Old 06-09-2009, 04:22 PM   #51
justpball
justpball's Avatar
Re: 90 burb (( daily dragger))
did you do the front arms that way so the bag can set in the hole so it will be lower? did you still use cups on the bottom of the bag?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 06-09-2009, 08:46 PM   #52
87 dually burb
my short bus
87 dually burb's Avatar
I bolted the bags to the lca's just drill a hole in the center for the bag
The d-2600 bags rubs alittle so I'm going to change to the d2500
I havent done much on the back lately rainy ever after noon and saturday at 4am I fly to La for work till friday night ordering notch and bag mounts so I can get it started saturday when I get in
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 06-10-2009, 08:32 AM   #53
justpball
justpball's Avatar
cool bro, thanks for the info!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-15-2009, 10:00 PM   #54
87 dually burb
my short bus
4 days in la I dont get where are all the custom rides are
we went to santa monica,vinice,maria del ray,sunset strip,walked hollywood blvd only 3 coolrides all week
I can wait to get back to Va I dont get the whole la thing
got some cool pics to post when home
Old 06-23-2009, 02:01 PM   #55
justpball
justpball's Avatar
any new stuff??? wondering what you are going to do with the back?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-24-2009, 08:05 AM   #56
tvblazer78
Low & Fast!
tvblazer78's Avatar
Ya we need some more pics of this thing. You have to be close to getting this thing going..
tvblazer78 is offline   Reply With Quote
Old 06-25-2009, 12:58 PM   #57
87 dually burb
my short bus
the job box full of tools wont be back till friday and I need the plasma cutter to finish the floor cut out notch and tub kit should be in next friday the truck has sat since jun first hoping to finish it up by first weekend in july have to drive it to Pa for a week vacation
Old 07-08-2009, 11:31 PM   #58
87 dually burb
my short bus
got most every thing cut out for the notch and cover
going to a buddy house thur for some welding should have the notch in friday after noon
Old 07-09-2009, 08:28 AM   #59
tvblazer78
Low & Fast!
tvblazer78's Avatar
Pics? You know that what we would be asking..
Old 07-09-2009, 10:09 PM   #60
87 dually burb
my short bus
I had to order another notch should be in friday if its there I'll have pic's with it in I dropped the truck off around 1 pm and dont have any new pic's
Old 07-10-2009, 08:45 AM   #61
justpball
justpball's Avatar
which notch did you have to go with?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-11-2009, 03:24 PM   #62
87 dually burb
my short bus
10" 8 pc from sd it didn't should so maybe monday everything is cut and ready just need to weld in notch and figure out mounts
Old 07-19-2009, 10:25 PM   #63
87 dually burb
my short bus
got 8.5"s from bottom of frame to notch
will have better pics by wend when the bag mounts are on
Old 07-19-2009, 10:28 PM   #64
87 dually burb
my short bus
side note the notch is 1" narrower than the frame for the burbs
we notched the inner frame for it to work and 45'd the outer edges with a plate back to the frame
will have pic later to explain it better
Old 07-20-2009, 08:49 AM   #65
justpball
justpball's Avatar
how much above the stock floor does the notch come?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-20-2009, 10:29 PM   #66
87 dually burb
my short bus
I'll get measurements tues when I start on bag mounts
Old 07-25-2009, 10:31 AM   #67
justpball
justpball's Avatar
updates?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-25-2009, 08:46 PM   #68
87 dually burb
my short bus
yes bags are in measurements are in truck
will post in the am
no pic's till my desk top is back later in the week
sits level with front (with no gas,rear seat
should drop 2-3 more inches when interior/tank has gas (40 gals)
need to z front in the winter
Old 10-14-2009, 05:53 PM   #69
87 dually burb
my short bus
I have a teaser pic for you ok follow along as I detail all I'm having done at the welding shop this week
welded in tubs/ notch cover (removable top panel for access)
redid spare tire area for my 2 co2 bottles to fit
had my roll pan welded in
shaved: tail lights,mirrors,roof rack holes, antenna
covering up body lines in tailgate 1' from each end and mounting tag in 2" box in center of tail gate
Old 10-15-2009, 12:30 PM   #70
HarrisonTX
In post#1, your first post here, what did you do to achieve that drop?
It looks level, and low enough for me!
Im refering to the third picture, in post number 1.
You 'burb looks real good man.
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 10-15-2009, 01:48 PM   #71
SBTork
Garage wrench
SBTork's Avatar
Do you have a pic of this?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 10-15-2009, 03:47 PM   #72
tvblazer78
Low & Fast!
tvblazer78's Avatar
That looks sweet! We have to have better pics then this to see all that cool work!
Old 10-15-2009, 05:09 PM   #73
87 dually burb
my short bus
going to pic up from welding shop friday morning
Old 10-15-2009, 06:34 PM   #74
HarrisonTX
'69 custom/camper
'86 k5 blazer
'06 Duramax
Old 10-15-2009, 07:07 PM   #75
87 dually burb
my short bus
the 3rd pic is with the 6" flip and no over load springs ( bottomed out on frame alot) 2" of travel in rear
the front is 3" belltech spindle and a SD bag kit the height you see in pic 3 is with the front aired out sitting on inner fender wheels
also note they are 31" tires it sat about 2" high in front at that time
