03-25-2013, 07:55 PM | #7251 |
Re: What did you do to your truck today?
Sorry, Don, here is a pic:
Daniel is chomping at the bit to paint the scripts black. Thanks again! Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
03-25-2013, 10:25 PM | #7252 |
03-25-2013, 10:29 PM | #7253 |
Started on the cpp disc brake and drop spindle! The old spindle removal was a huge PITA.
Posted via Mobile Device Posted via Mobile Device |
03-25-2013, 10:34 PM | #7254 |
Looking Good! The black script will look sweet!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
03-25-2013, 10:34 PM | #7255 |
03-25-2013, 10:42 PM | #7256 |
03-25-2013, 10:43 PM | #7257 |
03-27-2013, 09:09 PM | #7258 |
Worked on it a bit this afternoon, it's sittin but not drivin...
03-28-2013, 10:15 AM | #7259 |
03-28-2013, 03:46 PM | #7260 |
Installed a IPod stereo set up today. It consists of a Kicker Pxi50.2 controller a Kicker HS8 powered subwoofer and a pair of 4" 2-way speakers mounted in a pair of moulded plastic Versa-pods. The sound is incredible and it is totally hidden from view.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
03-28-2013, 04:59 PM | #7261 |
Cam/dbl roller timing chain installed/used an XE270 Comp 4x4 Extreme cam. Heads are ported and lifters/pushrods and roller rockers installed, going back out to finish porting intake now, can't wait to hear it run. |
03-28-2013, 08:21 PM | #7262 |
Put on my new visors, wipers and cleaned up the heater box and put in a new core. Now I have heat just in time for summer.
66 shorty |
03-28-2013, 08:45 PM | #7263 |
Ported and port matched gaskets on Rpm intake, ready to install, getting closer. |
03-28-2013, 09:36 PM | #7264 |
Installed autometer phantom gauges. Get paid Monday and will order the electronic speedometer and tach.
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
03-28-2013, 10:30 PM | #7265 |
*****in
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
03-28-2013, 10:33 PM | #7266 |
ran a 6 ga. wire to my efi to stablize the volts. then took it for a cruz to see if it helped..and it did,,
03-29-2013, 05:02 PM | #7267 |
enabled the autotuner on my megasquirt to tune the truck wow this things gonna be scary fast
03-29-2013, 05:41 PM | #7268 |
To say that I did this today would be a lie. It has taken me about a month. Removed the original rad and installed new aluminum, lost the old broken shroud and noisy fan and installed an electric fan. Also removed the leaking LMC master cylinder and put new mc and reconditioned booster.
Hope everyone has a relaxing Easter Weekend.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb |
03-29-2013, 06:34 PM | #7269 |
Started blasting my new to me rear end. I didn't have a lot of time so I just messed around for a bit. I am using a HF 50 lb blaster. I just wish I had a bigger compressor. It will take a couple of hours to get it done but it will look good. I'm going to put new seals in it por 15 it and put on a chrome cover and olts. The brakes will be all new and new u joints. I'm also having the trailing arms powdercoated and new bushings and bolts. 1st pic is half blasted pumpkin 2nd pic is the axle tube kinda blasted.
66 shorty |
03-29-2013, 07:28 PM | #7270 |
Moderator
What are your compressor specs? I've got a single stage 60 gal, 135psi. I wonder if that's enough for occasional blasting...
03-29-2013, 07:45 PM | #7271 |
Mine is a 25 gal 125 psi. It will work but its going to take a while because I will have to stop and wait for it to refill.
66 shorty |
03-29-2013, 07:54 PM | #7272 |
it is all about cfm's what does youre's put out at 90 lbs? mine puts out 8.5 at 90 and it still needs to catch up
03-29-2013, 08:10 PM | #7273 |
Took ol' blue out for the second run of spring...kinda' thinkin' it is time for a front sway bar .....
03-29-2013, 08:22 PM | #7274 |
Mine is only 4.3 at 90. Its good for about 30 seconds at a time. Maybe time to go get a new compressor.
66 shorty |
03-29-2013, 09:56 PM | #7275 |
Installed my carpet today!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
