Closed Thread
Old 03-10-2013, 04:52 PM   #7126
T2vigil
T2vigil's Avatar
Re: What did you do to your truck today?
Finally a good enough day to get the spare tire fender primed and painted. Now to get the fender one and the holder on and it will be good to go.
T2vigil is offline
Old 03-10-2013, 05:38 PM   #7127
70inline6
I followed PoDuck's write-up and parts list (#62 Brake Question), and replaced the brakes on my '60. My 'after' pics looked just like his, so no sense posting them. I will show y'all the bucket-O-parts and the 'NICE' surprises I found as far as cracked shoes and hoses.
I replaced everything but the Master Cylinder - flexible lines, shoes, drums, hardware, wheel cylinders. I suppose the MC will go out now. Gravity bled the system and test drive went well. Yay!
70inline6 is offline
Old 03-10-2013, 06:03 PM   #7128
63ChevC10
63ChevC10's Avatar
Sticking to my "build it from wrecking yard parts" theme, I bought a used fuel tank and itstalled it today. I did splurge and buy a new sending unit, so I have about $80 invested and the fuel system is doing great! Fuel gauge even works! Plus, I got a few looks driving it to the station and back. Did I mention that I love these trucks?!?
63ChevC10 is offline
Old 03-10-2013, 07:05 PM   #7129
LDO
LDO's Avatar
Picked up some of this at Lowes and hot glued it to the inside of my cowl panel.
Results.
Sorry for the crappy pics and low light but it turned out pretty good for a last minute mod at the end of the work day.
LDO is offline
Old 03-10-2013, 07:50 PM   #7130
BadaSs_Cal
BadaSs_Cal's Avatar
Drove it around my lot, one of the customers kids wanted to ride in it. Tomorrow it gets insurance so it can see the road again.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline
Old 03-10-2013, 08:46 PM   #7131
RANDY COX
RANDY COX's Avatar
Finished up grinding on radio faceplate,and took the Rallies off my 48 and put them on my truck..I believe I need bigger tires...
1964 BBC 402 4x4
RANDY COX is offline
Old 03-10-2013, 09:36 PM   #7132
hemifalcon
^^^i believe you need to shorten the stance!! (A little)^^^
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline
Old 03-10-2013, 10:09 PM   #7133
TehNewGuy
TehNewGuy's Avatar
Thats a awsome idea and I have some of that lying around too since my four american bulldogs tear up my windows!
1966 Chevy C10 LWB Fleet- Project
TehNewGuy is offline
Old 03-10-2013, 10:17 PM   #7134
TehNewGuy
TehNewGuy's Avatar
Last night I fixed the single barrel carb, seems the power piston was frozen in place and took more than a little work after sitting in gunk carb cleaner for 45 minutes to get it free again. Plus I found out that the throttle valve assembly is leaking at the the sides, where the valve sits... so thats great!
But since it was running pretty good this morning I decided to hit up a local Moose Lodge car show, a charity event for Veterans comming home. Was pretty great since this was my second one!
Old 03-10-2013, 11:41 PM   #7135
63MOUSE
after cutting and buffing, then spraying in bedliner, we put on my bed
63MOUSE is offline
Old 03-10-2013, 11:51 PM   #7136
Trsmotrhed
Trsmotrhed's Avatar
Looks nice. Got a question, the rear tail light panel seam is filled in and smooth. I need to replace mine and can't really spot weld like factory so was thinking of putting the new ones on and welding the seam. Is that what you did? How did you fill the seam so it don't crack. Thx
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 03-11-2013, 12:28 AM   #7137
63MOUSE
all my seams are filled in. drilled very small holes all along the crack and with a mig welder, shot the wire in those holes to make everything solid, then ground the crack to its original shape
63MOUSE is offline
Old 03-11-2013, 01:05 AM   #7138
Trsmotrhed
Trsmotrhed's Avatar
Thanks, that's a good idea. Do you have pics of drilling and filling the holes
63 SWB C10
Old 03-11-2013, 01:50 AM   #7139
azdude1964
azdude1964's Avatar
63mouse lookin good..cant wait to see it..
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline
Old 03-11-2013, 07:58 AM   #7140
LDO
LDO's Avatar
Great looking truck 63MOUSE!!
LDO is offline
Old 03-11-2013, 08:28 AM   #7141
63MOUSE
no i dont have any pics of the hole drilling. sorry. thanks for the comments to all you guys
63MOUSE is offline
Old 03-11-2013, 09:26 AM   #7142
robber grin
Weather was great! Rolled it outside for first time in a year and took bed apart for cleaning and so on. Frame looks like it will clean up without any major issues.
Started on 78 steering linkage and blew it apart - cleaning, priming, and painting pieces.
Sunday I went to work on floor repairs for transmission tunnel cover. PO cut it up pretty good for a truck 4 speed... bit of a hack job.
Cover isn't much better so if any of you happen to have a line on any straight low floor covers let me know... mine is "fixable" but replacement would be much easier.
living the dream...
rg
robber grin is offline
Old 03-11-2013, 09:40 AM   #7143
racecougar
racecougar's Avatar
Installed the passenger side front and rear cab supports and did a little more welding on the passenger side floor pans. The rear cab support had to be narrowed and the flanges reworked to match the original and fit up to the floor and rear pillar correctly.
Still a LONG way to go.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 03-11-2013, 12:30 PM   #7144
CRGRS 66
CRGRS 66's Avatar
Bed off, new rear suspension components mocked up, then removed along with ALL rear suspension. Just about ready to separate the frame and cab. Details, and pictures in my build thread.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 03-11-2013, 06:17 PM   #7145
meat-head
meat-head's Avatar
Just ordered some american racing 20x8.5 torque thrust st's and 245/45-20 tires! Out with the old 16x8 MB's, in with the new.
meat-head is offline
Old 03-11-2013, 06:21 PM   #7146
Blue_Aura
Blue_Aura's Avatar
Both of them are very nice looking wheels. Congrats!
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline
Old 03-11-2013, 07:45 PM   #7147
towersddg9
towersddg9's Avatar
shot of the bed side, will finish assembly (this week) block it down with 800 and buff
towersddg9 is offline
Old 03-11-2013, 08:09 PM   #7148
dantimdad
dantimdad's Avatar
Painted water pump, block off plates and water neck.
The fastener store was out of the right size bolts for the water pump, but, I got the others and polished them and got that stuff mounted.
I have to repaint the pulleys, double check all the bolts and then drop the engine on the frame.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 03-11-2013, 08:12 PM   #7149
Minzer
Minzer's Avatar
Thumbs up Re: What did you do to your truck today?
Rescued this beautiful specimen 66 that died in the middle of a field in Argentina. Much work awaits me. regard
http://67-72chevytrucks.com/vboard/s...d.php?t=569595
Minzer is offline
Old 03-11-2013, 09:31 PM   #7150
pmkrew
Found a BBW cab on Craigslist locally, checked it out and agreed to return on Thursday to pick it up...
pmkrew is offline
Closed Thread
