Old 05-12-2008, 01:50 AM   #51
CDA 455
MidlifeCrisisUnderWay
CDA 455's Avatar
Re: 67-72 BigBlock 4x4s! Pos pics info here.
Originally Posted by grendel View Post
Vic is one of the original owners of Atlas
When they released the Atlas, it was SWB only (Jeep, Bronco, Land Cruiser, etc). You can find pictures all over the place. It's one of the original marketing points for the NP205 derived Lomax by Novak.
Stak is it's own design, not based off a production t-case. They were also first to market with a tough 3 speed t-case, they also have proto-type four speeds out... same case.
Whoa !!
So you have one of the proto-types???!!!!
What are the gear ratios ???!!!!!
And when do they expect production to start on those???!!!!
DIY4X
1972 CST Blazer <---sold
CDA 455 is offline   Reply With Quote
Old 05-12-2008, 02:00 AM   #52
CDA 455
CDA 455's Avatar
When you go Stak, you never go back.
Let me know if you can find more of the wider XML.s
Regarding the tires:
There's a set on eBay now --> !!
Same company that I dealt with.
Cheap shipping cost, too!
DIY4X
Old 05-12-2008, 03:52 AM   #53
FormerMember
Link me please?
Strange, link shows up in replay, but not the post.
Got it, thanks.
FormerMember is offline   Reply With Quote
Old 05-12-2008, 05:15 PM   #54
CDA 455
CDA 455's Avatar
Link me please?
Got it, thanks.
Are you going to bid on them?
DIY4X
Old 05-12-2008, 05:34 PM   #55
FormerMember
Yes. Sniper is loaded on 'em
Old 09-30-2008, 02:30 PM   #56
Yukon Jack
Post Whore
Yukon Jack's Avatar
Just bumping this thread to see if anyone has any new info or pics they want to add.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-01-2008, 09:31 AM   #57
FROSTBITE406
FROSTBITE406's Avatar
sure heres some of the new rear terra tires i put on my 1967 3/4 ton gmc puller. 31x15.5 goodyears mounted on 15x14 wheels.
FROSTBITE406 is offline   Reply With Quote
Old 10-01-2008, 05:40 PM   #58
72chevyk10
I built it
72chevyk10's Avatar
i put a 77 454 in mine. edelbrock intake and carb, mallory ss/32(converted to vac advance wish i would have had this when i put the engine in.lol) only clearence issues were valve covers and big hei distriobuter. here it is soon after final assembly
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 10-01-2008, 11:51 PM   #59
Livrat
Member #1049
Livrat's Avatar
I went big block in my 68 GMC about 20 years ago.
Used a .060 454 4bolt block, steel crank, micro oval port heads hogged out to use 2.19in stainless valves, Performer cam and intake, HEI. Doug Thorley Tri-Y headers.
Did not have any clearance issues as I moved it all forward 2.5 inches, used all factory 72 Big block pulleys and brackets, stock V8 crossmember and a V8 2WD fan shroud,
Livrat is offline   Reply With Quote
Old 10-08-2008, 12:01 AM   #60
rwondrash
I also have been thinking about putting a 502 in my 67/72 mix but my question is did any of you have to add a leaf in front to support the additional wheight? Or did you just leave them alone?
rwondrash is offline   Reply With Quote
Old 10-08-2008, 09:38 AM   #61
Burt4x4
Burt4x4's Avatar
I did not do anything to my front springpacks and all is working fine
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-08-2008, 04:12 PM   #62
Yukon Jack
Post Whore
Yukon Jack's Avatar
I am running Tuff Country's HD front springs that give you the extra leaf. Not sure if it was needed in reality - not like I'm gonna have a winch up there anytime soon.
Old 11-25-2008, 09:05 PM   #63
drbyrdman
drbyrdman's Avatar
so iam getting ready to install my 396 in my 4x4. and it looks like all the firewall bashing is around the clutch rod hole. iam using the stock cross member with poly mounts and would like to use the stock holes in the frame. will it fit?? i would like to see some other pics out there.
drbyrdman is offline   Reply With Quote
Old 11-26-2008, 06:43 PM   #64
Yukon Jack
Post Whore
Yukon Jack's Avatar
Hate to tell you this, but you just won't know until you put it in place. Some need no modifications to put in the stock sbc location, some do. I had interference on both sides using the stock sbc crossmember, new rubber motor mounts and the stock sbc engine location.
Old 11-26-2008, 07:30 PM   #65
muscletrucks
muscletrucks's Avatar
Would a body lift kit help clearance issues?
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 11-27-2008, 01:23 PM   #66
Todd Johnson
A firend of mine works on Fords and runs into the same problem about engine placement. Just because the trucks are from the same plant doesn't mean everything fits the same. I have two 4x4's with 454's in them. The 1968 I moved the engine Forward aprox. 2" and put 2wd Jethot headers. Small moons had to be made in frame for a good factory look. The 1970 was not moved forward. It has low cut valve covers and the drive side is still tight.
The exhaust manifold is still stock. Both trucks are long wheel base which helps with the extra weight up front, not so much kick. I had to put bigger lug bolts on because of the added weight. Both trucks are 1/2 tons with power steering. The 68 has disc front and rear and the 70 has disc front.
Todd Johnson is offline   Reply With Quote
Old 11-28-2008, 10:37 AM   #67
Yukon Jack
Post Whore
Yukon Jack's Avatar
Usually a body lift helps with HEI clearance and also with the valve cover clearance - but - I used a body lift and still had clearance issue at the valve covers. Again, you just really won't know until you slide it into place.
Old 11-28-2008, 10:21 PM   #68
72chevyk10
I built it
72chevyk10's Avatar
just be sure to keep a can of primer near by if needed
Old 01-24-2009, 10:31 AM   #69
drbyrdman
drbyrdman's Avatar
iam getting ready to put my 396 together and was wondering what oil pan works with the stock cross member. i heard that the one with the hump in the middle hits. thats the one i have now.
Old 01-24-2009, 11:20 AM   #70
Yukon Jack
Post Whore
Yukon Jack's Avatar
My 454 came from a 1989 2wd 1 ton - using the stock 1969 sbc engine crossmember the oil pan was extremely close to the crossmember. I ended up cutting the crossmember and adding some material to gain some clearance. Hope that helps a little.
Old 01-24-2009, 12:41 PM   #71
drbyrdman
drbyrdman's Avatar
i heard that a stock chevelle one works .
Old 01-24-2009, 11:40 PM   #72
72chevyk10
I built it
72chevyk10's Avatar
i got a 77 454 out of a 3/4 ton burb. im using the stock sbc crossmember and mounts and have about 1-2 inches between the oil pan-crossmember. in other words probly find a truck oil pan
Old 01-25-2009, 10:30 AM   #73
drbyrdman
drbyrdman's Avatar
iam going to get a 30710 milodon pan
Old 01-25-2009, 06:00 PM   #74
CTENTA1
Registered 1971 K5
Thumbs up Re: 67-72 BigBlock 4x4s! Pos pics info here.
So you should be able to use the Milodon pan and original small block engine crossmember and have no problems? Cool ill keep that in mind for when it's time to do the conversion.
CTENTA1 is offline   Reply With Quote
Old 01-26-2009, 10:38 PM   #75
72chevyk10
I built it
72chevyk10's Avatar
yea thats the same oil pan i use and im on all sbc mounts
