Old 11-12-2017, 12:33 PM   #701
joedoh
joedoh's Avatar
Re: S10 Swap how to
Originally Posted by KRFitz View Post
Thanks for the reply and photos. Much appreciated. I will also explore what may be available to purchasing new to get into a smaller rad/condenser, but I now know this is an option. I'm sure I will have a million more questions. How about fitting the drive shaft...if the motor has to be moved back 8", does the front shaft get a section cut out? Not sure why they went with a 2 piece drive shaft on these trucks? Thanks
replace it with a one piece shaft, usually you can find one that is close in length, for example a longbed driveshaft is usually 64" overall and a reg cab colorado driveshaft is 54" long. when you factor in that lowering the rear makes the driveshaft shorter (lowering an s10 you usually shorten a driveshaft 1" to keep the yoke from cramming into the trans) so 54 is almost perfect.
measure your driveshaft to be sure, center of u joint to center of u joint. I dont recommend shortening the two piece because the front shaft will end up ~12" long and you will want to replace the carrier bearing while you are working on it, might as well just put that towards a one piece.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-13-2017, 08:57 PM   #702
gigamanx
Re: S10 Swap how to
As a guide if anyone is interested in what measurements you end up with using a 4 1/2" front cab mount and how it affects ride height and all the other measurements. Measurements are without any suspension modifications. The cab mount also has a 1/2" rubber mount on top for a total of 5" from top of frame to bottom of the cab cross member that contains the mount hole.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 11-13-2017, 11:00 PM   #703
KRFitz
Re: S10 Swap how to
Thanks for posting the measurements. Is this the typical tire sizes guys are using front and back? Not that there's a standard, but what have you found works well for wheel sizes for a lowered look?
KRFitz is offline   Reply With Quote
Old 11-14-2017, 10:12 AM   #704
gigamanx
Re: S10 Swap how to
Diagram doesn't have the front tire size I would go for, but that's what is on the car so I had to take measurements from there. I'll probably update the diagram when I get a new front tire. The rear ones are new and I did enough research of various builds that the average tire diameter is 29" for the front and rear. The size does fill the rear fender out fairly nicely and tucks in well for a lowered truck.
Tucked in with the right spacers and 2" drop spindles, 29"x8" front tires seems to be the consensus, but I haven't tried that myself yet to confirm that there is no rubbing.
Borrowed from a different thread:
Originally Posted by joedoh
the rear tire is a 235/75/15, I like that tire on almost every truck
Old 11-15-2017, 03:43 PM   #705
skymangs
skymangs's Avatar
Re: S10 Swap how to
i beg to differ, i have used two piece shafts and old carrier bearings many times and never had a problem i just shorten the front half, and it is NEVER anywhere near 12" long! works out nicely, cause you don't have to mess with moving the carrier bearing.
skymangs is offline   Reply With Quote
Old 11-15-2017, 05:16 PM   #706
joedoh
joedoh's Avatar
Re: S10 Swap how to
looks like you are right, 12" would be much longer than the actual measurement. my comment was actually about cost, a rcsb driveshaft is $50-60 in a salvage, shortening a two piece would be double that and you would probably replace the carrier "while you were in there"
Old 11-15-2017, 06:44 PM   #707
ThadandDad48
Re: S10 Swap how to
Glad to see this thread is still active. My 14 year old son and I are currently working on a swap just like this have built cab mounts very similar to the design shown only using 4" square tubing (son actually did all the welding to assemble the mounts. have moved the motor into position and made mounts and are currently working on the core support.
All the info here is great look forward to getting this truck together and running. We are using the 4.3 vortec out of the 1998 s10 we purchased and using the 4L60E that was behind it. Also had a 2001 short bed we used as a frame donor stretched it to 116" as others have previously mentioned. The short bed had no engine or tranny when we purchased but did have the old tranny cross member in the bed which I was able to rework to act as a trans support and only had to drill 2 holes in the frame. Any suggestions for brake pedal since both our s10s have the huge aluminum casting assembly and they don't look like they would be easy to remove or rework for repurposing in the 48?
ThadandDad48 is offline   Reply With Quote
Old 11-15-2017, 09:53 PM   #708
gigamanx
Re: S10 Swap how to
I had used the 4x4 tubing at 4 1/4". Worked a charm. I did cut a little notch from mine and glad I did. It barely clears the edge of the lower cab corner when lowering the cab onto them. Feel free to check out my project build for a core support mount.
Old 11-16-2017, 12:04 PM   #709
Black93GT
Black93GT's Avatar
Re: S10 Swap how to
That's how I made it work. I actually used one half of a 4wd drive shaft and the other was from a 2wd. I had to fabricate a bracket to set the carrier bearing back. It won't be my permanent solution but was able to make it work for free and right away.
'49 3600 build
SBC 350, a T-5 and some patina
Black93GT is offline   Reply With Quote
Old 11-16-2017, 01:37 PM   #710
1952ssr
1952ssr's Avatar
Re: S10 Swap how to
A drive shaft from a late '90's caprice or roadmaster will work fine using a V8 and 4L60 tranny if you want to go with one piece.
1952ssr is offline   Reply With Quote
Old 11-16-2017, 07:24 PM   #711
joedoh
joedoh's Avatar
Re: S10 Swap how to
I have made a big interface bracket on a couple trucks to use the 98-03 pedal bracket but I have changed my tune lately, its very heavy and needs a lot of reinforcing.
If you want a simple brake pedal setup, skymangs shows how to use a 82-93 s10 pedal bracket on page 2.
Old 11-16-2017, 08:44 PM   #712
skymangs
skymangs's Avatar
Re: S10 Swap how to
this is a shortened 2 piece driveshaft, no where near 12" long with the original carrier bearing. we have been driving it for over 4 years now, so don't tell me it can't be done! cost about $100 to have a driveshaft shortened/balanced. i don't know about you, but i don't have time to go scrounging around a j/y every build.
Old 11-16-2017, 10:04 PM   #713
joedoh
joedoh's Avatar
Re: S10 Swap how to
scrounging? I call them on the phone and say I need this driveshaft. the last one was 60 bucks and wasnt any more driving than it takes to go to the driveshaft shop, and I had it to install the same day. add to that, the 98+ longbeds came with a one piece shaft, so they dont even have a carrier bearing crossmember.
I can agree to disagree, but dang if it doesnt seem like your way is the "more money more work more time" way.
edit: and I am looking again, your trans is a TH350 which is shorter than the 4L60e in my picture.
Old 11-18-2017, 08:55 AM   #714
Black93GT
Black93GT's Avatar
Re: S10 Swap how to
Wow... More power to you. I took a look at the one in my 98 donor truck and knew within seconds it would be too much work. (Granted, making 82-93 pedals straddle the column to match the original spacing wasn't light in the fabrication department either)
'49 3600 build
Old 11-18-2017, 01:40 PM   #715
skymangs
skymangs's Avatar
Re: S10 Swap how to
I've also done 4L60's. 6 of one half dozen of the other, I'm just saying it can be done. and it's not the horrible headache you make it out to be.
Old 11-19-2017, 12:01 AM   #716
joedoh
joedoh's Avatar
Re: S10 Swap how to
I didnt say it was impossible. I didnt say it couldnt be done. I didnt even say it was a headache. you said I said all that. but I didnt.
I said, and I am paraphrasing, "why bother with a two piece when you have such a short front section?". the reason for having a two piece, because the shaft is over 57" long, doesnt exist on a 53-55" shaft.
the cheapest carrier bearing is 32 bucks, the least expensive shop in my area to shorten a shaft is ITP and their cost this time last year was $124. thats ~$150, a rcsb s10 driveshaft is 50-60 dollars. THATS what I said. I even have the two piece as a tranny plug (what I usually do) or to sell on craigslist.
Old 11-19-2017, 01:54 AM   #717
Speedysdad
Re: S10 Swap how to
Since I am going with the one piece drive shaft route, it appears that I may need to take out the riveted crossmember (carrier bearing mount) out and move it underneath the frame and turn it upside down. I think I have seen others who have done that in their pics.
Jim
Building my first hot rod
54 Chevy truck, S10 frame
383/700r4/373
Speedysdad is offline   Reply With Quote
Old 11-19-2017, 02:51 PM   #718
frankist
Re: S10 Swap how to
Thanks for the diagram Gigamanx, not 100% sure what motor you are going with Speedysdad, but if 5.3 vortec, rear dump camero headers that skymangs mention is the way to go. I tried a few different option and found that those fit best with the correct outlet direction giving a lot of room to wiggle the motor to its final destination. With those headers and skymangs designed motor mounts, my one piece driveshaft did not need the center support bearing mount modified or removed. Hope this helps, can provide a picture if you need one.
frankist is offline   Reply With Quote
Old 11-19-2017, 03:18 PM   #719
joedoh
joedoh's Avatar
Re: S10 Swap how to
you shouldnt need to do that, you can either just leave it as is and the driveshaft may not be very close (depending on how much you lower the truck) or you can just notch it a little to clear the driveshaft. you can plate it back it, or just leave it open.
its not a crucial crossmember and I say that because it is riveted to the bottom of a channel instead of tying the top and bottom of the channel as an important crossmember would (like the gas tank crossmember) or have the frame boxed in that area. the later longbeds dont even have that crossmember, but the inside of the frame rails are boxed on the 98+. I will stop short of saying completely remove it, but its not a beefy frame crossmember.
Old 11-19-2017, 05:45 PM   #720
OutlawDrifter
Re: S10 Swap how to
Meh, I removed mine completely. My tranny x-member is pretty heavy and makes up for it though.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-20-2017, 11:05 AM   #721
joedoh
joedoh's Avatar
Re: S10 Swap how to
I think you are gonna be fine haha. I just stopped short of telling someone to go ahead and remove it
Old 12-06-2017, 11:59 AM   #722
dettmer13
Re: S10 Swap how to
Hello everyone. I've built my cab stands according to skymang's version 2 plans, and mounted them to the given measurement away from the oval hole. Everything is going together well, but I'm a bit concerned with the clearance of the front wheels in relation to the fender. I plan on lowering it 2" using Belltech 2102 spindles with new stock coil springs. If the experts think everything is OK and it'll clear, then I'll move forward. Any input is appreciated.
dettmer13 is offline   Reply With Quote
Old 12-06-2017, 12:13 PM   #723
joedoh
joedoh's Avatar
Re: S10 Swap how to
1. your front clip is pointing down in relation to the cab. this happens more than you think on this swap. raise it so the body line on the fender is level with the bottom of the door.
2. it looks like you might be mounted a bit far back, but to be sure, did you replace the upper control arms? if you swap them side to side or use the speedway tubular uppers and get them on upside down? the wheel will move forward a lot in either case. did you take out any caster shims? it also sets the wheel forward if they are removed. if you havent messed with the control arms, triple check your measurement and make sure the body mounts are level and plumb. for example, the body being low on the rear mounts will cause the problem stated in #1 and lean the cab back.
Old 12-06-2017, 01:44 PM   #724
tlorber
tlorber's Avatar
Re: S10 Swap how to
Your front fender and hood DO appear to be aiming down a bit, although that may just be the camera angle. I've noticed on my truck that as I put more weight on the front end the wheels articulate to the rear slightly. Is everything currently in place? (i.e. motor, tranny, radiator etc.).
Here's how mine ended up with everything in place. I still want to drop the front end a bit and probably get larger tires in the front.
Name:  Right Side after.jpg
tlorber is offline   Reply With Quote
Old 12-06-2017, 03:12 PM   #725
dettmer13
Re: S10 Swap how to
joedoh, The front clip is facing down right now because I was following the Stovebolt forum directions to get my hood alignment and fenders to line up before I welded in my core support, but I will make the proper adjustment to check for wheel clearance first. Also, I haven't messed with the suspension at all yet. Everything is just as stock as it came on the S10. I'll get under the truck and make some measurements to be sure everything is level and plumb. I'm pretty sure I wasn't drinking when I fabbed them and/or tacked them in. I do have the motor and transmission in the truck right now, but not the radiator. I'll let you know what I find.
