Closed Thread
Old 04-04-2013, 08:26 AM   #7301
racecougar
racecougar's Avatar
Re: What did you do to your truck today?
Originally Posted by 63ChevC10 View Post
I worked on the yard most of the day...BUT, I had to see if the truck would start after sitting for over 24 hrs (been having battery drain issues). Started right up! Still nervous though...
Why not grab a multimeter and source the parasitic drain?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 04-04-2013, 10:51 AM   #7302
dantimdad
dantimdad's Avatar
Just a suggestion: I had a drain issue and it turned out to be a bad diode in the alternator.
It's supposed to be very common on GM alternators.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 04-04-2013, 01:09 PM   #7303
63ChevC10
63ChevC10's Avatar
It's sort of a long story, but I've been working on it slowly when I have time. The next step will be to check for which circuit is drawing amps on the battery by using the meter and pulling fuses.
63ChevC10 is offline
Old 04-04-2013, 01:11 PM   #7304
63ChevC10
63ChevC10's Avatar
Steven
Thanks, and I was thinking the same thing. I just went to an internally regulated alternator and so far so good. I still have a feeling I'll be pulling out the meter and finding the current draw though.
Old 04-04-2013, 01:27 PM   #7305
Rich 5150 69
Rich 5150 69's Avatar
In my opinion best and easiest way to test the diode block while the alternator is still on the engine is to do an AC ripple test with a digital multimeter. Just start up the car, turn on the headlights to remove surface charge off the battery. This will force the alternator to switch on. Next set the meter to AC Volts. With the engine running put the positive lead of the meter to the "BAT" terminal on the alternator and hold it there. Then place the negative meter lead onto the negative post on the battery. If you get a meter reading of more than 1.5 Volts AC (1 1/2 Volts AC) the diode block in the alternator is bad and needs replaced. Its a real simple test that only takes a few seconds to perform. Hope this helps!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 04-04-2013, 03:22 PM   #7306
gofastnut
gofastnut's Avatar
Last night after work I got to put some PlastiKote Rust converter on a few of the many rust spots on Ole Brownie. The stuff works pretty good! I think I'm gonna need about a gallon of it!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline
Old 04-04-2013, 09:25 PM   #7307
Trsmotrhed
Trsmotrhed's Avatar
Finished installing my gauges today.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 04-04-2013, 09:29 PM   #7308
Hx16457
Hx16457's Avatar
Looks good! You did a nice job with it!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 04-04-2013, 09:43 PM   #7309
Trsmotrhed
Trsmotrhed's Avatar
Thank you. Very happy with how they came out.
63 SWB C10
Old 04-04-2013, 09:58 PM   #7310
Lugnutz65
Lugnutz65's Avatar
I towed home a 1966 longbed parts truck. I have sooooo many parts for my 65 now that I had to store this at a friends house until I make room. LOL!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 04-04-2013, 10:06 PM   #7311
markeb01
Senior Enthusiast
markeb01's Avatar
Wow! That is a very nice looking parts truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-04-2013, 11:15 PM   #7312
mud.man.rj
mud.man.rj's Avatar
Tonight I finished welding up the plates for my rear cab mounts that cracked, stupid body lift the truck came with, all good and overbuilt now. Time to try out the newly built big block tomorrow.
mud.man.rj is offline
Old 04-04-2013, 11:40 PM   #7313
Narxoleptic Customs
Got the garage cleaned up. Unloaded the bed of the old truck from the move to the new house. Not enough hours in a day...
Narxoleptic Customs is offline
Old 04-05-2013, 09:25 AM   #7314
TehNewGuy
TehNewGuy's Avatar
Decided a while ago i wanted some kind of tool box in my truck for storage, but the alluminum ones look out of place. Long story short i desided to make a wood box that matches the bed kinda, and got everything for free so far after trading a bunch of oak wood i had lying around for 2x8's and all the rest was just lying around my buddies garage...
Pics 1&2. Buddy griding off the extra long bolts on the angle iron for the box sides and the box
Pic 3. Mounted fishing rod holders and the spare tire to the sides of the box
Pic 4&5. Then finally installed the Awsome marine antenna (the fiberglass housing was cracked and broken, but i just hacksawed the bad stuff off and threw it back together) and the complete box!
1966 Chevy C10 LWB Fleet- Project
TehNewGuy is offline
Old 04-05-2013, 09:49 AM   #7315
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Nice box... Careful with the handle... I see a broken rear window in your future...
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 04-05-2013, 02:00 PM   #7316
dbos
dbos's Avatar
Here my 65 fleetside. Paint the cab white last week and just finished the green this afternoon. Hope to have it on the road this summer
dbos is offline
Old 04-05-2013, 02:27 PM   #7317
hopped up
hopped up's Avatar
Ill take those hubcaps !!!
hopped up is offline
Old 04-05-2013, 08:38 PM   #7318
akaupp
Yesterday I stripped the step bumper and repainted it white. It will probably go on this weekend, I hope.
I had to cut the tow balls off, so unfortunately, they won't be going back on.
akaupp is offline
Old 04-05-2013, 09:17 PM   #7319
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: What did you do to your truck today?
In the works...
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 04-05-2013, 09:17 PM   #7320
1964Chevy
1964Chevy's Avatar
Put an inline fuse in the electric fan thermostat sending unit, it blew the fuse in the panel and baffled my tiny brain why the fan would not come on. Drove Toad for the first time in 6 weeks. Went over yonder and did burnouts.
I remembered why I like my pickemup truck. Sound of real V8 and the smell or burning rubber.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline
Old 04-06-2013, 06:43 PM   #7321
gmcdeadhead
gmcdeadhead's Avatar
got the 14 bolt rear in today , tomorrow i'll do the brakes.[IMG][/IMG]
gmcdeadhead is offline
Old 04-06-2013, 08:20 PM   #7322
63ChevC10
63ChevC10's Avatar
Thanks for the tip. I've been out of town for a couple of days (Portland, OR swap meet), but I'll be trying that soon!
Old 04-06-2013, 09:15 PM   #7323
Dano0579
Dano0579's Avatar
Washed my truck for the first time since I got it and fixed the passenger door window where it was off track.
Current project (My Maria)
62 Chevrolet LWB stepside
235 inline 6 cylinder
http://67-72chevytrucks.com/vboard/s...d.php?t=569873
Dano
Dano0579 is offline
Old 04-06-2013, 09:47 PM   #7324
Trsmotrhed
Trsmotrhed's Avatar
Working on the other side of bed. Not sure if I can save it.
63 SWB C10
Old 04-06-2013, 11:10 PM   #7325
garett
got the rear end done in the old burban, then drove to the gas station and filled up. seat belts tommorow yea!
garett is offline
Closed Thread
