01-12-2007, 08:53 PM | #51 |
Re: Impala SS/Caprice rear disc brake BRACKETS
I am wondering if anything can be done for us 6 lug guys.. I was thinking Envoy rear discs and a caliper that would work...I have seen burb and tahoe setups but I need something to fit 15" rims. Calipers for Envoys aren't cheap though. If you venture down that lane let me know..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-12-2007, 09:39 PM | #52 |
My understanding of the braking system is this, proportioning valves determine the rate at which brake pressure is applied to the front and rear brakes (pressure to the front first and the rear). Residual valves determine the amount of static pressure that is on the brake shoe or the brake caliper pad. Shoes require a 10 lb residual valve and disc only require a 2 lb residual valve. Older master cylinders had the residual valve built into them. Thats why you would need to get a drum/drum, disc/drum or disc/disc depending on your application. I think some newer proportioning valves may have both functions built in. Long story short, you need to know what YOUR master cylinder and proportioning valve was designed to do. Here's some good info on braking systems design.
http://www.mpbrakes.com/technical-su...igurations.cfm http://www.stoptech.com/tech_info/te...e_papers.shtml
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-12-2007 at 09:40 PM. |
01-12-2007, 09:59 PM | #53 |
Next project: 1970 K10
Thanks Hart_Rod!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
01-14-2007, 10:21 AM | #54 |
when useing the rotors will they fix my 71 lug pattern or do they have to be drilled
01-14-2007, 05:26 PM | #55 |
Never Done?
The caprice/impala ss rotors are a 5x5 bolt pattern, the same as 71-72 trucks. From previous posts, they supposedly slide right on, no problem.
01-14-2007, 06:05 PM | #56 |
The impala rotors are a perfect fit, but do not buy the cheap ones from Advance autoparts. The two I bought are both warped too bad to use.
01-14-2007, 06:41 PM | #57 |
what about the e brake can it be hook up
01-16-2007, 12:45 PM | #58 |
Sorry, not with the Impala/Caprice calipers.
01-17-2007, 12:01 AM | #59 |
thanks i will wait for the camaro .what a swap to add to a truck camaro caliper and impala rotors
01-17-2007, 07:30 AM | #60 |
Never Done?
Bob, received the brackets yesterday. They are some heavy duty pieces! I'll be keeping an eye open for the brake line adapters.
01-17-2007, 10:03 AM | #61 |
Thanks Adam, I'm glad you like them!!!
01-20-2007, 08:05 PM | #62 |
I would like a set of the brackets for the camaro calipers. thanks
01-20-2007, 08:59 PM | #63 |
these will fit 73 and up 12 bolt also correct? if so what would shipping cost to 75647
01-20-2007, 09:35 PM | #64 |
a 15 inch ralley will fit so i figure they will also fit over a 15 inch center line? anyone know for sure?
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
01-21-2007, 04:58 AM | #65 |
put me in line for the camaro brackets when you have them
01-21-2007, 07:37 AM | #66 |
Sleep-Deprived
Glock, put me on the list for Camaro brackets also
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
01-22-2007, 02:56 PM | #67 |
Junior Member
Hey Bob,
How do I buy a set of these for my '72 P/U ? Mike |
01-22-2007, 03:03 PM | #68 |
427mike - I sent you a PM!
Bob
01-22-2007, 09:59 PM | #69 |
I'm interested in a set of these brake caliper brackets with parts list. What would shipping be for Fort Worth, TX 76133.
I also want the brake hose fittings included. I want to use a money order, PM me with your mailing address. Last edited by N2GMTrux; 01-23-2007 at 08:56 AM. Reason: Add brake hose fittings & mailing info. |
01-23-2007, 02:44 AM | #70 |
OutOfMyMind & I'llNeverKnowWhy
Put me on the list for the Camaro brackets, please
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
01-23-2007, 10:06 AM | #71 |
please put me in line for the camero style brackets for 12 bolt .thank you very much.
01-23-2007, 10:14 AM | #72 |
N2GMTrux - PM sent.
Lizzard27, Justins76, 69_hafton, and DMARCUM123, ya'll are now on the list! Thanks guys!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-23-2007 at 10:15 AM. |
01-23-2007, 09:24 PM | #73 |
New Member
If you still have some brackets available I'll take a set. How much for shipping to 77566.
01-23-2007, 09:28 PM | #74 |
Bob, put me on the list for Camaro brackets, now that I'm out of the red let's see if I can get something going again.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
01-23-2007, 10:33 PM | #75 |
plugger7 - $9.00 for shipping, total of $59.00. You can use Paypal at glock35ipsc@aim.com. If you want to use a money order, PM me for a mailing address. And thanks!
Chris - Got ya down! Actually, I've had you down since you sold your kit
