Old 02-22-2009, 12:45 PM   #51
Barebones66
Barebones66's Avatar
Re: My 65 Build
Originally Posted by FreeRideYZ250 View Post
Honestly man, this is my first go at any kind of body work or automotive paint spraying. I use an airless and spray latex house paint all the time, it is somewhat similar and alot different at the same time.
Obviously you have to have the tools to do the work, .
Well your doing a fine job for your first go at it. Ironically I paint too... Have done everything from sand blasting and spraying freeway brigdes and industrial to fine laquer work over the years and like you, I think it gives me the confidence I can do this. I just hope mine turns out half as good as your is.
I don't have near enough tools as I found out yesterday. I thought i'd have my bed off in no time cause in theory it's a simple task in my opinion, but with out proper tools it turns into a drugout ordeal. All the bolts in the bed are seized up. I may have to get a torch to free them cause I need to get this thing apart so I can get movin on it. Any suggestions on those bolts ? They always spin from the top when you try take them off. I just don't want to butcher it and cause more work for myself. Need ideas for proper torch to go with. Shoot me a pm if you have any ideas I don't want to rob your thread.
Great job man. Keep it up
Looking forward to the progress.
1st project 66 SWB
Dave
Barebones66 is offline   Reply With Quote
Old 02-22-2009, 02:15 PM   #52
FreeRideYZ250
Re: My 65 Build
I haven't experienced the seized bed bolts yet. On the parts truck I bought, we just cut all the bolts off with an oxy acetylene torch. Might have to do the same on this one. I plan to use new hardware any how.
You might try a map gas plumbing torch to heat them up and expand them. However if you don't have a way of holding the top of them you may have to cut them off. Either a die grinder with a cut off wheel, oxy acetylene torch, maybe you can break the nut off with an air chisel.
I had to slit the nut, and break them, when I removed my front bumper.
Sometimes you have to get innovative.
FreeRideYZ250 is offline   Reply With Quote
Old 02-22-2009, 02:35 PM   #53
Barebones66
Re: My 65 Build
Yeah I tried the air chisel and the grinder (neighbors loved that ) but I just don't want to butcher the base of the bed panels cause i'll be reusing them and don't want to create more work for myself. thats why im thinking acetylene torch and hit it from underneath to limit the damage on the edge. Gotta shop around cause I need a welder too.
Not worried about the bedstrips so much cause i'll get a new kit for mine as well. Torches zip them off like butter from what I understand but im wondering how much damage that does.. guess i'll find out. I feel like just grinding off the top of each head then just cleaning it up and deal with it. Either way, it's coming off.
I even had visions of cutting the bed open in the middle with a metal saw zaw so I could just stand in the middle of the bed and reach everything easier Probably not such a good idea though
Don't mean to hack your thread, thanks for the help man.
Again, nice job on the project.
1st project 66 SWB
Dave
Old 02-22-2009, 03:04 PM   #54
FreeRideYZ250
Re: My 65 Build
Thank you, and no worries about the thread hi jack. If its helpful information, its all good.
I should be making alot of progress in the next few weeks. Finishing up painting the odds and ends now, to put the front end back together. Have a few more parts to order for the motor. And assembly begins.
Old 02-22-2009, 05:01 PM   #55
Iron-Butt
454 club
Iron-Butt's Avatar
Re: My 65 Build
great work.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 02-23-2009, 12:57 AM   #56
Captainfab
60-66 Nut
Re: My 65 Build
Just watch the direction of the torch. If it is touching or close to other metal, it will heat it up as well and you could blow a hole where you don't want it. If you find you need to cut a bolt and it is in a bad place, try using a larger thicker piece of steel to deflect the flame and subsequent blast of molten metal from damaging other areas. also when cutting bolts it is easiest to start at the tip and work your way down little by little being careful when you get to the bottom.....hijack off.
Old 02-23-2009, 03:03 PM   #57
protrash64
Resistance is Futile
protrash64's Avatar
Re: My 65 Build
First off.....nice work YZ250....the frame looks killer, the engine is killer, etc, etc.
I took apart my donor bed with a sawzall....3/4's of the wood was gone anyway. It was not fun.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-23-2009, 03:56 PM   #58
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: My 65 Build
Mad skillz, dude!
Joey~AP is offline   Reply With Quote
Old 02-23-2009, 06:12 PM   #59
66Z71
66Z71's Avatar
Re: My 65 Build
I don't know how I've missed this tread. That's going to be a nice truck. I love the color.
Eric
66Z71 is offline   Reply With Quote
Old 02-23-2009, 07:37 PM   #60
FreeRideYZ250
Re: My 65 Build
Thank you. Look forward to meeting you at a show and bs'n trucks.
Can't wait to cruise it.
Old 02-23-2009, 07:39 PM   #61
FreeRideYZ250
Re: My 65 Build
Originally Posted by Joey~AP View Post
Mad skillz, dude!
Thank you.
Eric
Thank you. The color is just primer for now. It will remain my top coat until the entire truck is ready for paint. Not sure on the exact color combo when I get to that point. The primer is is PPG DP 60
Old 02-23-2009, 09:15 PM   #62
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
Re: My 65 Build
Great looking progress on it. I too got mine from my Grandpa but luckily I didn't have to pay for it. Just the money to do what I'm doing now. Maybe I'll be able to find some more old pics of the truck from when he bought it much like yours.
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 02-24-2009, 11:06 PM   #63
FreeRideYZ250
Re: My 65 Build
And the saga rolls on.
Brake booster mock up and brake line tweaking to match.
Parts painted.
Old 02-24-2009, 11:09 PM   #64
FreeRideYZ250
Re: My 65 Build
Party on Wayne. Party on Garth!
Front end parts in various stages.
The grey paint is a hammertone aerosol. The black is a full gloss black aerosol.
Old 02-24-2009, 11:16 PM   #65
FreeRideYZ250
Re: My 65 Build
Lastly for today.
A very helpful tool set up. 4.5" electric angle grinder with wire wheel on it. Have burned through about $50 worth of harbor freight wire wheels on this project. However I don't know what I would have used other wise. Very useful tool.
Engine side view: New starter, motor mount, and exhaust manifold mock up. I plan on running manifolds to break the motor in and (not as much heat on the valves) until I can pony up the pennies to buy good headers and have new exhaust bent. It has 2.5" dual pipes into older flowmaster 2 chambers now, dumping in front of rear end. Its a little loud. I want to do the exhaust all at once.
Old 02-24-2009, 11:18 PM   #66
joe231
joe231's Avatar
Re: My 65 Build
Looking Good!!!!
CHEVY ONLY
Old 02-24-2009, 11:26 PM   #67
protrash64
protrash64's Avatar
Re: My 65 Build
Absolutely!!! Nice work again today, and be sure to wear the safety glasses with those wire wheels.
Old 02-24-2009, 11:37 PM   #68
FreeRideYZ250
Re: My 65 Build
No doubt about the safety glasses thing. I had a few bristles stuck through my pants and into my flesh when I came in from the garage last night.
My dad has worked in a machine shop for 35 years, and has had a few eye drillings. He tought me young to always protect my eyes.
Old 02-24-2009, 11:41 PM   #69
protrash64
protrash64's Avatar
Re: My 65 Build
Yeah buddy, I wear shorts year round, cuz, we can right? Those bristles hurt when you get nailed by one! Im sure Joe231 is going to post up a violin player any moment now.
Old 02-24-2009, 11:45 PM   #70
joe231
joe231's Avatar
Re: My 65 Build
couldn't help it....sorry
CHEVY ONLY
Old 02-24-2009, 11:53 PM   #71
protrash64
protrash64's Avatar
Re: My 65 Build
.........its my fault YZ250.
Old 02-24-2009, 11:59 PM   #72
Barebones66
Re: My 65 Build
good progress
question is when you gonna fix the garage door spring ? lol nice brace, just like a painter
1st project 66 SWB
Dave
Old 02-25-2009, 09:39 AM   #73
FreeRideYZ250
Re: My 65 Build
good progress
Nice notice of the brace. The garage door springs actually work decent for a 30 year old garage door. They just don't like it when I hang things on the door, it sags down a bit. Being 6'2" I need the door all the way up, or I have to wear a helment when I'm working.
The door shuts just enough to where its above eye sight line, however its low enough I will whack my head on it.
Old 02-25-2009, 10:19 AM   #74
TimE
Hey Y'all!!
TimE's Avatar
Re: My 65 Build
I'm guessin' you figured that out the hard way??
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-25-2009, 11:28 AM   #75
Strodder
Daring to be Different
Strodder's Avatar
Re: My 65 Build
Coming along real nice. I do the same thing hanging things to paint on my garage door. Only I have a roll up door.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
