Old 02-18-2018, 02:12 PM   #701
Wyattdog2
Re: What did you do with your truck today, Part 3
Originally Posted by idbeast View Post
Played with my X Member kit
Did you buy that x member kit? Nice work btw, i have stock s10 frame still but that looks like it would be beneficial
Wyattdog2 is offline   Reply With Quote
Old 02-18-2018, 05:14 PM   #702
OrrieG
OrrieG's Avatar
Originally Posted by OrrieG View Post
Scored some 59 Fleetside spear trim pieces, just the ends. Does anyone know if the straight trim pieces with the curve on the front ends is unique to the fleetside, or possibly used from another GM product?
Pieces arrived, show quality as promised. Now just need to score some fair priced straight runs (actually have a curve in the end to follow the bed trim line). The place in Canada wants $300 each for the four pieces.
OrrieG is offline   Reply With Quote
Old 02-18-2018, 05:44 PM   #703
Wyattdog2
Originally Posted by Softpatch View Post
Get out your wallet
here it is (front drive Kit) AllAmerciamBillet.com
No billet for this build.
Old 02-18-2018, 06:19 PM   #704
evilokc
i made a little progress on my heat/ac unit. the issue is that I have a 10 plus year old unit from "hot rod air" that has never run. I'm missing all the interior parts except the evaporator. I have been talking with "vintage air" to see if their controls and replacement parts will work. their exceptional customer service has led me to some answers. the hot rod air unit uses electric servos for the a/c and the vintage air controls will work on that no problem. the heat on the hot rod air unit is vacuum. vintage air is all electric. they sell a conversion kit to change the vacuum heat to electric. I'm pricing all the missing parts I need and the conversion kit to see if I'm going to do that or purchase a complete interior only kit that has a new evaporator and all the needed interior parts. it will be a cost based decision. I know the conversion will be cheaper than the kit but once I add all the bits and pieced the cost difference may not be as large as I'm thinking. if its just a couple hundred difference I will be a lot more comfortable with a new kit with all matching parts.
evilokc is offline   Reply With Quote
Old 02-18-2018, 06:44 PM   #705
gigamanx
Originally tried putting my fuel pump near the front of the truck and had fuel issues when I was sitting on a hill. Moved it to the rear and "while I was there" ran hard lines to clean up the engine. Anyone know if I can run hard lines for vacuum and PCV lines too? Would look sweet to get rid of all those rubber tubes.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 02-18-2018, 06:46 PM   #706
svr
svr's Avatar
Got a start on my exhaust
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 02-18-2018, 06:47 PM   #707
svr
svr's Avatar
So far so good, welder ran out of shielding gas
Old 02-18-2018, 06:58 PM   #708
gigamanx
Seems to always be the case...shield gas running out right in the middle of a project. I just ran out of wire the other day when I had just started welding up some brackets on a Sunday no less. Ugh.
Old 02-18-2018, 07:58 PM   #709
svr
svr's Avatar
I know of no reason you can't run hard lines, am using hard lines on mine, my original had a hard vacum line, just make sure pcv line is big enough im using 3/8
Old 02-18-2018, 09:58 PM   #710
MiraclePieCo
MiraclePieCo's Avatar
Looks super clean. You are much more perfectionistic on those joints than me. No doubt it will pay off in a clean-appearing and leak-free junction.
MiraclePieCo is offline   Reply With Quote
Old 02-18-2018, 10:45 PM   #711
svr
svr's Avatar
LOL, I didnt take pics of the gaps and not quite straight areas, have cut a bunch spot welds and had to redo.
Old 02-19-2018, 02:46 PM   #712
Wyattdog2
I had all my 50 gauges rebuilt but now that i dropped a 01 ls1 i am thinking i might just modify my dash to accept similar year gauges into my dash since i dont care for the style and cost of the aftermarket ones i have seen. Has anyone put modern car or truck gauges (salvage Yard) in a 47 to 53?
Old 02-19-2018, 03:18 PM   #713
idbeast
Yes, I bought it. I was looking for pre-made boxing plates and found these, they were actually almost $200 cheaper then the boxing plates!No Limit X-Member Kit
idbeast is offline   Reply With Quote
Old 02-19-2018, 08:24 PM   #714
idbeast
Got the topside and sides of the frame painted today!
Old 02-20-2018, 12:30 AM   #715
Jesse Z
I have seen it done a lot so I know it's feasible.
Jesse Z is offline   Reply With Quote
Old 02-21-2018, 12:20 AM   #716
Black_Sheep
Black_Sheep's Avatar
Had some time to kill while the parts I painted were drying so I whipped up a column mount for the tach out of a chunk of aluminum. The mount that came with the gauge cup was pretty fugly...
Black_Sheep is offline   Reply With Quote
Old 02-21-2018, 11:27 PM   #717
Dan in Pasadena
Dan in Pasadena's Avatar
Curious, what material you used? Automotive grade paint or something like Rustoleum? Looks nicely done!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-21-2018, 11:33 PM   #718
Dan in Pasadena
I pulled out my window regulators today to starting installing my side windows and wind wings. The rollers are partly broken and they’re all frozen solid. They don’t rotate at all.
I bought new rollers from CPP awhile back and finally opened the envelope today to see they come with new rivets. I wasn’t sure how to go about installing them until it occurred to me to check YouTube. Sure enough, Danchuk has a short video telling you how to replace them for a TriFive car - whose regulators are essentially identical to our TF trucks.
Here’s the video. There may be others.
https://m.youtube.com/watch?v=xF1rok1yN9s
Old 02-22-2018, 12:49 AM   #719
idbeast
Eastwood Extreme Chassis Black Gloss Finish
Old 02-22-2018, 01:44 PM   #720
jweb
jweb's Avatar
It's easy to keep the stock gauges.
Use this for the speedo: https://www.summitracing.com/parts/dak-ecd-100-1
And this for the oil pressure:https://www.summitracing.com/parts/sum-g6326
Then you can drill and tap the head for the temp sensor.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 02-22-2018, 07:06 PM   #721
robertsjm711
robertsjm711's Avatar
IT'S ALIVE!!!
https://youtu.be/Cyg7r1fW-rM
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 02-22-2018, 07:30 PM   #722
evilokc
Originally Posted by robertsjm711 View Post
congrats man!! awesome feeling aint it!
Old 02-23-2018, 04:55 AM   #723
Tchuffman
Made a carb heat shield out of aluminum
Tchuffman is offline   Reply With Quote
Old 02-23-2018, 05:04 AM   #724
Tchuffman
Installed new 32/36 weber on my 250 inline 6 and works pretty good
Old 02-23-2018, 05:06 AM   #725
Tchuffman
Nice
