Old 07-02-2008, 09:34 PM   #51
AJohn6
Knuckle head
AJohn6's Avatar
Re: Project Step Aside, 1971 SWB/Step
Originally Posted by abadsvt View Post
WOWOWOWOW!!!!! Your truck is sweet!!! I love everything about it!
They don't make the grey centered wheels anymore and that was a few years ago. I had my powedercoated grey in the center with a custom grey powdercoat mix. Keep up the great work!!!!!
I find the gray centered ones all over the web, they must have started re-selling them. I appreciate the compliments. I still have some catching up to do to get on your level.
Originally Posted by 49m View Post
What did you do with the old wheels
I still have them, I'm gonna keep them around as a spare set.
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 07-02-2008, 09:47 PM   #52
AJohn6
Knuckle head
AJohn6's Avatar
I took yesterday off from work so I could play with the new toys, man oh man they are nice. I can definitly tell it has been a few years since I have welded any substantial amount. Heck, I used to build firetrucks and TIG weld high pressure pipe. I was even bonified, qualified and certified by the guys who say you can weld certain things or not.
Any how back on topic, I got the small c-notch welded into the frame and I got the tank, valves, and compressor moounted.
Adam
Old 07-03-2008, 10:03 AM   #53
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Cool!!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-04-2008, 10:53 AM   #54
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
The truck is looking good.. I have a question though.. where did those clear side markers come from?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-04-2008, 11:18 AM   #55
AJohn6
Knuckle head
AJohn6's Avatar
I ordered them from Brothers. I believe this is the link to them.
http://www.brotherstrucks.com/prodin...number=SMAE2CL
I don't know if I like them though. I have seen the ones in the link below on a few trucks and I like the way they keep the original look of the lights only with a clear lens.
http://www.brotherstrucks.com/prodin...er=SMADKIT%2DC
Adam
Old 07-04-2008, 11:30 AM   #56
MisterE72
Keep Your Nose Clean
Thank you for your service to our country. The truck is looking really good. I dig the stance with the air out. Did you encounter any clearance issues with the 10" wide rear wheel and 5.25 backspace? Thanks Mister E
MisterE72 is offline   Reply With Quote
Old 07-04-2008, 11:39 AM   #57
AJohn6
Knuckle head
AJohn6's Avatar
Well, I got a bit more done yesterday. I got the airlines ran, and the rear shocks mounted. A piece of advice for all you newbies out there like myself, don't do any plasma cutting around freshly ran airlines... DOH! Also, the fitting that was in the left front bag was leaking. I had to remove the upper plate since I just couldn't get it to stop leaking. Once I replaced the fitting it was all good.
Adam
Old 07-04-2008, 11:46 AM   #58
AJohn6
Knuckle head
AJohn6's Avatar
I haven't been able to air it out all the way with the bed on yet. In the previous pictures the frames original bumpstops in the rear are sitting on the rearend. I have now removed those and notched the fram so it sits quite lower. I still don't think the truck will sit level when airred out. I have a strong feeling that I am going to run into problems with rear tires, clearance was a little tight. I will see what i can do to make them fit and if I can't then I will just have to figure something else out.
Adam
Old 07-04-2008, 03:05 PM   #59
FRENCHBLUE72
PROJECT 7DEUCE
I have the clear ones on the botton link they are ok but how do yours look at night lit up?
MEMBER #6377
Project "7DEUCE"
Old 07-04-2008, 04:55 PM   #60
AJohn6
Knuckle head
AJohn6's Avatar
Frenchblue72, i guess it depends on what you are looking for. I don't really care for them because you can see the bulb at night. Thats why I like the non "Euro" ones. I will see if i can get a couple pic's of it when it gets dark out, let you be the judge.
Adam
Old 07-04-2008, 07:34 PM   #61
wildchild
your truck looks awesome i hope my 70 looks that clean some day if you are looking online for parts check out kennys trucks in tulsa if you cant find what your looking for try calling him its not a real big shop but he can suprize you most of his stuff is cheaper than anyone else ive found
wildchild is offline   Reply With Quote
Old 07-04-2008, 09:33 PM   #62
FREEMAN70
FREEMAN70's Avatar
Thumbs up Re: Project Step Aside, 1971 SWB/Step
man this truck is sweet, hope mine turns out half as good as this one. man i would like to maybe check it out sometime.
FREEMAN70 is offline   Reply With Quote
Old 07-08-2008, 08:35 PM   #63
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Originally Posted by AJohn6 View Post
Hey all you step siders out there, I need some help.
I need a passenger side bed step hanger bracket. I have looked at almost all of the online dealers and I can't find one.
Just wanted to see if the Brkt has showed up yet, If not i will check the Post Office & see what the Problem is............
Let me Know, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 07-08-2008, 08:41 PM   #64
c10addict
c10addict's Avatar
Let me Know, Rick
If it is lost I am pretty sure I have one I can send you.... Let me know..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 07-11-2008, 10:26 PM   #65
d10s69c10
Built 4 Speed
d10s69c10's Avatar
VERY VERY SICK BUILD! i want the same thing on my fleetside...
but if i may say one thing welder to welder i now the wieght of the truck is being held in front of your Frame notch. It would take a whole lot of wieght in the back to bend it but just 2 cents would be to box the spot where you notched it on the inside and possibly run a 1/4-3/8 flat gusset on the outside just to make sure nothing goes wrong.
done alot of gusseting on lowriders (hydraulics) and the brunt force tears these things apart.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 07-11-2008, 11:13 PM   #66
BACKYARD88
BACKYARD88's Avatar
Looking good Mang
-Mike Owen-
Old 07-13-2008, 11:12 AM   #67
The Big Green
Now thats a saweeet truck, I cant wait to see how it sits. good job man! I am ordering the same wheels and want to see how they fit when aired out.
The Big Green is offline   Reply With Quote
Old 07-15-2008, 11:47 AM   #68
AJohn6
Knuckle head
AJohn6's Avatar
Let me Know, Rick
Rick, thanks a million man, I got it.
c10addict, I appreciate the help, Ricks part came in.
I was thinking the same thing. I had been re-browsing through a bunch of the builds on here and I was coming to the same conclusion. Thanks for you advice and I am going to take it. It can never be too strong.
Adam
Old 07-19-2008, 08:27 PM   #69
VA72C10
VA72C10
VA72C10's Avatar
Great looking build. Following to learn some things
VA72C10 is offline   Reply With Quote
Old 08-07-2008, 05:07 PM   #70
19stepSide72
wanna be 67
19stepSide72's Avatar
I need more info.....feed me!! Nice looking truck.
19stepSide72 is offline   Reply With Quote
Old 08-08-2008, 05:47 PM   #71
Hart_Rod
Hart_Rod's Avatar
John - the truck looks great! Gotta love a lowered stepper, .
Hart_Rod is offline   Reply With Quote
Old 08-08-2008, 08:45 PM   #72
VA72C10
VA72C10
VA72C10's Avatar
Any more pics since the notch? Trying to decide if it's worth it to do it since i'm not going to modify my steel bed floor.
Old 08-09-2008, 04:15 PM   #73
AJohn6
Knuckle head
AJohn6's Avatar
Sorry fellas, no new updates. I have been working some insane hours and I haven't had a day off in quite some time. In fact I just got home from work and I have to work tomorrow. I haven't touched the notch yet although I did start wiring the valves and compressor up. I would suggest doing a notch I just would do one so you can get it an inch or two lower. The pic below shows how low it can go with factory bumps stops and no notch.
I hope that helps
Adam
Old 08-19-2008, 08:26 AM   #74
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Lookin low! Now ya gotta get that chin spoiler off and you'll be set!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-19-2008, 01:48 PM   #75
AJohn6
Knuckle head
AJohn6's Avatar
Yeah, the air dam is off, I just don't have any pictures of it yet...
I'm stuck back down in FL now dealing with a little wind and rain from Tropical storm Fay. Maybe one day I will get to work on it again.
Adam
