01-10-2015, 09:30 AM | #51 |
The 60-66 GMC/Pontiac guy....
Re: Intro and Some Photos of my '63 Project
I can't wait to see the motor back in it.
And see the thing make a poncho motivated run... That truck is a bad boy!
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
01-10-2015, 09:56 PM | #52 |
It's Better With Nitro
Thanks! Me neither. In the meantime, in case I forgot to post it, I did finish my deluxe steering wheel modification. It was an unintended diameter reduction, as I was planning on restoring the old original deluxe wheel, but it was too much of a basket case as I got into it. So, I cut out the hub and welded it to a '61 Pontiac steering wheel I had reduced a long time ago for a Ventura project that never materialized.
...size difference after welding the hub to the outer ring... ...lots of epoxy - previous sectioned area on the bottom wheel that I epoxied 10 years ago started to crack: ...about 45 hours of sanding and shaping with another application of epoxy in between: ...painted then assembled:
01-11-2015, 09:59 AM | #53 |
That wheel looks great!
01-11-2015, 11:28 AM | #54 |
Great job
03-21-2015, 09:20 PM | #55 |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 03-22-2015 at 09:52 AM. Reason: Added photo |
03-28-2015, 10:16 PM | #56 |
03-29-2015, 08:05 AM | #57 |
That's the main issue isn't it?
Finding -time- to do the project. ... This is by far in my top 3 favorite builds on this forum. Looking forward to more photos of progress brutha. .
04-12-2015, 09:52 AM | #58 |
04-12-2015, 10:07 AM | #59 |
SWEET! Almost spray time...
04-23-2015, 05:06 PM | #60 |
Thanks! Ended up having to completely strip the top of the hood, which set us back a bit. But, a color test was shot on the underside today. Color and hue are good to go…
04-23-2015, 05:48 PM | #61 |
OE dark green or something newer?
04-23-2015, 06:01 PM | #62 |
Going with a darker tone of the late GM Woodland Green. Kind of a modern homage to the original early Woodland Green.
04-23-2015, 09:14 PM | #63 |
While I am not a huge fan of green... I think that looks great...:-)
Posted via Mobile Device |
04-23-2015, 09:57 PM | #64 |
Cool..... Looking forward to your progress.
04-30-2015, 12:25 PM | #65 |
Thanks, guys! You can tell from the photo in post 56 of the work on the driver side door that underneath the white, the previous owner painted the truck (along with the orange scallops), the truck (code 535) was originally Woodland Green with the Cameo White two tone. I'm going to use a shade of the Hyundai Powder White as the second color to better match the flake in the newer GM Woodland Green.
04-30-2015, 01:10 PM | #66 |
Nice job on the doors, fenders and hood. That color looks great
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-18-2015, 09:05 AM | #67 |
05-18-2015, 09:09 AM | #68 |
Awesome
05-21-2015, 02:33 PM | #69 |
subscribed.
Nice work
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
06-29-2015, 08:25 AM | #70 |
Working on a couple projects at the same time, so I've been a little laxed on posting progress photos. Small parts were shot. The bed is next.
06-29-2015, 09:02 AM | #71 |
I know how it is to be spread thin across several projects...
But the quality certainly has suffered because of it.. That's apparent by the photos... really looks great.. I can't wait to see it done..
07-01-2015, 12:51 PM | #72 |
What a beautiful truck!! I'm running into a hell of a problem with mounting my '66 389 in my 64 c10 the issue is mostly with the exhaust. I was thinking about hacking up my headers, but the other issue is that I have to bolt the engine mounts to the cross member and mock up seems to be really high and looks to need some of the cab cut out. Please help!
07-01-2015, 01:55 PM | #73 | |
Are you using one of the GM conversion motor mounts? Also, what about the headers is the issue?
07-01-2015, 02:03 PM | #74 |
07-01-2015, 02:12 PM | #75 |
I honestly never thought I would see green paint that I would like. ..
That truck is going to be gorgeous! !! AND be pontiac powered! Nice
