Old 12-02-2007, 07:59 PM   #51
OldCreek
OldCreek's Avatar
Re: 700R4 with NP205?
it came with the gaskets and all thread bolts.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-17-2010, 09:29 AM   #52
D O C
good day for grave digging!so has anyone done this with pics yet??i'm gonna get the kit as my 241 tail housing is shot and i have a 205 off a 350 with adaptor,so my 1ton burb will be complete(well except for the 4l80e)
thanks for the addy guys
D O C is offline   Reply With Quote
Old 03-10-2011, 11:17 PM   #53
my90k5
72 K/5 Junkie
my90k5's Avatar
Just scribed to this thread for the information to swap out my 465 to a 700R4.
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 03-11-2011, 12:06 AM   #54
breeh
Recovering 67-72 Addict
breeh's Avatar
I've never looked back after doing mine.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 03-12-2011, 07:04 AM   #55
1malo68
1malo68's Avatar
Don't know if this helps but this is the AA shaft installed in a 700R with the TH350 adapter. The 2nd pic is the tranny pan clearance with a 2" lift. The 3rd one is how far I had to move the engine forward to keep the transfer case in the stock position
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 03-12-2011, 09:37 AM   #56
royo
royo's Avatar
ORD also has a new output shaft for a 700r for this kind of swap
nickle and dime
royo is offline   Reply With Quote
Old 06-23-2011, 01:51 AM   #57
DetroitDan
DetroitDan's Avatar
yet to see it mentioned, but what difference would there be if it's a th400? I have a th400/NP 205 and I found a used built 700 I'd like to use. Don't know as I'll do it though if it mans building two new driveshafts. Would add a lot of expense, plus I want to be able to switch back if I need to, say if the 700 explodes and I can't afford to get a new one. I'd want to be able to throw the 400 back in.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 06-23-2011, 09:38 AM   #58
b454rat
700 had 27 spline, TH400 has 32 spline.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 07-26-2012, 01:55 AM   #59
Jebenubin
Jebenubin's Avatar
great (old) thread, I have a 700r4 and a 205...but my 205 was behind an SM465:a 10 spline input shaft...what I need is the coupler (27 spline to 10 spline) and the th350 adapter...I found the adapter, but only been able to find the coupler from advance adapters for 250.00+ I do not want to drop that much coin for that coupler...anyone know of a cheaper place to get one, or what the specs are on that coupler so I can have a buddy at a local machine shop make me one? Thanks, Jeb
Jebenubin is offline   Reply With Quote
Old 07-26-2012, 09:04 AM   #60
obijuan
its the same size as the ten spline coupler, just 27 spline. theres a snap ring in the middle to prevent floating over the splines.
call your local gear place, theyll have em.
locally i have nogalitos gear. i think its 67 bucks? its been a while since i looked but its certainly not 250.
you did not mention the spacer from techpak fitzall? 75q3a or something. this will prevent your front driveshaft from rubbing the pan.
obijuan is offline   Reply With Quote
Old 07-28-2012, 02:31 AM   #61
wilkin250r
wilkin250r's Avatar
I'm most curious about the front driveshaft clearance, I've heard mention of it several times in this thread, about certain types of driveshaft joints and so forth.
Anybody got pictures of the issues and solutions to front driveshaft problems?
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 07-28-2012, 08:59 AM   #62
obijuan
the solution is to use the techpak spacer 7q35a. that is the correct part number, just read the box. it pushes the tcase away from the trans by 2 inches or so.
the CV joint is too big. you can see exactly where it has to go in the middle picture of the group of pics above.
alternative solutions are to notch your trans pan.
Old 07-28-2012, 08:37 PM   #63
wilkin250r
wilkin250r's Avatar
Ok, so it seems like the issue is that the transfer case is too close to the tranny, yes? I could see where a double-cardan style driveshaft would have even more difficulty clearing.
How is this problem solved with a stock NP241? Is the tranny adapter fairly long? Or is the yoke on the 241 actually out further to clear the pan? Or is it clocked lower?
I know you can buy a new output shaft for the 700R4 to make it identical to a TH350 output, which would be obviously shorter than using an adapter, but maybe that's not the preffered method with this clearance issue.
Is clocking the 205 an option?
Old 07-28-2012, 09:04 PM   #64
obijuan
A 241 and 208 have to make room for the planetary gears. So there's a bigger front half to the case, which puts the front output further away from the mounting face. Take a goggle image tour and compete a 241 to a 205. The relation of ujoint center to the mounting face is much different.
Also to see the difference in pan shapes to show the clearance problems between 700 and a 350.
Old 01-30-2013, 01:05 PM   #65
1972K20
1972K20's Avatar
What's the latest solution to the front driveshaft clearance issues with this swap? If I do this, it will be on a K5 with no lift. Can someone chime in that has done this with stock suspension? Thanks
1972K20 is offline   Reply With Quote
Old 01-30-2013, 01:15 PM   #66
obijuan
Stock output shaft and the spacer.
Old 01-30-2013, 01:29 PM   #67
CUSTOM/10
CUSTOM/10's Avatar
Here's a link to my build. I have a 700R4 / NP205 with the later model 4 bolt flange front output. The shaft is a custom made Tom Woods shaft with a smaller CV joint than stock. I dimpled the corner of the pan and it clears by 1/2" or less. That's with a 4" lift. The truck currently sits as in the pictures so I have no up-dates as far as driving it. I do believe the stock U-bolt CV joint would be back closer to the T/C giving you more clearance. But I don't know this for sure.
4th page has a picture.
Mine is with the AA shaft & the stock TH350 adptr.
Gary
http://67-72chevytrucks.com/vboard/s...therapy&page=4
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-30-2013, 01:52 PM   #68
1972K20
1972K20's Avatar
Can you elaborate? How does this keep the front shaft from interfering with the pan on a stock truck? Thanks
Old 01-30-2013, 02:05 PM   #69
CUSTOM/10
CUSTOM/10's Avatar
I'm not sure that this is any better than the stock set up. I like the 4 bolt flange better than the u-bolt flanges, so I went this route. I was showing the picture so everyone could see what the clearance issues are with this set up.
Using the 2" spacer would deffinately give better clearance, but you then have to relocate the drivetrain about 4". 1-7/8 for the 700R4 & 2" for the adpter. I just moved the engine forward the 1-7/8 for my set-up.
Hopefully someone has a picture of the stock driveshaft, AA shaft & stock adapter.
Edit: The 2"spacer would move your TC back 2 additional inchs, giving you more room between the TC & the 700r4 pan.
Gary
72 SWB 4x4
My 72 SWB Build
Old 01-30-2013, 02:09 PM   #70
obijuan
It pushes the Tcase further away from the trans. So it is not as close to the pan. The short output shaft has never worked without other mods.
Old 01-30-2013, 02:11 PM   #71
1972K20
1972K20's Avatar
Yea, my main concern is my front drive shaft hitting the pan. It seems like everyone that has done this has had some amount of lift. My Blazer will be stock height. From those photos it already looks very close.
Old 01-30-2013, 10:44 PM   #72
1972 CST
when i did this same set up and i got the shorter output shaft and was told to use a np205 front driveshaft from a 67-72 truck because it has a smaller cv joint
1972 CST is offline   Reply With Quote
Old 01-31-2013, 07:07 PM   #73
BigRed76
BigRed76's Avatar
In my '76 I'm running a TH700R4 with a NP205, I used the AA shorter output shaft on the trans. But I also used a deep pan on the trans. so there was no way my stock front driveshaft with the double cardan joint was going the clear that pan. So because of my driveline angles (4 inch lift) I'm eliminating the double cardan joint and just using one u-joint on each end of the shaft.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-31-2013, 07:33 PM   #74
birdistheword
birdistheword's Avatar
I did this swap on my truck this summer and just put the front drive shaft in last night. I'm using the shorter shaft and factory TH350 adapter and stock trans pan. I have the double cardon joint on my truck and I'd say the pan to shaft clearance is about 1/8 inch. But I also have a 2.5 inch lift.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 02-01-2013, 08:00 AM   #75
CUSTOM/10
CUSTOM/10's Avatar
Do any of you guys have pictures ? I'd like to compair the amout of clearance between the different set ups. I'm sure others would like to see them also !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
