Closed Thread
Old 07-10-2009, 12:12 AM   #51
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Originally Posted by Hickup pickup View Post
I will be puting a nitrogen infused intercooler to disipate the generated heat transduced through a ridgid Kenuter valve perpetuated into a Flux capacitor.thus cooling the center cap.
haha gotta love the kenuter valve/flux capacitor setup. been using that one for years!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline
Old 07-10-2009, 07:03 AM   #52
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Would these wheels fit a large GM car rotor that has 5x5 (what was that, Caprice or Roadmaster?) And if so, will the car rotor work on our truck with a bearing change?
chuckmc8 is offline
Old 07-10-2009, 08:12 AM   #53
aggie91
I'm just glad to be here!
aggie91's Avatar
Did a quick search Rock Auto for this idea. They list the same Raybestos part number for the rotors for the 1978-1990 Caprice (along with some Buick and Cadillac models) and the 1981-1987 Chevy/GMC 1/2 ton pickups. Same issue with the 71-72 C10 and the 71-76 Caprice and Caprice Classic.
So, this looks like this would not work any better...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 07-10-2009, 08:14 AM   #54
SCOTI
SCOTI's Avatar
I think the PLASTIC cap would melt long before the silicone.
I'm sorry..... I don't recall saying anything about melting . My logic was more on the heat cycles, bearing grease, & road grime that's typically associated w/the spindle hub area.
These are nice looking wheels. Not nice enough to jump through the hoops required to run them w/1/2 ton truck rotors IMO.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 07-10-2009, 09:39 AM   #55
Jbham88
Jbham88's Avatar
can you advise how much was machined from the rotor snout.
1986 GMC 4x4
Jbham88 is offline
Old 07-10-2009, 09:55 AM   #56
chuckmc8
chuckmc8's Avatar
Anyone have an idea of which car/application/front rotor this is suppose to fit w/o modifications?
chuckmc8 is offline
Old 07-10-2009, 10:32 AM   #57
au03z71
au03z71's Avatar
Methinks I might just stick with the Coys C-5s
au03z71 is offline
Old 07-10-2009, 10:38 AM   #58
lolife99
67-72 parts collector,…
lolife99's Avatar
That's a good question.
Maybe these were designed for the 88-98 2wd trucks?
Keith
Convert to disc brakes.
lolife99 is offline
Old 07-10-2009, 10:40 AM   #59
Hickup pickup
Hickup pickup's Avatar
ScotI dont take things so seriously, My point being you have little choice in the matter if you insist on running this wheel ( i am already committed), I feel you probably stand the same chance in loosing the cap while siliconed on as you do with the weak clips they come with.
2-20, 2-21 whatever it takes!
Hickup pickup is offline
Old 07-10-2009, 10:56 AM   #60
Security guy
Security guy's Avatar
Haha, this is a good thread. Thanks for all the pics and info on these. It looks like you've helped us all on these. I'm curious too, what are these wheels designed for? They do look good, just is it worth saving a few bucks to go through all this, or just get some coys with a little less problems?
Security guy is offline
Old 07-10-2009, 11:09 AM   #61
Hickup pickup
Jbham88 I simply machined them until they fit taking care to keep as much material as possible around the race ares , This is why I suggest the coning. I can tell you the end of the snout was machined down to the same size as the aftermarket replacement cap and it only has about 1/32 of an inch clearance in the wheel.
Old 07-10-2009, 02:25 PM   #62
Jbham88
Jbham88's Avatar
They Have to fit something I dont have a local dealer to find out
1986 GMC 4x4
Jbham88 is offline
Old 07-10-2009, 04:05 PM   #63
Chad71
Chad71's Avatar
Damn these are beautiful wheels,nice choice.
1971 Chevorlet Custom Deluxe C10
2007 Chevorlet HHR- lots of mods
Chad71 is offline
Old 07-10-2009, 04:15 PM   #64
SCOTI
SCOTI's Avatar
ScotI dont take things so seriously, My point being you have little choice in the matter if you insist on running this wheel.....
Neither should you. I edited my response to better portray the mindset.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 07-10-2009, 04:19 PM   #65
big_al_71
big_al_71's Avatar
it seems like quite an amount of work to get these wheels to fit but at the end you will be unique...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 07-10-2009, 05:43 PM   #66
Hickup pickup
Mod to dust cap
Old 07-10-2009, 05:47 PM   #67
Hickup pickup
Just about there
Old 07-10-2009, 05:55 PM   #68
SCOTI
SCOTI's Avatar
That's a sweet burb BTW.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 07-10-2009, 06:21 PM   #69
Hickup pickup
Thanks SCOTI !
Old 07-10-2009, 09:22 PM   #70
Dinos63
chevy only
Dinos63's Avatar
it looks killer,worth the work rob
CHEVY ONLY... Nothin Else !
Dinos63 is offline
Old 07-12-2009, 06:31 AM   #71
chuckmc8
chuckmc8's Avatar
I found a retailer on the web that had this info posted. I just Googled "BOSS 338 fitment guide" and chose one. Although these are 18" I think we determined that the hub area is the same on the 18 and the 20". I just cut and pasted the info below. Notice that the vehicle that I chose was a 71 Blazer, It didnt give a 5 lug 71 truck as an option. These have "gauranteed fitment" I guess that no one has tried it on a truck rotor tho. It does have the other models listed that these are suppose to fit in a 5x5 lug pattern. Any of these GM rotors interchange with our trucks?
OEM tires: 225/75-15 (717x225mm). Bolt pattern: 5x127 (5x5). Offset: -10 to 10 mm. Tires up to 757x265mm. Rims up to 23x9.5".
Browse:
What Fits
Styles
Specs
TIRES
DIRECT FIT package. [ Fitment Guarantee] See package options See what else fits
Back
BOSS 338 B
18x9.5, Bolt Pattern (PCD) 5x127 (5x5), Offset (ET) -4mm
Gray/Machined Lip, $169.00 each.
5x127 (5x5) bolt pattern, offset -4 is considerable for:
( 18x9.5 size can be unsuitable for certain models/years/trims )
Buick: Roadmaster
Cadillac: DeVille
Chevrolet: 1500 2WD truck Astro Blazer 2WD C10 C1500 454SS truck Impala Laredo 2WD Suburban 1500 2WD Tahoe 2WD Van 5 lug
GMC: 1500 2WD truck Jimmy Full Size 2WD Safari Savana 1500 Suburban 1500 2WD
Lincoln: Continental Mark III
I also looked for Astro van rotors for a pic-notice the step in the hub that is similar to the machined version that was modified for the 'burb
chuckmc8 is offline
Old 07-12-2009, 08:49 PM   #72
big_al_71
big_al_71's Avatar
are these the same wheels?
Old 07-12-2009, 09:04 PM   #73
chuckmc8
chuckmc8's Avatar
I think so Al.
chuckmc8 is offline
Old 07-13-2009, 09:59 AM   #74
chuckmc8
chuckmc8's Avatar
I think that I know whats going on here with the rotors. After 1988 all 5x5 rotors are 'stepped' on the hub like the Astro van rotors that I posted the pics above. i just looked up 88 & up applications for C/10, Van, burb and so on and all are stepped. prior years are not.
So the kwestion (my kue doesnt work on my keyboard) is there a way to run the later model rotors (88 & later) (ed:I have since found out there isnt)
I am running an 1986 crossmember with 2 1/2" drop spindles.
BTW, The coys dont fit w/o mods either. Here is a thread for reading with good photos on the coys. The 71-87 rotor hubs are the problem...after 88 I beleive the BOSS 338 or the Coys just bolt on w/o any mods
http://67-72chevytrucks.com/vboard/s...d.php?t=300737
UPDATE-I went to AutoZone and asked them to put an 86 rotor and a 88 rotor on the bench so that I could compare them- the 88 and later hub (and thus the spindle) is 1" shorter than the 87 & earlier stuff. That explains how the BOSS center cap clips in as designed. There would be ample room on the 88 and up rotor.
here is a 1988 & up rotor
The only other thing to check is if 88 & up spindles (with these smaller rotors & brake components)
would work on 67-72 suspensions.....if not, the grinding/lathe turning proceedure will be the only way to run these wheels.
Maybe useless info, but it doesnt cost anything to gather......and maybe help someone else
chuckmc8 is offline
Old 07-13-2009, 10:12 AM   #75
BossHogg69
motor exploder
BossHogg69's Avatar
I'm not poking fun here, but for some reason I couldn't stop laughing, not because your 'kue' doesn't work, but because you just kept on truckin' without it! that's awesome!
Adam
Closed Thread
