12-10-2004, 05:11 PM | #51 |
I am going to do my best to re-produce the 383 front molds with some slight adjustments....6.5" and 1" speaks slightly angled up and towards the rear. Wood molding rings were made today and Fiberglass Kit was ordered. This is going to be fun.
Alex 1971 Lil' Red 350 SBC 700R4 |
12-10-2004, 05:14 PM | #52 | |
12-10-2004, 05:26 PM | #53 |
This is awesome.
Alex, even though you get to do all the work :p, this thread is exciting. It's like a fun little adventure! |
12-10-2004, 05:44 PM | #54 |
Yeah Greg...who would have known??? I order some regular kick panels that I thought were going to house my 6.5" speaks and they won't work with the Kappa's. So...I'm determined to make them fit. I'm a Tile Contractor whom has been figuring out how to fit things together for the last 25 years. I've done some fiberglass work some years back so I'm not too worried. I'll start to build the mold skeleton this weekend. I know it will be alot of hot glue gun work and running back and forth to the truck to check the fit. I hope to have something by New Years or there about. Thanks for everybodys support and interest.
12-10-2004, 06:47 PM | #55 | |
Those are very nice! Neat and clean looking. How are they attached to the wall though? |
12-10-2004, 07:10 PM | #56 |
I have the kick pannel speakers and I was wondering could I just cut a hole in the kick pannel and weld a box that is 3 or 4 inches deep so that the speaker will not bottom out on the kick pannel ? I really dont want to trash the kick pannel housings.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-10-2004, 07:10 PM | #57 | |
12-11-2004, 02:22 AM | #58 | |
Assuming someone looks under the speaker enclosures.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
12-11-2004, 11:43 AM | #59 |
Cool I think that's My afternoon project. It's a good thing I did not take the cab and box down to get sprayed last week like I planned.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 12-11-2004 at 11:46 AM. |
12-11-2004, 12:20 PM | #60 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-11-2004 at 02:34 PM. |
12-11-2004, 02:40 PM | #61 |
Hey, Guys....I've got a skeleton frame work made that will hold the 6.5" speakers and been out at the truck moving it all around trying to determine just how it would be best. If it's not the E-Brake rod...it's the freekin E-Brake pedal...and then if you lower the speaker pod the dimmer switch starts to Fulk with you. So I'm thinking I could put them Low out of the way of the E-brake/Vent rod Equip and fab out a dimmer switch extention towards the passenger side...nah...don't think I like that. Whatever is decided you ARE still going to have to screw the molds/speaker pods to the kick panel area. Then I thought, "Why not make the molds to fit the lower front corner of the door"??? You won't have to cut your door, E-Brake/Vent rod are NO longer a problem, and you can dance on the dimmer switch all day long. Molds for the lower door could follow the curve of the door and could easily be angled up at the driver and Passenger...plenty of room for your feet and those lil' 1" tweets and only 4 small screws would attch them to your non cut door. For that matter, would cover up the PO's cutting of the door if that is the case. Go sit in your truck and look at the lower front of the doors and see if you think this might be an option. I think if the molds/pods were nice and smooth and painted to match your truck...this may be my answer. Thoughts?
12-11-2004, 02:49 PM | #62 |
It seems like the front area of the door would be a lot more prone to potential accidents... Just seems like they'd be more in harms way there. Plus, the asthetics of having a bulbous pod on your door when you open it up versus having them kind of tucked away in the kick panel area. This is all just one man's opinion, of course. I'm not saying it's a bad idea, in fact, it's a good one. It's a possible solution to the problems of placement. However, to me, it just seems more natural to have them in the kick panel area.
I have a '68, so I don't know exactly where the e-brake pedal is in the later models. I'm looking at 383 Stroker's pictures and trying to imagine where this would all fit in. I'll have to go out to my truck to get a better idea. |
12-11-2004, 02:59 PM | #63 |
Why not build a box to face forward under the seats and use whatever speaker you want. Should be plenty of room!
12-11-2004, 03:01 PM | #64 |
True...bulbous pod on door. Probably would only look odd when the door was open. I'm not done and still brain storming. I think I will make up a skeleton frame for both places before I decide to mix the resin.
12-11-2004, 03:07 PM | #65 |
GM ONLY BABY!!!
This is how I did my speakers in my 72 GMC. It took about 3 hours to build this and I have Alpine's in it. If you look they are on the sides of the console, facing the doors. I have a 2.5" and a 6" pair or something close to that size. The truck is in winter storage right now so I can't look at it at the moment. I also built a sub box under the seat that houses a set of 8" subs.
http://img.villagephotos.com/p/2003-11/497511/pic3.jpg
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
12-11-2004, 03:09 PM | #66 |
I'm using 04' Yukon Denali seats which have 3" max under them...so that shoots that option down for me. I do have a 04' center console and could mount the speaks faces towards the doors on either side...don't know how the imaging would be with that arrangement.
12-11-2004, 03:12 PM | #67 |
neat DoG...how does that sound with the speaks facing outward???
12-11-2004, 03:42 PM | #68 |
I tried searching for it but had no luck. There was a post w/pics of someone installing cut-down, late model (94-98?) chevy truck door panels on some 67-72 doors.
IIRC, these door panels have speaker pods built in them (I believe they're similar to the one's in our 02 Trans-Am's door panels). Does anyone know where that post & related info went?
12-11-2004, 03:47 PM | #69 |
GM ONLY BABY!!!
It sounds pretty good to me. All I have is the sponge foam type cone around the back of the speakers in the console.
12-11-2004, 09:08 PM | #70 |
67-72 Addict!
Crutchfield sells Q-form housings for 73-87 trucks that might work. The kick panel area should be pretty close to ours. Look at how the speaker is angled up for sound and also looks to have clearance from the e-brake. I went to the q-form site and got part number QL-K1006
http://www.crutchfield.com/S-0Iwf0Zt...sp?i=044K10061
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-11-2004, 09:11 PM | #71 |
dont be skeert just cut the doors the sound is great and its easier
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-12-2004, 12:55 PM | #72 |
Sisyphus was my mentor!
I have 2 67's so the ebrake pedal isnt a problem for me. As for the dimmer switch, couldnt we move it in &/or up a tiny bit? I just like the fact that the kickpannels are out of the way & less visible to prying eyes (door open or closed). Thanks ChevyDude for your work so far!
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
12-12-2004, 01:33 PM | #73 |
Yes you can move your dimmer switch but may cause the drilling of more holes...unless...I have an idea.... a dimmer switch relocation bracket that has 4 holes. Two that attach to the original floor bolts and two for re-attaching the dimmer with two new 1/2" bolts. This would move the switch 2-4" towards the passenger side without drilling any new holes in the cab floor.
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 12-12-2004 at 01:38 PM. |
12-12-2004, 02:06 PM | #74 |
C10 Club Tennessee
Maybe I missed it, but what is the allowable depth of the speakers that we could put in our kick panels. I have a friend that is an engineer at Harman Industries in Franklin, KY. He can get JBL and Infinity's DIRT CHEAP. I just want to know what the depth is that I can use.
Thanks,
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
12-12-2004, 02:09 PM | #75 |
With the everyday AutoSound kick panels that the vendors all sell...max depth is like 2"...maybe 2.5"
