013, 10:46 PM   #7058
azdude1964
azdude1964's Avatar
tryin to get some up
Old 03-01-2013, 10:47 PM   #7059
azdude1964
azdude1964's Avatar
how do you put a pic under your name? please help
Old 03-01-2013, 11:15 PM   #7060
Trsmotrhed
Trsmotrhed's Avatar
In your profile there is a place to add a picture and edit your signature. There's a place on here that tells how. If I find It I'll pm it to you.
63 SWB C10
Old 03-01-2013, 11:17 PM   #7061
azdude1964
azdude1964's Avatar
thanks
Old 03-01-2013, 11:46 PM   #7062
azdude1964
azdude1964's Avatar
C:\Users\dude's\Pictures\2013-03-01 engine\engine 070.JPG
Old 03-01-2013, 11:49 PM   #7063
Trsmotrhed
Trsmotrhed's Avatar
Cool, you did it.
63 SWB C10
Old 03-01-2013, 11:53 PM   #7064
towersddg9
towersddg9's Avatar
Finally got my truck into the booth, been busy racing go karts with my 8 year old, will be close to completion soon, pushing for goodguys
towersddg9 is offline
Old 03-02-2013, 12:07 AM   #7065
azdude1964
azdude1964's Avatar
cant get pic on here/// shoot i really wanted to show it off
Old 03-02-2013, 02:06 AM   #7066
akaupp
I towed the truck home from my office today and popped the rear diff cover. Found a bunch of metal and not enough oil. Went online and found a good rear end out of a '78 for $200 complete from drum to drum and a 3.73 gear, plus he loaded it.
akaupp is offline
Old 03-02-2013, 02:14 AM   #7067
Trsmotrhed
Trsmotrhed's Avatar
When you're posting a pic, click on the little paper click looking icon, search where the pic is at on your computer and upload. From a mobile phone you need a photo bucket acct. Upload pics to your photobucket acct. From PB click on pic, click menu and copy the link that says direct and has http/ in front of it. Now when posting pic here from mobile click on the yellow looking square with a mtn in it, paste the link and there is you're pic posted on here. Send me a private message and I'll help you. Good luck.
63 SWB C10
Old 03-02-2013, 02:17 AM   #7068
Trsmotrhed
Trsmotrhed's Avatar
[QUOTE=akaupp;5921967]I towed the truck home from my office today and popped the rear diff cover. Found a bunch of metal and not enough oil. Went online and found a good rear end out of a '78 for $200 complete from drum to drum and a 3.73 gear, plus he loaded it.
That don't look good at all. At least you found another rear end and will be going in no time.
63 SWB C10
Old 03-02-2013, 03:56 PM   #7069
mud.man.rj
mud.man.rj's Avatar
Man did you chew that diff up, good score on the other diff.
mud.man.rj is offline
Old 03-02-2013, 04:56 PM   #7070
Hx16457
Hx16457's Avatar
Well I got the 700r4 filled up and drive her around a bit, but as MY luck would only have it I am still hearing noise. I am thinking now it has to be the rear end! I hear it when I get out of the gas and slowing (stopping etc...) then when I get back in the gas it goes away, or I just can't hear it... I have run it up on stands and spun the tires by hand and can hear a thing. I had a 77 with kind of the same issue, no noise with out load on it. I replaced the rear end on it and every thing is fine now, so I am thinking of the same action on Sally...
Maybe get a covertiom kit and use a newer rear end...
Hx16457 is offline
Old 03-02-2013, 10:17 PM   #7071
Trsmotrhed
Trsmotrhed's Avatar
Finishing up the passengers side 2.5" drop spindle, 1" drop coil and new brake hardware.
63 SWB C10
Old 03-02-2013, 11:36 PM   #7072
azdude1964
azdude1964's Avatar
I'll try and get some up but if you look at my profile you will see it
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
Old 03-02-2013, 11:55 PM   #7073
Trsmotrhed
Trsmotrhed's Avatar
Had to put the passenger tire on and drop the jack. Maybe could have gone with a 2" drop coil instead of the 1" with the 2.5" drop spindle. I'll see after I get both sides done and drive it awhile.
63 SWB C10
Old 03-03-2013, 12:28 AM   #7074
earl84
Took it out for its first drive that wasn't a kind of shakedown run and had a rear wheel bearing blowout completely and lock up the right rear wheel. Spent about 5 hours running to parts stores and working on it. 3 bearings later, none fit right. Luckily it was only about 3 blocks from the house and was able to get tools I needed easily. Had to knock on a neighbor's door and ask to plug my extension cord into their house in order to grind off the bearing remnants. In the end, had to order one that won't be here for 2 days. Put it back together without the inner bearing and limped it home where it will sit for a few days. Luckily, this didn't happen yesterday on the highway when I was going 65 mph or that I didn't have my daughter with me, cuz she was supposed to learn how to drive a manual today.
earl84 is offline
Old 03-03-2013, 08:56 AM   #7075
Hx16457
Hx16457's Avatar
Sorry to hear that!
Really glad she was not with you, & you were not on the hwy!
Sounds like a good neighbor though!
Hx16457 is offline
Closed Thread
