Old 12-23-2017, 12:48 PM   #701
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Br3w City's Project omgwtfbbq
Them changes
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-20-2018, 10:37 PM   #702
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm not dead, nor is my truck. Due to the photobucket changes, most of my updates have been coming via Instagram @Rev_J_HD since its the easiest and most direct way to put it out.
Since not everyone has time for my videos (even me sometimes ) I'm going to throw up some pics of various things, jumping backwards just a bit.
I had put the the bedsides and fenders on, as well as finished some touches on the frame. While I waited for other materials to show up, I went and stripped the peeling chrome off my indicator knobs, and brushed the aluminum that was underneath.
Old 05-20-2018, 10:44 PM   #703
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Since I didn't have the '66 fenders with the reverse lights (which is where I put the tail lights before)... I needed a solution for mounting the LED tails. I didn't want something obstructive and so I played with the idea of partially cutting it into the post of the bed.
The LED lights have a very shallow mounting depth, so flush mounting or partially frenching them into stuff is a bit easier. I ended up marking out the bed post as well as the light cup before making any cuts (the cuts are in the light cup fwiw).
Both cups were welded and after I hit the surface with JB weld so the whole are can be smoothed out and ease the work of the filler to follow.
Old 05-20-2018, 10:50 PM   #704
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
After the JB weld was smoothed on both joints, they got hit with filler and shaped down again. Once the transition was even and didn't have and leftover bumps from the welds or the JB, it got hit with a coat of primer to seal the work until the rest of the bed is ready for paint.
Old 05-21-2018, 07:34 AM   #705
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I like the tailight mod.
Old 05-21-2018, 09:23 PM   #706
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks Aerotruk.
I apologize if the pics jump around a bit, I'm trying to fit the updates into these 5-pic limit posts.
I needed a bed, and didn't want a wood bed or a traditional metal one either. I also need access to all the stuff under the bed (more on that later). So I started laying out aluminum channel to make a subfloor.
Old 05-21-2018, 09:29 PM   #707
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I also took the same approach for the rear subfloor as well. Laying out aluminum channel, then welding it to make the skeleton frame to size.
The floor is (at least) 2 pieces, so the front and rear are removable independently.
Old 05-22-2018, 12:30 PM   #708
jchav62
1962 C-10
jchav62's Avatar
Awesome work! I'm diggin' your tail light engineering there!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-22-2018, 05:47 PM   #709
made2drag
made2drag's Avatar
Nice!
made2drag is offline   Reply With Quote
Old 05-26-2018, 07:23 PM   #710
tinydb84
tinydb84's Avatar
I like the aluminum frame....I should have done it that way...
David
Instagram: myfabguy
Old 05-27-2018, 05:16 PM   #711
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
After most of the fab on the aluminum sections was done, I picked up some support shocks and pivots so I could start to make the hatch I wanted.
Old 05-27-2018, 05:20 PM   #712
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Then I pulled them back out to paint the support frames, and so I could pattern the aluminum skin for the bed itself.
Old 05-27-2018, 05:27 PM   #713
Hollow65
Hollow65's Avatar
Really nice work!
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 05-29-2018, 04:35 PM   #714
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Once I had the aluminum cut out for the skins, I could use a pneumatic rivet gun to actually skin the frames. There was definitely some small areas that had to be touched up by hand with a file, but for the most part it all fit together well.
Old 05-29-2018, 04:38 PM   #715
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I also added this little lift handle to make things easier, and cleaned up the pivot side, adding a thumb tab to the rod that the pivot uses.
Old 06-01-2018, 11:46 PM   #716
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Picked up a 1/4 turn pull latch to hold the bed floor down, but both lift and lock easily.
Old 06-02-2018, 12:08 AM   #717
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Your build is to me almost like: 'deja vu all over again'
66 C20 Service Truck:
Old 06-06-2018, 12:49 PM   #718
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work. I like the bed floor you did.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-07-2018, 09:41 AM   #719
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Just when I think I'm out...It pulls me right back in
Moved by attention back inside for a few, and took the cover off my Twister Shifter console. Its aged a bit and I need to do more modifications to it to accommodate other changes. Pulled the cover off, gave her a light sanding, and hit it with some textured black paint. You can also kinda see inside the shifter a bit for those who were curious about this less common auto shifter style.
Old 06-09-2018, 11:12 AM   #720
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I started to lay out a plate on my carbon sheet. This will become the switch mount panel for the nitrous stuff.
Came back to the shifter console and did all the lettering highlights in a matching blue, then hit the whole thing with a few coats of clear to give everything an even finish.
Old 06-09-2018, 11:59 PM   #721
Captainfab
60-66 Nut
The shifter plate looks great.....it almost looks illuminated. What method did you use to get the blue into the engraving so perfectly?
Old 06-10-2018, 12:13 PM   #722
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks Cap. The paint I'm using is OneShots which is a sign painting/lettering paint, and then some various spraypaints. I did the black base on the cover, then hit it with a med/med-thin coat of clear and waited a day or so for it to harden. I took the OneShots and got it kinda cold so it thickened, then used a long thin lettering brush to do the letters. Quickly I came back with a rag coated in thinner and made a little pommel, and wiped away any extra paint that was on the surface. Then I cleared over the whole thing once it dried.
The OneShots is a very opaque, vibrant color, and against the black does look like it luminesces. (Also the camera was a little sweaty which probably adds to the look lol).
Old 06-10-2018, 11:56 PM   #723
Captainfab
60-66 Nut
Thanks for the reply.
Old 06-12-2018, 10:20 AM   #724
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
No problem Cap (I've also got your P/S bracket on my list of build updates to add )
Got a pile of stuff from the parts man this morning. Painted up my backing plates and could start to test fit the bottle mounting in the bed.
Old 06-17-2018, 12:10 PM   #725
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Made some adjustments to the Qa1's in the rear trying to dial travel vs ride height. I might still need to raise the springs a bit, but empty at this weight the new settings have improved the feel a lot.
